Old 12-21-2017, 09:47 AM   #15
fika84
fika84's Avatar
One purpose of a flywheel is to smooth out the engine pulses. The lighter the flywheel the rougher the engine feels, especially at lower speeds. Usually, engines with fewer cylinders need larger (heavier) flywheels.
Check the flywheel on the side of this two banger pow-pow JD tractor ......
OK, I'm done ............
Believe it or not, I saw one of these do a tractor pull this past October! Cider Days in Colorado baby!
fika84 is offline   Reply With Quote
The Following User Says Thank You to fika84 For This Useful Post:
humfrz (12-21-2017)
Old 12-21-2017, 09:48 AM   #16
Icecreamtruk
Drives: Track preped NA FRS
I changed my stock flywheel with a 11lbs one. I was expecting this to become a nightmare to daily but I was doing it for the easier/faster revmatching. I will tell you right now, that if you dont lurch the car with the stock flywheel, you wont with lightweight one, its not as bad as people make it out to be, and boy does it feel good when rowing thru gears up or down.
Icecreamtruk is offline   Reply With Quote
The Following User Says Thank You to Icecreamtruk For This Useful Post:
venturaII (12-21-2017)
Old 12-21-2017, 09:56 AM   #17
I put a light weight flywheel in my 91 Talon TSI. I very quickly removed the light weight flywheel from my 91 Talon TSI. I am firmly in the camp of it is more of a pain for a DD than it is worth. It was very nice to bring the revs up fast but it totally sucked at maintaining them as soon as you let off the gas.
Old 12-21-2017, 10:21 AM   #18
RallySTI
Drives: 2013 Subaru BRZ
Originally Posted by RickyRacer View Post
TOB is done on my car
While I'm fixing it, I bought a brand new clutch and wondering if this lightweight flywheel is compatible with the OE clutch
They are both made by exedy
Can confirm.
The TF02 will work with the original clutch and the FJK1005 OE replacement from EXEDY. The TF02 has the same dimensions as the OE flywheel.
RallySTI is offline   Reply With Quote
Old 12-21-2017, 11:08 AM   #19
ermax
ermax's Avatar
I’ve read negative reviews about light flywheels on every car I’ve ever put one on yet I did it anyways and never regretted it and never found them that hard to deal with. Your revs do go up and down quicker so your timing needs to change but it takes no time at all to adjust. I’ve never had problems with stalling either. I plan to do a flywheel on my FRS when it’s time to do the clutch.
The Following 2 Users Say Thank You to ermax For This Useful Post:
fika84 (12-21-2017), venturaII (12-21-2017)
Old 12-21-2017, 11:48 AM   #20
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
Originally Posted by fika84 View Post
Oooh @Ultramaroon it's not that bad! The stock flywheel is 28 lbs!
I put a 13lb flywheel in at 3000 miles and have driven it for 32k. You do need to get a little used to the needing to rev slightly higher from a stop to get going, but as long as you have good throttle control it's fine. Idle and other things are not bad at all. Totally tolerable. I'm also at a mile high elevation.
The best additional mod that leveled all of this out was a 4.88 FD. Made everything feel more like "stock", except quicker all around.
Really in the end it depends on OP's future goals and mods. It's always good to have a "vision" of what you want your car to be and how you want it to act.
Funny you mention that because my next mod is the Cusco 4.56 FD
RickyRacer is offline   Reply With Quote
Old 12-21-2017, 11:50 AM   #21
fika84
fika84's Avatar
They compliment each other very well
Then you add full exhaust and a tune and you'll be very happy.
Old 12-21-2017, 12:25 PM   #22
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I'm doing the opposite. I'm going to be removing my lightweight ACT flywheel and going back to stock flywheel with a performance clutch (South Bend Clutch Stage 2). I don't care for the ACT clutch.
Old 12-21-2017, 12:29 PM   #23
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
do you need a tune in order for the flywheel to idle and rev correctly in low rpms
Old 12-21-2017, 12:48 PM   #24
Now THAT brings on a back-in-the-day story.
It was a hot day in August at the Clinton County, Ohio fairgrounds. My grandfather had taken me to the fair and we stopped to watch the tractor pull contest. Now, this was back when the tractors were just stock farm tractors.
At the finals, this "pow-pow" John Deere tractor hooked up to the sled and started off ..... pow-pow-pow-pow. As the weight was increased it went pow...pow...pow. Just when we thought it was all done ....... it let out one more POW ...... and won the contest.
Bonus side story. Guess what they used to drag the sled back to the start line..?? Yep, a 50 year old steam tractor ....... with the throttle barely cracked .......
THE END
chaoskaze (12-21-2017), fika84 (12-21-2017)
Old 12-21-2017, 01:08 PM   #25
OP needed to hear both sides of the argument and I knew you guys would jump my shit in a New York minute. As long as he understands that there are real trade-offs, my work here is done.
fika84 (12-21-2017), Sapphireho (12-21-2017)
Old 12-21-2017, 01:17 PM   #26
fika84
fika84's Avatar
Nope, doesn't need anything special. Just bolt that bad boy on and go.
Old 12-21-2017, 01:19 PM   #27
Originally Posted by churchx View Post
humfrz: i wonder if i can retrofit those rear wheels of tractor in pic. Will i need to roll fenders and increase camber to not rub?
Such wheels may certainly reduce spending on tires!
Well, if you do, be sure to order them with the racing cleats.
Yep, they are great for off road ...... but they ride a bit harsh on pavement .....
Old 12-21-2017, 02:02 PM   #28
RallySTI
My opinion is that a LWFW is a mod that you will notice for the first month or so you drive and as time goes on your become familiar and the affects are not as noticeable.
The Following User Says Thank You to RallySTI For This Useful Post:
OEM Clutch And Flywheel with 14k. nickmerronesucks Transmission and Driveline 15 10-22-2015 04:57 PM
WTB OEM clutch and flywheel Opposed Want-To-Buy Requests 5 08-08-2014 01:47 AM
Competition Clutch Stage 3 clutch and flywheel, who has one and what do you think? OICU812 Engine, Exhaust, Transmission 2 05-17-2014 01:56 AM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
