Old 01-26-2018, 09:35 AM   #1
Miguelgomez
Drives: 2016 FRS
Check engine light
i got the P0420 code 2 days ago after installing catted UEL Headers a month and a half ago. I know that usually means either the o2 sensor or the catalytic converter but the thing is ever since the check engine light came on the down shifts make no noise what so ever and they used to be VERY loud and the revs dont go up like before when down shifting. also when the car drops back down to 2nd or 1st gear either in auto or manual mode it shifts very hard. Any idea as to why that is?
Thanks
Miguelgomez is offline   Reply With Quote
Old 01-26-2018, 09:38 AM   #2
The car thinks there is an issue and is pulling power. Need to get the cel cleared. Do you have a tune?
Old 01-26-2018, 10:38 AM   #3
Miguelgomez
Drives: 2016 FRS
I didn't think of that. No I haven't gotten it tuned yet. I was going to wait until I finished the full exhaust so I wouldn't have to tune twice but I guess it would be better to tune it now to avoid this again.
Old 01-26-2018, 10:44 AM   #4
You just need to tune for the header anyway. The rest of the exhaust has little need for a tune.
humfrz (01-26-2018)
Old 01-26-2018, 11:09 AM   #5
Miguelgomez
Drives: 2016 FRS
Thanks for the help. Hopefully it goes back to normal performance and sound after
Old 01-26-2018, 11:15 AM   #6
Yep if you tune and clear the code it should go back to normal.
check engine light, p0420
Check Engine light and Traction Control Light JeRM Issues | Warranty | Recalls / TSB 25 06-02-2023 10:00 PM
Help! From check engine light to fouled plugs back to check engine + plugs refouling larchamb Issues | Warranty | Recalls / TSB 44 04-03-2016 10:39 AM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 07:06 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 07:16 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 07:50 AM
