Old 01-11-2018, 02:51 PM   #869
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by BirgeyT1 View Post
Hooker has a really good turbo manifold solution too that looks like it would work on this chassis
Driver side would hit steering shaft, and the crossover tube needs to be in the front as we don't have enough room under engine/transmission to route a pipe. I also can't do a single turbo. Would need to be high 90mm or more because of my displacement. and I don't think there is even enough room for a turbo that size, not in a Daily Driver at least.
Old 01-11-2018, 03:36 PM   #870
Swift
I just Drive.
Swift's Avatar
Drives: in the womb still
Can you route crossover pipe OVER the bellhousing area. There is a LS kit for like a silverado or suburban where the turbo is housed high and near front right head.
I know you said you can't do single...
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project
Swift is offline   Reply With Quote
Old 01-11-2018, 04:37 PM   #871
DustinS
DustinS's Avatar
No, I don't think so. At least not with how far back my engine is. I was looking at possibly doing this to make 180 degree headers and even small header pipes wouldn't work.
Old 01-15-2018, 03:00 PM   #872
DustinS
DustinS's Avatar
Friend let me pull the car in his garage and do a quick check of the car. Still Slower than his FBO E85 GTR
Got the manifold off quickly:
I have a little over 6000 miles on the engine and intake ports look disgusting. The intake manifold had a significant amount of oil pooled inside of it. I need a catch can ASAP. Completely my fault as I figured I could wait while I do research on the best option for my situation. Guess I was wrong and just need to throw something on there while I research.
You can see how filthy the car is from having to park in the yard and getting rain. Too cold to wash the car . You can also see the oil pooled at the mouth of the throttle body:
Quick wipe of the intake ports, getting the valley plate off was a nightmare. One of the hex button heads stripped and I had to hammer in a larger hex socket to get it out. Took forever to do it as I didn't want to have to drill it out and retap it.
Pretty sure the shavings are from the bottom of the valley cover and were knocked loose while hammering the socket on. Still weird that there are shaving in the engine this far along I would think.
Paint on the throttle body failed as well. Going to try and tear it down to get it powder coated.
More updates on next oil change and catch can set-up to come.
Old 01-17-2018, 11:48 PM   #873
Swift
I just Drive.
Swift's Avatar
Soooooooooooo have you checked compression again? I think your ring gap is all wrong or rings situated wrong and you have significant blow by. That is ALOT of oil residue with only that many miles and hasn't the entire issue revolved around oil pressure??
I could just be tired.
Old 01-18-2018, 10:50 AM   #874
DustinS
DustinS's Avatar
I have not yet. Very good idea though. I need to look a the plugs anyway. Especially if the ports are that covered in oil. Problem being I can only get to 6 of them. I need to get a new set of headers soon. Just hard deciding if it's worth spending money on if I am going to go turbo or not.
Old 01-19-2018, 02:12 PM   #875
DustinS
DustinS's Avatar
I was going to use my catch can I had left over from the FA20, but it's huge. I instead bought a smaller one from Amazon that seems to have good reviews. Should be able to toss some stainless steel scrub pad to help with separating the oil out. Looking at ordering another one for the "Clean" side here soon. Which currently has breathers on it per what TSP recommended. The more I research, the more I see a catch can is a better direction.
Need to get some quality -6an hose and a couple more fitting so I can have a cleaner looking set-up than just rubber hose.
$35 and tossed in a few feet of rubber hose for a few dollars more. See how it does.
The Following 2 Users Say Thank You to DustinS For This Useful Post:
ILLSMOQ (01-19-2018), wooly35 (01-21-2018)
Old 01-22-2018, 10:38 AM   #876
DustinS
DustinS's Avatar
Well I did few things. Oil change and catch can install... Not good news (and possible some good news).
Everything is coated in a small even layer of very finely ground metallic dust as well.
Posted it up on facebook and instagram and tagged Texas Speed, they finally responded on how it wasn't normal. They should be contacting me today to see what happens. I am assuming they will want me to send my engine to them and if they determine they did something wrong, fix it under warranty. If they don't think it was because of them I will be presented a bill for labor and if I want them to fix it, a parts list/bill for that as well.
I also received the catch can. Built a simple mount for it out of some scrap metal bar.
Funny enough I was looking at it before the local club meeting and had some friends check to make sure the hoses didn't collapse under vacuum... They did instantly... So I put on the good rubber fuel/oil hose that won't collapse under vacuum.
Edit: Texas Speed isn't going to warranty the engine, but still want me to send it back for a tear down. Not worth the time/money to send the engine to them. I'll just either have a friend help tear it down, or have one of the LS guys here tear it down. 417 Motorsports is extremely good and seems to know Texas Speed. Owner is an acquaintance/friend as well.
Old 01-22-2018, 02:58 PM   #877
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Why are they not going to warranty the engine??
Old 01-22-2018, 03:09 PM   #878
DustinS
DustinS's Avatar
Past the 1 year warranty date. So their warranty starts on Ship date.
Old 01-22-2018, 03:17 PM   #879
gtpvette
Drives: 2015 FRS - FFR GTM
Wow that's too bad about the warranty. Without going back and looking when you posted the pictures when you got it,,,, can't of been out too long was it?? Hopefully the fix wont be too much out of pocket.
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
Old 01-22-2018, 03:26 PM   #880
DustinS
DustinS's Avatar
Received in November 2016. Installed in May 2017.
Old 01-22-2018, 03:55 PM   #881
Sportsguy83
Drives: Limited BRZ
Damn man.. sorry to hear. Any thoughts on your next steps?
Old 01-22-2018, 03:58 PM   #882
DustinS
DustinS's Avatar
Rip it out and disassemble. Triple check all the clearances to see what caused the issue to make sure it doesn't happen again. Put it all back together and hope it doesn't happen again.
The Following User Says Thank You to DustinS For This Useful Post:
Sportsguy83 (01-22-2018)
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) — General Topics 13 03-22-2016 04:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-22-2015 12:38 AM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 12:14 PM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 08:32 PM
