Old 01-06-2018, 06:51 PM   #15
Originally Posted by Strife26 View Post
I guess leave them alone is helpful but not what I was looking for.
Don't use a coin type tool was helpful.
Thanks for what you offered but I'm not looking to leave em alone. I need em to be .22.
And yes I used the gap tool to read how the were gapped. Could I be wrong sure, does that require ridicule? I guess since it's the internet. Anyways, I don't want to argue, but if you have helpful info I appreciate it otherwise I can do without.
Sent from my SM-G950U using Tapatalk
I reckon you just missed my funning with you ...... apparently black bolding of your number didn't get your attention.
Allow me to put it into works ....... since you appear to be math challenged.
You say you need the plugs to be gapped at two tenths of an inch (.22") ..... correct .. ?? I figured you meant two one hundreds of an inch (.022").
Now, if you want to know how to put almost a quarter inch of gap in those plugs ....... I can't help you ...... I don't think the electrode will reach.
Old 01-06-2018, 07:22 PM   #16
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Please help this old man out here ........
If the cylinder is charged and the valves are closed and the piston is at/near the top of its compression stroke and the spark plug fires ....... what's to "blow out the spark" ........
Spark "Blow Out" is a misnomer in most cases.
All that's usually happening is the extra air/gas in the cylinder makes it harder for the arc to jump the gap.
The pixies get sent to the plug but can't make the jump.
Thus the recommendation to make the gap smaller.
The Following 3 Users Say Thank You to x808drifter For This Useful Post:
Detroiter (01-07-2018), humfrz (01-06-2018), Strife26 (01-06-2018)
Old 01-06-2018, 07:41 PM   #17
OMG - smash them down ...... QUICK ......
Haha... right?
OP, just lean them up against something and push them down a little. Try to get them about even.
Old 01-06-2018, 08:44 PM   #18
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
oh ffs, my bad, blame my phone for being a stingy prick with the period, : P and me for assuming leaving the 0 out wouldn't matter.
My mistake if your post was meant to be "funny," I am used to "ask the forums for help," does, "you're a fkn idiot," or, "how, what, when, where..."
But then again, I am math challenged so ya, it's become one of those posts my sig refers to.
Thanks all for the help. I'm just gonna "Smash" em down and see how that goes, hopefully it all goes well.
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Strife26 is offline   Reply With Quote
The Following User Says Thank You to Strife26 For This Useful Post:
Ultramaroon (01-06-2018)
Old 01-06-2018, 08:58 PM   #19
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Somebody please give this man a hug....he needs a hug.
http://densoautoparts.com/spark-plug-installation
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
humfrz (01-06-2018)
Old 01-06-2018, 10:48 PM   #20
Oh ....... I'm sorry ....... I was just trying to make a funny .......
I should have read your sig ......
Good luck gapping your spark plugs.
Old 01-06-2018, 11:03 PM   #21
Well, I'll be darned ....... ol humfrz got some education today ......
Thanks ....... I needed that ......
Old 01-06-2018, 11:34 PM   #22
The higher the pressure the higher the breakdown voltage. (dielectric strength)
https://en.wikipedia.org/wiki/Paschen%27s_law
humfrz (01-07-2018)
Old 01-07-2018, 12:20 AM   #23
Detroiter
Detroiter's Avatar
Drives: 2014 Scion FR-S Monogram
Can confirm. What is commonly called "spark blow out" is not blow out at all.
It is extremely noticeable when it happens though. You know once you've experienced it. If it's bad enough to cause all cylinders to misfire on full boost then it will feel like you just slammed on the brakes mid pull haha definitely scary the first time it happens to you
Raven
OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap
Detroiter is offline   Reply With Quote
Old 01-07-2018, 12:26 AM   #24
Thanks, but most of that is waaaaay over my pay grade .......
Old 01-07-2018, 12:27 AM   #25
I've never seen it with a healthy ignition system. Have you ever had it with a modern one with individual coil packs? What kind of boost are we talking?
humfrz (01-07-2018)
Old 01-07-2018, 12:33 AM   #26
Detroiter
Detroiter's Avatar
Yeah that was the problem. B6 A4 with the 1.8t but running some questionable coil packs. Replaced them with new upgraded versions and had not as single problem after. It wasn't anything crazy just the max for the stock tiny turbo so around 21-22psi.
I will say that after upgrading the coil packs I was able to gap the plugs to .05 where stock was around .032 with no ill effects as the coils were far superior and provided a very good burn in each cylinder.
Raven
The Following 2 Users Say Thank You to Detroiter For This Useful Post:
humfrz (01-07-2018), Ultramaroon (01-07-2018)
Old 01-07-2018, 12:47 AM   #27
Ah! Thanks for confirming.
OP, too small a gap reduces the ignition efficiency because less molecules are heated to the point of activation energy in the combustion reaction.
Too large a gap puts a strain on the ignition coil itself. It has to do with the dielectric strength and dissipation of energy in the collapsing magnetic field set up in the coil.
But we're talking extremes here. Just get the gaps ballpark without fucking up the electrodes and you'll be golden.
Capt Spaulding (01-08-2018), humfrz (01-07-2018), x808drifter (01-08-2018)
Old 01-07-2018, 12:51 AM   #28
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
A .022 gap struck me as ridiculously narrow. Working on motorcycles in the late 60s to early 70s gaps like that were the norm because coils sucked so badly they couldn't throw a spark across any gap at all. On the original single cam Honda 750s you had to clean the plugs and narrow the plug gaps every couple of thousand miles or the engine would get a case of the blind staggers at anything over half throttle.
As the decade progressed ignition systems got better and better until by the early 80s plug gaps in the .030 to .040 range were pretty common. Memory is some got into .050 territory. Now we're back into the .020s and .030s. I thought coil-in-cap systems and iridium plugs had relegated ignition problems to the history books. Appears not.
Folks are right about using caution gapping the iridiums. Mistakes get very expensive.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following User Says Thank You to Capt Spaulding For This Useful Post:
humfrz (01-07-2018)
Spark Plugs at 65K user4815 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 50 12-25-2017 05:19 PM
Spark Plugs for turbo e85 Hags86 Forced Induction 6 09-17-2017 08:01 PM
Which model spark plugs for the FRS/BRZ? tobkin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-05-2016 06:18 PM
Spark plugs Triumphrider Engine, Exhaust, Transmission 12 06-19-2014 11:47 AM
spark plugs subaruferrucci Engine, Exhaust, Transmission 22 04-10-2013 12:24 PM
