#15 | |
Allow me to put it into works ....... since you appear to be math challenged. You say you need the plugs to be gapped at two tenths of an inch (.22") ..... correct .. ?? I figured you meant two one hundreds of an inch (.022"). Now, if you want to know how to put almost a quarter inch of gap in those plugs ....... I can't help you ...... I don't think the electrode will reach. ![]() humfrz |
#16 | |
LMGTFY
Drives: 13 FRS, 91 Miata
All that's usually happening is the extra air/gas in the cylinder makes it harder for the arc to jump the gap. The pixies get sent to the plug but can't make the jump. Thus the recommendation to make the gap smaller. |
#17 |
Haha... right?
OP, just lean them up against something and push them down a little. Try to get them about even.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Strife26 (01-06-2018) |
#18 | |
Drives: 2015 Subaru BRZ Series.blue
My mistake if your post was meant to be "funny," I am used to "ask the forums for help," does, "you're a fkn idiot," or, "how, what, when, where..." But then again, I am math challenged so ya, it's become one of those posts my sig refers to. Thanks all for the help. I'm just gonna "Smash" em down and see how that goes, hopefully it all goes well.
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks. |
| The Following User Says Thank You to Strife26 For This Useful Post: | Ultramaroon (01-06-2018) |
#19 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
Somebody please give this man a hug....he needs a hug.
http://densoautoparts.com/spark-plug-installation |
| The Following User Says Thank You to BirdTRD For This Useful Post: | humfrz (01-06-2018) |
#20 | |
![]() I should have read your sig ...... ![]() Good luck gapping your spark plugs. ![]() humfrz |
#21 | |
![]() Thanks ....... I needed that ...... humfrz |
#22 | |
https://en.wikipedia.org/wiki/Paschen%27s_law
| The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (01-07-2018) |
#23 | |
Drives: 2014 Scion FR-S Monogram
It is extremely noticeable when it happens though. You know once you've experienced it. If it's bad enough to cause all cylinders to misfire on full boost then it will feel like you just slammed on the brakes mid pull haha definitely scary the first time it happens to you
Raven OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap |
#24 | |
![]() humfrz |
#25 | |
#26 | |
I will say that after upgrading the coil packs I was able to gap the plugs to .05 where stock was around .032 with no ill effects as the coils were far superior and provided a very good burn in each cylinder.
| The Following 2 Users Say Thank You to Detroiter For This Useful Post: | humfrz (01-07-2018), Ultramaroon (01-07-2018) |
#27 | |
OP, too small a gap reduces the ignition efficiency because less molecules are heated to the point of activation energy in the combustion reaction. Too large a gap puts a strain on the ignition coil itself. It has to do with the dielectric strength and dissipation of energy in the collapsing magnetic field set up in the coil. But we're talking extremes here. Just get the gaps ballpark without fucking up the electrodes and you'll be golden.
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
#28 |
Persona Non Grata
Drives: '15 BRZ (WRB)
A .022 gap struck me as ridiculously narrow. Working on motorcycles in the late 60s to early 70s gaps like that were the norm because coils sucked so badly they couldn't throw a spark across any gap at all. On the original single cam Honda 750s you had to clean the plugs and narrow the plug gaps every couple of thousand miles or the engine would get a case of the blind staggers at anything over half throttle.
As the decade progressed ignition systems got better and better until by the early 80s plug gaps in the .030 to .040 range were pretty common. Memory is some got into .050 territory. Now we're back into the .020s and .030s. I thought coil-in-cap systems and iridium plugs had relegated ignition problems to the history books. Appears not. ![]() Folks are right about using caution gapping the iridiums. Mistakes get very expensive.
Slow is smooth, and smooth is fast
| The Following User Says Thank You to Capt Spaulding For This Useful Post: | humfrz (01-07-2018) |
| Spark Plugs at 65K | user4815 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 50 | 12-25-2017 05:19 PM |
| Spark Plugs for turbo e85 | Hags86 | Forced Induction | 6 | 09-17-2017 08:01 PM |
| Which model spark plugs for the FRS/BRZ? | tobkin | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 04-05-2016 06:18 PM |
| Spark plugs | Triumphrider | Engine, Exhaust, Transmission | 12 | 06-19-2014 11:47 AM |
| spark plugs | subaruferrucci | Engine, Exhaust, Transmission | 22 | 04-10-2013 12:24 PM |
