go_a_way1
Old 12-04-2017, 04:22 PM   #3585
GalloVecchio
GalloVecchio's Avatar
Drives: Not a BRZ
Posted a pic in GREY thread...
http://www.ft86club.com/forums/showt...=1#post3012397
GalloVecchio is offline   Reply With Quote
The Following User Says Thank You to GalloVecchio For This Useful Post:
Leonardo (12-12-2017)
Old 12-10-2017, 10:08 PM   #3586
Prodigalson
ThisGuyLoves86's
Prodigalson's Avatar
Drives: 2013 Scion FRS
Enkei PF01 17x8 +45
Firestone Firehawk Indy 500 245/40/17
TRD lowering springs (1")
OEM crash bolts in both positions
Flush? Will it rub?
2013 Scion FRS (current car)
1991 Mazda Miata MX5 (current car)
2003 Nissan Pathfinder (R50) (current car)
2018 Lexus GX460 (current car)
2023 GR86 Neptune M6 Premium (Leased)
Prodigalson is offline   Reply With Quote
Old 12-12-2017, 03:04 PM   #3587
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by Prodigalson View Post
Enkei PF01 17x8 +45
Flush? Will it rub?
The 245/40 Indy has a tread width of 8.3", and will fit on 17x8 +45 Enkei PF01 wheels nicely. They will fit without rubbing lowered on the TRD springs.
Adding both bolts may add enough camber to have the tire touch the strut. You may have to add a spacer to add both bolts. (I have read here that -2.5 camber is possible with both bolts)
As for flush: An 8" wheel with a +35 offset is generally considered flush.
I LIKE TIRES!
Prodigalson (12-29-2017)
Old 12-15-2017, 08:52 PM   #3588
Grisha
Grisha's Avatar
Drives: '13 FRS
Lightbulb
Cheers, FRS/BRZ owners!
I'm looking to buy a set of wheels before the spring comes here in the Northeast. I'm looking at the setup 8.5 +30 in the front, 9.5 +35 in the back. I'm not lowering it.
Will 245/35/18 (front) & 265/35/18 (rear) fit with no issues?
If not, what tire size should I go with?
Thank you!
Grisha is offline   Reply With Quote
Old 12-15-2017, 10:34 PM   #3589
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Thank you!
Welcome to the Forum.
It looks like your wheels will poke approx 0.6 inches front and rear. The 265 is going to rub also.
To make these fit, you will need some or all of these: Narrower tires, coilovers, camber bolts, tophats, and LCA. (Parts are for camber, you can use them at stock-ish ride height)
GOOD LUCK!
The meaty tire thread is Mandatory reading for those that want a 265.
http://www.ft86club.com/forums/showthread.php?t=41083
I LIKE TIRES!
Old 12-15-2017, 10:39 PM   #3590
Grisha
Grisha's Avatar
Drives: '13 FRS
GOOD LUCK!
Thank you for the reply!
What's the widest tire I can run on this setup w/o lowering it and messing with camber?
Old 12-15-2017, 11:24 PM   #3591
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Read post 213, 214, & 219. Looks like with that offset for the rear a 245 would be maxed out. So 225/40 front. The stretch will be very similar front and rear. They will poke.
http://www.ft86club.com/forums/showt...=28017&page=16
Here is a 18x8.5 +30 He has a 235/40.
http://www.ft86club.com/forums/showthread.php?t=44291
A 225/40 has a larger diameter than the 245/35. Going up to a 235/40, especially without lowering will make the wheel gap look different front and rear. My best advice: Read the meaty tire thread.
I LIKE TIRES!
Old 12-16-2017, 01:15 AM   #3592
Grisha
Grisha's Avatar
Drives: '13 FRS
Thanks and all the best to you!
Happy Holidays!
The Following User Says Thank You to Grisha For This Useful Post:
Leonardo (12-16-2017)
Old 12-21-2017, 01:18 AM   #3593
Grisha
Grisha's Avatar
Drives: '13 FRS
Leonardo, after long hours of research I decided to go with 18x9.5 +38 square setup. I'll be running stock height for now, so can you help me decide between 245/35/18 and 245/40/18? There'a guy running the same setup that I'm going for: http://www.ft86club.com/forums/showp...1&postcount=89
Thank you and happy holidays again
Old 12-21-2017, 01:45 PM   #3594
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I have 245/35/18 MPSS. I went with them because, they are the correct diameter, weigh 2lbs less than a 245/40, and have a larger contact patch.
I know Michelins are expensive, and that the 245/35 can cost more than a 245/40, but right now on Tirerack, they have Ventus Evo 12's for 150 each. (not bad )
I understand that if you are not going to lower you car, that you may want a taller tire to "eat up" some of the gap. If this is your logic, then go for the taller heavier tire. Most guys eventually lower their cars though...
Happy holidays! Glad I can help.
I LIKE TIRES!
Old 12-26-2017, 10:57 PM   #3595
LatentWagen
Drives: '17 BRZ / CBS + PP
On my Legacy I ran a set of SSR Comps in 17x8.5 +48, 245/40 MPSS. Will they fit my BRZ without too much fuss? Stock performance pack suspension for now, but planning on dropping the car with a set of RCE Yellows, or maybe another set of RCE/KW coilovers, which were amazing on the BD chassis.
I'm also sitting on a set of SSR Type-C RS's in 17X8.0 +35, maybe better to stagger?
LatentWagen is offline   Reply With Quote
Old 12-27-2017, 02:03 PM   #3596
Leonardo
Country Boy 4 Life
Leonardo's Avatar
First of all... Welcome to the Forum!
Second, I am stoked for you that you already have two sets of wheels that will fit.
Your 17x8.5's are rare. Anyway, 17x9 is popular. A 17x9 +45 is very close (2mm to 4mm) to the stock strut and spring, especially with a 245/40 tire. Your 17x8.5 +48 wheels should be 3.4 mm farther away from the spring perch. Try them on your BRZ and post some pics!
No clearance issues at all with the 17x8 +35 wheels.
I would get a set of camber bolts for the front. They are inexpensive.
RCE springs work well with the stock struts and get great reviews.
This is a great tool for looking at how wheels and tires compare.
http://www.willtheyfit.com/
GOOD LUCK!
I LIKE TIRES!
Old 12-27-2017, 07:44 PM   #3597
LatentWagen
GOOD LUCK!
Leonardo, thanks for the reply! And the advice, already got some bits on the way to address camber. Will definitely post up pics when I'm brave enough to break out the setup. Freezing temps now here in NY. Maybe I'll give in to temptation on a warm day tho.
And yes the by 8.5s are pretty hard to come by. I know because I searched for a while! Always been a big fan of the Comps and Type-Cs, also had sets on my 2.5 RS Coupe (16x7), and my bugeye WRX wagon (17x7.5). IMO they're as classic and simple a wheel as you can get but still look great on most cars. They also happen to be 14lbs a piece in 17x8.5, which is nice
The Following User Says Thank You to LatentWagen For This Useful Post:
Leonardo (12-27-2017)
Old 12-27-2017, 09:14 PM   #3598
DarkSideFRS
Drives: 2013 pearl white FR-S
i am lowered on TRD springs with -1.7F and -1.3R camber... would i rub on 17x9 +38 rims on 245/40/17?
DarkSideFRS is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
