Old 01-21-2018, 05:41 PM   #1
brkn86
Drives: 2002 Acura Rsx & 2013 Scion FRS
Clutch Spring Removal? Effects on TOB
Anyone who has removed their clutch spring. i heard that someone do not want to remove it because the spring is there to keep the clutch pedal up completely, in order to prevent the throwout bearing from touching the clutch disc; while no immediate harm is happening, you might be speeding up its wear and tear. i just want to confirm if that is true? for those who have have their spring removed and been on stock tob for a long time.
Thank you!
brkn86 is offline   Reply With Quote
Old 01-21-2018, 07:37 PM   #2
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
I don't think the spring removal affects TOB life. Without the spring, the pedal is not held all the way up like you said, and has the tinest bit of back and forth play. Even without the spring, I highly doubt the resting pedal is putting enough downward pressure to engage the TOB, and thus cause more wear. I've had my clutch spring out for 5 months now.
ApexEight is offline   Reply With Quote
Old 01-21-2018, 08:16 PM   #3
I think it's way more important to understand the clutch operating system well enough to decide.
Old 01-21-2018, 10:49 PM   #4
nico_rsx
Drives: BRZ 2017 Pure Red, MT
If you're talking about the spring in the pedal mecanism, I'm pretty sure it's actually pressing the pedal DOWN (in order to help press the pedal), and not holding it up.
nico_rsx is offline   Reply With Quote
Old 01-21-2018, 11:14 PM   #5
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Idk about you, but my clutch runs CentOS 5.
trvth (01-30-2018), Ultramaroon (01-22-2018)
Old 01-21-2018, 11:22 PM   #6
........that's for making me look that up!
Spuds (01-21-2018)
Old 01-21-2018, 11:23 PM   #7
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Spuds (01-21-2018), Ultramaroon (01-22-2018)
Old 01-21-2018, 11:29 PM   #8
Spuds
The Dictater
Spuds's Avatar
But you learned a thing today!
Old 01-21-2018, 11:57 PM   #9
Well, ya ....... but, I will forget it by bedtime ......
Like mrs humfrz says to me "every day is a new day for you, isn't it Roger".
The Following 3 Users Say Thank You to humfrz For This Useful Post:
gravitylover (01-22-2018), Spuds (01-22-2018), strat61caster (01-22-2018)
Old 01-22-2018, 12:18 AM   #10
lol
I had to read that a couple times before I snapped in. Well played.
Spuds (01-22-2018)
Old 01-22-2018, 09:18 PM   #11
brkn86
Is there anyone who has removed their clutch spring and seen any issues down the road?
Old 01-22-2018, 10:12 PM   #12
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
The roads over here in AZ have many issues, but I doubt it's because I flicked my clutch spring off the window while driving to work that day...
carsebuco is offline   Reply With Quote
Old 01-22-2018, 10:12 PM   #13
Joyride86
Joyride86's Avatar
Drives: 15 FR-S Firestorm MT
I haven't and I'm 2.5 years in.
Diode Dynamics Tail as Turn, LEDs, HIDs | Yospeed Custom Plaque and Frame | Suntek Carbon Tint | Spyder Smoked Side Markers | GrimmSpeed License Plate Relocator and Hood Struts | Five:AD Spoiler | JDM Armrest | Beat-Sonic Backup Cam | Moddiction Anvil 2 | Invidia N2 |
Joyride86 is offline   Reply With Quote
The Following User Says Thank You to Joyride86 For This Useful Post:
brkn86 (01-22-2018)
Old 01-22-2018, 10:29 PM   #14
ermax
ermax's Avatar
It does both actually. The spring expands pressing the pedal up. Then as you press down on the pedal it compresses the spring until it pivots into the other direction and then starts expanding again helping press the pedal the rest of the way to the floor. If you don't adjust the engagement point after the spring removal the pedal will droop a little. I could actually see how it could put a little pressure on the TOB. The question is, is it enough pressure to make contact with the TOB. Hmmm.
That clutch engagement adjustment could also be dangerous if people preload it too much. That would probably be worse than the spring removal itself.
Perfect solution would probably be a replacement spring that has enough force to hold the pedal up but not enough to assist (mask) the pressure plate.
I did the spring but never messed with the engagement. I kind of like it better without the spring but wasn't as blown away as some others have been. Now that I've had it removed for a while I am tempted to put it back in and see if I like it better in stock form.
The Following User Says Thank You to ermax For This Useful Post:
brkn86 (01-22-2018)
Clutch return spring removal MikeyBRZ Engine, Exhaust, Transmission 186 09-16-2020 01:40 PM
Question about the clutch spring removal btan219 Engine, Exhaust, Transmission 4 05-12-2017 09:54 PM
Clutch Spring Removal DaBoBo21 Engine, Exhaust, Transmission 6 04-10-2017 06:26 PM
How To: Clutch Spring Removal in 15 Minutes eric6 DIY (Do-It-Yourself) Guides 165 02-15-2017 12:44 AM
Clutch spring removal Sandy AUSTRALIA 4 07-22-2015 11:14 PM
