Old 01-23-2018, 11:04 PM   #43
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
To me, the spring removal didn't really make the engagement point more defined, it made the pedal feel more linear. With the spring in, the clutch felt lighter on the lower half of the travel as the spring pivots and pushes down. With it out, the travel feels the same weight through the entire range, making it much easier to modulate.
ApexEight is offline   Reply With Quote
The Following 3 Users Say Thank You to ApexEight For This Useful Post:
ermax (01-23-2018), guybo (01-24-2018), HSUBLU (01-24-2018)
Old 01-24-2018, 06:38 AM   #44
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
The clutch in my GenCoupe was pretty terrible too. Had something to do with the DMF. I stalled that car out quite a few times.... all the while letting my passengers know that I DO KNOW HOW TO DRIVE STICK, YES, THANK YOU. And it lurched a lot when shifting in lower gears.
The whole setup just sucked. Not enough to hate the car though. My FRS is WORLDS better
guybo is offline   Reply With Quote
Old 01-24-2018, 03:23 PM   #45
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
My ex had an early Gen Coupe (2010 2.0T) and I HATED the clutch and shifter in that thing. It was so vague and rubbery, and the clutch was very light for a 200+hp sports car.
Out of curiosity, when I was about to buy my BRZ, I test-drove a 2013 Gen Coupe 2.0T with the newer more powerful engine, in the hopes that they had improved the shifter/clutch. Nope; shifting still felt like playing with rubber bands, and the clutch pedal was still light as a feather.
That being said, I worked at a Hyundai dealer for most of 2016, and it felt like there was a big difference on the newer 3.8L models. Clutch felt heavier than before, and shifter felt more direct. But I still wouldn't buy one.
@bpennerz
SLVRSRFR is offline   Reply With Quote
Old 01-24-2018, 04:27 PM   #46
HSUBLU
Drives: 2017 BRZ WR Blue
That's generally been my impression as well. I wasn't sure if I was imagining things or not but now that someone else mentioned it, I don't feel as nuts as I did before.
HSUBLU is offline   Reply With Quote
The Following User Says Thank You to HSUBLU For This Useful Post:
ApexEight (01-24-2018)
Old 01-24-2018, 09:37 PM   #47
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Removed spring, adjusted clutch pedal, and updated slave cylinder many thousands of miles ago. Still holding up strong 87k on original TOB.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Clutch return spring removal MikeyBRZ Engine, Exhaust, Transmission 186 09-16-2020 01:40 PM
Question about the clutch spring removal btan219 Engine, Exhaust, Transmission 4 05-12-2017 09:54 PM
Clutch Spring Removal DaBoBo21 Engine, Exhaust, Transmission 6 04-10-2017 06:26 PM
How To: Clutch Spring Removal in 15 Minutes eric6 DIY (Do-It-Yourself) Guides 165 02-15-2017 12:44 AM
Clutch spring removal Sandy AUSTRALIA 4 07-22-2015 11:14 PM
