Old 12-27-2017, 12:11 PM   #29
gtengr
Drives: 2017 BRZ
Originally Posted by Grady View Post
For me $500 on a $5k to $6k expense is negligible. Jackson racing kit $4k, I received a ok deal on an AVO kit $4.5K.
I think this is where our opinions diverge, because I can confidently say without looking at the parts list that I would not be getting everything that "I" would want in a turbo kit at $4.5k. When I priced the turbo option with all the accessories I'd need, it came out to ~$7500. I agree the cost difference isn't necessarily big enough to be a deal breaker, but it is more expensive.
Anyway all of them would be fun they are forced induction! For me the turbo brings a more reliable platoform. To each his own this is why we have such great choices for this car. What other car do you have this many options for forced induction? It makes it hard to decide.
Agreed. It's great to have so many options. I prefer a lot of things about turbos, but the stock rod weakness, along with the Edelbrock and CS400 being able to get me near where I think the safe limit is, has me leaning away from turbos. It would be another story if I was looking forward to building the engine some day.
gtengr is offline   Reply With Quote
The Following User Says Thank You to gtengr For This Useful Post:
CSG Mike (12-27-2017)
Old 12-27-2017, 02:16 PM   #30
bfrank1972
Drives: 2013 FR-S Argento
As long as you keep the boost levels sane (i.e. 7-10 psi for a base kit), I would think a turbo would be more friendly to stock rods than a supercharger kit, unless you're absolutely lugging/loading up the turbo at low rpm in higher gears (which is just begging for problems). Consider flooring a car at 4000 rpm in 2nd gear (with sticky tires) - superchargers and their instant response could provide a much higher instant load on the stock rods than any turbo kit.
Also I'm somewhat wary of the Rotrex kits - the number of failures (regardless of kit manufacturer) of the Rotex units is not insignificant. May be due to incorrect priming or belt tension, not sure, but the failures are there. If you have warranty coverage, your car is out of commission for weeks. If you don't have warranty coverage, you're out $1500-$2000. On the other hand, take a basic SBD kit, they sell for <$3000, add $1000 in protective goodies, and if that turbo fails it's no where near as expensive to replace as a rotrex units. Maybe the Vortech units/Eaton/Sprintex units are more reliable, don't know much about their track records.
They both have their reliability issues, any FI is a risk. End of the day, I decided my car with tune & header is quick enough
Old 12-27-2017, 03:37 PM   #31
WORKS
WORKS's Avatar
Drives: WORKS CARB Legal Turbo BRZ
Turbo ... but we're biased
Has anyone logged their fuel consumption before and after their FI swap?
WORKS is offline   Reply With Quote
Old 12-27-2017, 03:48 PM   #32
CSG Mike
CSG Mike's Avatar
SC's are friendlier to the rods; less torque at low rpm.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
gtengr (12-27-2017), nos145 (01-13-2018), Teseo (01-01-2018)
Old 12-27-2017, 04:14 PM   #33
gtengr
Drives: 2017 BRZ
I don't think there's evidence to back that up as a concern, especially not with centri's that are only generating a few psi anyway at that rpm. Throttle tip in programming can control this if it's a problem.
I agree on the Rotrex units. Turbos leak and fail too though. I would not expect the turbo in a $3k kit to outlast an Eaton TVS.
Old 12-27-2017, 06:33 PM   #34
bfrank1972
At that point I'd consider the turbo (fairly easily replaced) as a maintenance item
Old 12-27-2017, 07:35 PM   #35
Grady
Grady's Avatar
I would say that at the same PSI/temp supercharger or turbo the stress is the same on the engine. You will see less torque at the wheels of a supercharged engine but that is because some of the torque is going out the front of the engine to run the supercharger. But the engine stress is the same.
The Following 2 Users Say Thank You to Grady For This Useful Post:
CSG Mike (12-27-2017), Teseo (01-03-2018)
Old 12-31-2017, 07:14 PM   #36
shr133
shr133's Avatar
Drives: 2013 FRS
I'm still going over this, but I think I'm going with an edelbrock supercharger because I want instant torque and low maintenance. This is my summer daily and a supercharger is easy to set up and very low maintenance for the HP I want. I want to make a max of 350-400 on E85. I think over 400HP you start to break a lot of parts. To get over 400HP a turbo may be a better choice. A supercharger offer an easy set amount of power. A turbo is way easier to add boost and power but over 400 HP will probably need a engine rebuild and you are dealing with a lot of heat with a turbo and becomes higher maintenance. With turbos you also have to find a kit that makes the power where you want it.. But a turbo is great if you like to tune, change from 5,10,15lbs of boost just by changing maps. A supercharger you have to change pulleys but is only effective to a point. I'm going with a supercharger if the stock engine and car could safely hold 500HP I would get a turbo but it's personal choice you can get a turbo to almost replicate a supercharger with more available top end....
Enkei TS9 18 X 8, Michelin Sport 4S 225 40 18, Flex Fuel, Edelbrock Supercharger, P & L header, Nameless front pipe, V1 cat back, Aluminum Driveshaft, pvc delete, med duck bill, KW V3, Whiteline 20 and 18 mm bars, Buddy Club and SPL control arms, Toe Arms, motor and trans mounts, Whiteline bushings, SHR stage II tune.
shr133 is offline   Reply With Quote
The Following User Says Thank You to shr133 For This Useful Post:
nos145 (01-13-2018)
Old 01-01-2018, 03:55 PM   #37
mjanmohammad
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
I'll be doing this! I've been using the Fuelly app since I bought my car last year, and ordered a JDL kit recently.
mjanmohammad is offline   Reply With Quote
Old 01-01-2018, 06:53 PM   #38
gtengr
Drives: 2017 BRZ
Since the turbo is an exhaust restriction, I think the supercharger makes slightly more power in the cylinder (at same efficiency, psi, etc). Agree the turbo should put more to the wheels.
Old 01-02-2018, 07:58 AM   #39
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I have the SBD and so do a few guys here in Atlanta and I know some guys personally who have driven 55-60k miles without turbo or engine failure on a "supposedly" cheap turbo.
SUB-FT86 is offline   Reply With Quote
Old 01-02-2018, 11:19 AM   #40
86Tony
Drives: 2015 AOZORA EDITION
Turbo all the way, i started off with a c38 rotrex it was nice but it wasnt all that, tbh i never felt like the car was boosted it just feels na and you have to rip it to feel the power. I then switch to Ptuning with gen 2 gtx2867r i dont think i can recommend superchargers anymore with the turbo power is still linear and still pulls all the way up to redline. All that turbo noises that low end and mid range tq is fuckin awsome. Rotrex setup i made 277whp 200wtq at 8 psi with my gtx2867r i made 323whp 271wtq at 9 psi
86Tony is offline   Reply With Quote
Old 01-02-2018, 12:12 PM   #41
StraightOuttaCanadaEh
Wes
How long have you been turboed for?
Instagram: @gt86ws
Old 01-02-2018, 12:46 PM   #42
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
That's a pretty big bump in power, and nicely sized on the GTX28. Good choice and numbers.
I think a well-tuned and sized turbo setup can be VERY linear and nice. I think the supercharger was doing it's job for someone who wanted linear power with those power goals, but for someone who wanted more power, the Ptuning kit is wicked.
Edit: What header are you running? I'm curious because it makes zero sense to use the stock header to me, being that there's a pre-turbo cat.
JazzleSAURUS is offline   Reply With Quote
installing a supercharge kennyd8606 Forced Induction 20 08-12-2016 03:09 PM
Turbocharge vs. Supercharge vs. None Cojonudo Forced Induction 39 12-23-2015 07:20 AM
Can't decide (new to car mods) turbo or supercharge Mikeez Forced Induction 89 06-17-2014 05:06 PM
Unnecessary Boost needed (Turbo or Supercharge) Nickse30 Forced Induction 32 05-27-2013 01:57 PM
if going FI, would you turbocharge or supercharge? tibsy92 AUSTRALIA 35 08-18-2012 11:02 PM
