Old 01-24-2018, 10:58 AM   #897
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by all4spl View Post
And I would also do the head studs vs head bolts. I always feel safer torqueing down on thread of the studs vs threads of the block, especially with ARP. The block will give before the bolts do.
I had a nightmare experience back in the day with a block thread failing after motor was reassembled... Definitely Head Studs >>>> Head bolts.
That was crazy back in the day, had to send the block to a machine shop to re-thread, bought bolts and sent to other machine shop who actually cut the bolt head and threaded it, making it a stud.
At this point, the problem was the nut was too big to allow the socket in the hole to tighten it (it was 17mm thread, needed a 14 mm nut)... So that machine shop actually by hand (meaning it wasn't a CNC machine, it was a manual machine) modified the 17mm nuts to be a 14mm nut.... That ultimately worked.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
DustinS (01-24-2018)
Old 01-24-2018, 01:08 PM   #898
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Thinking about pulling the heads tonight... I just hate taking the car down so soon
The Following User Says Thank You to DustinS For This Useful Post:
Sportsguy83 (01-24-2018)
Old 01-24-2018, 01:33 PM   #899
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Just do it now so it’s ready for the good weather
ILLSMOQ is offline   Reply With Quote
The Following 2 Users Say Thank You to ILLSMOQ For This Useful Post:
DustinS (01-24-2018), Sportsguy83 (01-24-2018)
Old 01-25-2018, 04:22 PM   #900
all4spl
I say pull it now. It's already "broke" why not tear it down now and possibly fix it before it gets worse. Atleast you'll know what youre up against.
all4spl is offline   Reply With Quote
Old 01-25-2018, 04:57 PM   #901
DustinS
DustinS's Avatar
Going to start off with taking the heads off to get a good look at the cam. I am suspecting the Cam/bearings as you have said. I'll go from there.
Took the car out once more last night as a friend wanted to install fog lights on my car. Been driving the car easy since the oil change. Really hope the block isn't trash
Old 01-25-2018, 06:19 PM   #902
ILLSMOQ
It’s not trash buddy
Old 01-26-2018, 11:28 AM   #903
DustinS
DustinS's Avatar
Difficult to see, but there is some weird wear mark here.
Old 01-31-2018, 12:14 PM   #904
DustinS
DustinS's Avatar
More Ideas
ILLSMOQ (01-31-2018)
Old 01-31-2018, 12:18 PM   #905
ILLSMOQ
Ahhh...the turbos
The Following User Says Thank You to ILLSMOQ For This Useful Post:
DustinS (01-31-2018)
Old 02-05-2018, 12:08 PM   #906
DustinS
DustinS's Avatar
Well got it torn down to just the short block. Waiting to get an engine hoist/for the snow to melt so I can get it out. I also tested a possible new radiator mounting. Just lay it down further for more room behind it for intake and venting.
Should have plenty room for some ducting.
Had two of the Rocker Arm Bolts almost strip out on me. Cylinder 3 & 4.
Weird finish on oil pump:
Cam Bearing #2 looks not so great.
Old 02-06-2018, 11:42 AM   #907
DustinS
DustinS's Avatar
Began working on the radiator ducting:
I also went ahead and bought a set of Z06 Exhaust Manifolds:
The Following 3 Users Say Thank You to DustinS For This Useful Post:
ILLSMOQ (02-06-2018), Sportsguy83 (02-06-2018), Zer0 (02-06-2018)
Old 02-06-2018, 03:37 PM   #908
DustinS
DustinS's Avatar
Well I got someone to buy my Full Blown Radiator, so I ordered up the chase bays 240sx tucked radiator. It's a dual pass with slightly shorter height and -20an inlet/outlet on the same side. Really didn't think I was going to get this deep into it lol
The Following 5 Users Say Thank You to DustinS For This Useful Post:
ILLSMOQ (02-06-2018), Sportsguy83 (02-06-2018), wooly35 (02-09-2018), zeal86 (02-06-2018), Zer0 (02-06-2018)
Old 02-06-2018, 07:24 PM   #909
Zer0
Drives: 2015 frs
[QUOTE=DustinS;3039952]Well I got someone to buy my Full Blown Radiator, so I ordered up the chase bays 240sx tucked radiator. It's a dual pass with slightly shorter height and -20an inlet/outlet on the same side. Really didn't think I was going to get this deep into it lol
Can't wait to see your progress with your cooling setup!
Zer0 is offline   Reply With Quote
The Following User Says Thank You to Zer0 For This Useful Post:
DustinS (02-07-2018)
Old 02-08-2018, 03:44 PM   #910
DustinS
DustinS's Avatar
Stuff for the battery relocation project has been ordered. Hoping to move the fuse box to battery location to clean up the engine bay. I think I spent too much, but I want to do this once and do it right.
ABS module relocation is also going to be started tonight. I need to remove the ABS Module and start getting the wiring de-loomed and split up. Custom lines need measured and ordered. Still trying to decide between trying to bend my own hardline and ordering DOT legal stainless lines.
Warm weather is on its way and I am excited to get this stuff done.
I need to take a caliper and measure the A/C hardlines and see about ordering aluminum tubing in the right size and bending it myself.
ILLSMOQ (02-08-2018), Sportsguy83 (02-09-2018), zeal86 (02-08-2018)
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) — General Topics 13 03-22-2016 04:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-22-2015 12:38 AM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 12:14 PM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 08:32 PM
