#43 | |
Drives: 2013 Scion FR-S Asphalt [Gray]
| The Following User Says Thank You to TorontoNat For This Useful Post: | ILLSMOQ (12-20-2017) |
#44 | |
Only users lose drugs.
Drives: All the time
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#45 | |
Drives: 2017 WR BLUE BRZ
These are aluminum |
#46 | |
Also strength and rigidity are not synonymous. |
#47 |
Any increase is marginal at best and actually counter effective at worst.
#48 |
Show your work.
#49 |
Don't have to show anything. Unless you are mounting the cage directly to your suspension points there is little to be gained. Bolting a cage onto the floor supports of the car just allows the cage itself to flex. As strong as it may seem there is still some substantial deflection over several feet of tubing. In order to deal with that deflection you would need several cross braces high up in the cage. This adds weight and raises the COG to a point where any advantage in rigidity is negated. If the cage is too heavy it can actually cause flex at the body mounting points.
It seems counter intuitive unless you look at the big picture.
#50 |
Adding a cage can undo the work put into chassis design to intentionally permit and accommodate flex. Safety gained at the expense of performance.
| The Following User Says Thank You to venturaII For This Useful Post: | Tcoat (12-21-2017) |
#51 | |
They serve a great purpose when racing and are used with all the other proper equipment but boy racers like them in street cars (that never, ever will see a track) so they can play racecar and pretend to be cool.
#52 |
lol.
Ok boys. Who anchors their cage to the floor? |
#53 |
Most of the pretenders.
I did not say directly to the floor now did I?
#54 | |
#55 | |
My guess is neither of you have ever measured torsional rigidity before and after a proper cage install, and are talking out of your asses.
#56 | |
A proper cage install in a well engineered, dedicated racecar is a rare thing. We are talking about slapping something into a modified street car. The effect is not going to be the same. To say that "A cage will most DEFINITELY increase rigidity, and likely by a fair margin" is not a catch all nor accurate statement by any means.
| HELP: Spoon Front Subframe Rigid Collar Install | nichiolas | DIY (Do-It-Yourself) Guides | 1 | 12-25-2016 07:44 AM |
| SPOON rigid collars install | mokinbird87 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 137 | 11-16-2015 03:24 PM |
| Rigid Collars? | Calum | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 28 | 11-04-2015 01:38 AM |
| New Rigid Industries Capture LED Light w/ Built in GoPro could be sweet for the track | 86_Insider | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 07-02-2015 07:53 PM |
