go_a_way1
Old 01-17-2018, 07:57 PM   #3627
Tgutz21
He is running the following spec. I think that this is reasonable for wheels of this size. It doesn't look exaggerated to me. Though the 18x10's look huge!
Camber Info:
Front camber: -1.6
Rear camber: -2.5
I have 18x8 +35 & 18x9 +37 with 225/40 & 245/35. My camber is -1.5 f & -2.0 rear. My tire wear is even. Some camber is good; but you'll want your toe to close to zero.
The wheel directory has most Forum Members wheels specs. It is a great resource. http://www.ft86club.com/forums/showthread.php?t=7535
Also, the Meaty tire thread is great!
http://www.ft86club.com/forums/showthread.php?t=41083
Thank you for your time and info! A sales rep had told me recently to go 18x10 in the rear because i want lip. Even though he had said that I was still hesitant on it cause that’s such a wide tire. I thought I’d ask here to get a second opinion.
Tgutz21 is offline   Reply With Quote
The Following User Says Thank You to Tgutz21 For This Useful Post:
Leonardo (01-18-2018)
Old 01-21-2018, 11:27 PM   #3628
funwheeldrive
I'm interested in a set of SSR wheels. They are 16X7.5" with +48 offset. I'm wanting to use a 205/55R16 tire or something similar. Would this look strange on an otherwise stock 86?
Old 01-21-2018, 11:42 PM   #3629
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Here are 16x7.5 ssr wheels with that size tire. +48 offset will make them look similar to the stock wheels. They will look sunk in a little compared to the +35 in the link.
SSR wheels will look good.
http://www.ft86club.com/forums/showthread.php?t=36471
I LIKE TIRES!
funwheeldrive (01-22-2018)
Old 01-22-2018, 01:42 PM   #3630
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
16X7.5" with +48 offset will be 1/4" closer to fender than stock, and 1/4" further inboard. Similar in appearance to 16x7" +42 from the outside. 225/50 would be a perfect tire for that rim width; IMO a 205/55 would look skinny.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 01-25-2018, 11:40 AM   #3631
brazy
brazy's Avatar
Drives: '14 LR BRZ Limited
WHEEL |-- STOCK HEIGHT --| |-- LOWERED 1" --|
WIDTH |--- FRONT REAR ---| |-- FRONT REAR --|
7.0 |------- +25 +18 -----| |-- +23 +13 --|
7.5 |------- +31 +24 -----| |-- +29 +19 --|
8.0 |------- +38 +31 -----| |-- +36 +26 --|
8.5 |------- +44 +37 -----| |-- +42 +32 --|
9.0 |------ +50 +43 ----| |-- +48 +38 --|
9.5 |------- +57 +50 -----| |-- +55 +45 --|
10.0 |----- +56 +51 ------|
This was taken from the OP from the Wheel Directory
In my case, I have decided on 17x9 +42 wheels square.
I will be lowered about 1" on coilovers, so no concern of rubbing spring perch, but I'm looking at "perfect flush" measurements of +48 for the front and +38 for the rear
Am I to understand that I will poke 6mm in the front, and sunk in 4mm in the rear? Are those numbers based on 0 camber/factory camber?
If I run 17x9 +42 on all corners with a moderate "hard-cornering" alignment ( ~1.5 front // ~1.0 rear).. will the front really poke? My initial impression was that +42 is a pretty non-aggressive setup. I'd prefer to be slightly sunken in than poking out
brazy is offline   Reply With Quote
Old 01-25-2018, 02:21 PM   #3632
Leonardo
Country Boy 4 Life
Leonardo's Avatar
You'll be just fine! -1.5 front camber will tuck the top of the tire/wheel and will look great.
I added a 5mm spacer to my rear 9" +42 wheel to make it flush. I'm at -2 rear.
I LIKE TIRES!
brazy (01-26-2018)
Old 01-26-2018, 04:39 PM   #3633
brazy
brazy's Avatar
I had the same plan for the rear spacer.. good to know you've done the same and like it. I just wasn't sure about the front, +48 seems like a high offset for it to sit flush. Just checking! thanks for the input
Old 01-26-2018, 04:42 PM   #3634
Leonardo
Country Boy 4 Life
Leonardo's Avatar
+48 is accurate, but with your +42 wheels, coilovers, and some camber, everything will fit/look great!
I LIKE TIRES!
Old 01-29-2018, 06:36 PM   #3635
An Amish Woman
An Amish Woman's Avatar
Drives: '15 WRB Brz
What would be the best size tire for a wheel 18x9.5 +39 with coilovers and LCR?
Can't really wrap my head around how it works.
Follow me on Instagram
https://instagram.com/anamishwoman/
'15 WRB BRZ Limited (Summer)
'93 Ford Festiva L (Work Horse / Race Project)
An Amish Woman is offline   Reply With Quote
Old 01-29-2018, 08:00 PM   #3636
Leonardo
Country Boy 4 Life
Leonardo's Avatar
https://tiresize.com/calculator/
Hello!
Use this link. Type in the stock tire size in "size 1" (215/45/17)
Now type in the size tire you are thinking about in "size2" - Let's say 255/35/18. It will tell you that the diameter is only slightly (1.6%) larger diameter, but has a much wider contact patch.
I would suggest one of these sizes. 245/35/18, 255/35/18
I would also suggest reading the Meaty tire threads first page.
I LIKE TIRES!
An Amish Woman (09-13-2018)
Old 01-30-2018, 03:29 AM   #3637
ShadowWolf_99
ShadowWolf_99's Avatar
Drives: 10 Series #895
Damn there is so much to look up and check.
Im still very green on learning all these clearances and fitments.
Can anyone double check me for flushness within a close reasonable amount and a good fitment overall please?
I have:
Tein lowering springs down 1.5-ish?
Getting:
Wheels = MOTEGI RACING MR116 18X8 (45mm offset for all four)
Tires = FIRESTONE FIREHAWK INDY 500
Front: 225/40R18
Rear: 255/35R18
Or get same size that will be large enough to still fit the front and space out the rear so I can do standard tire rotations.... what size spacer for say the 255s all around?
From what I've found I should sit pretty good unless im misreading. Let me know thanks. Much appreciated.
PDX86 / 86 Sessions / 86Squad / DarkSquad
ShadowWolf_99 is offline   Reply With Quote
Old 01-30-2018, 12:23 PM   #3638
671mike
Drives: 2015 frs
18X8.5/9.5 5x100 +35/30
quick question will a 18x8.5 35 and a 18x9.5 35 fit with a front 245 rear 265 with tein s tech 1 inch drop coils
671mike is offline   Reply With Quote
Old 01-30-2018, 01:56 PM   #3639
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I have:
Getting:
Front: 225/40R18
Rear: 255/35R18
Welcome to the Forum!
18x8 +45 MOTEGI RACING MR116 will work for your front. I have the same exact size wheels for my front with the same offset, though now I have added a 10mm spacer making them +35. I am using a 225/40/18 MPSS front tire.
If you want a wider tire for the rear, I would suggest getting a wider wheel. Like in the link below. I ran a 245/35/18 on an 18x8 and it was too wide. The 255/35 is not going to be a good fit.
I have 18x9 +37 rear wheels with a 245/35/18 MPSS tire. Since my set up is close to a 18x9 +35, (like in the link) I can tell you that it will fit a 245/35/18 tire lowered on tein springs. But a 255/35 is going to be close and may rub.
https://www.amazon.com/Motegi-Racing...I+RACING+MR116
Or get the 18x8 +45 all around with a 225/40 and call it a day. You can rotate the tires that way. Adding a 10mm front and a 15mm rear will make the wheels flush. (Or 15mm front and 20mm rear for a more aggressive look)
It really is about what you want out of the wheels and tires.
Happy to help.
I LIKE TIRES!
Old 01-30-2018, 02:00 PM   #3640
ShadowWolf_99
Happy to help.
Thank you for your knowledge. Very helpful. So I'm thinking I'll do the 225s with spacers. Seems pretty logical for rotations.
Sent from my SM-G950U using Tapatalk
The Following User Says Thank You to ShadowWolf_99 For This Useful Post:
Leonardo (01-30-2018)
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
