Old 12-20-2017, 05:06 PM   #1
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
Will this flywheel work with OEM clutch?
TOB is done on my car
While I'm fixing it, I bought a brand new clutch and wondering if this lightweight flywheel is compatible with the OE clutch
They are both made by exedy
RickyRacer is offline   Reply With Quote
Old 12-20-2017, 05:50 PM   #2
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
http://www.lmperformance.com/856993/...2013-2016.html
The flywheel
Old 12-20-2017, 06:50 PM   #3
humfrz
I don't see why not ....... but, I would suggest you contact Exedy and ask them ......
humfrz
Zentec (12-22-2017)
Old 12-20-2017, 07:53 PM   #4
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
humfrz
thanks i will check with them tomorrow.
I'm surprised there aren't more reviews of people installing LWFWs on this car... can't weight to have this one on...hopefully... if it fits
Old 12-20-2017, 09:54 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
If you daily your car, I bet you lunch you'll grow to hate it within a month.
Old 12-20-2017, 10:38 PM   #6
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
So true. Keep stock flywheel.
Old 12-20-2017, 11:00 PM   #7
JoeC
Drives: Subaru BRZ Limited
just curious, why? what difference does it make in the drive-ability?
JoeC is offline   Reply With Quote
Old 12-20-2017, 11:11 PM   #8
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Lot of shudder.
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
JoeC (12-21-2017), Teseo (12-22-2017), Ultramaroon (12-20-2017)
Old 12-20-2017, 11:19 PM   #9
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
It's easier to stall or slip the clutch, you need to have more precise clutching ability. That said I had zero issues daily driving a '90 Integra RS with an 8lb ACT prolite racing flywheel, actually liked it much better than stock, way more responsive to throttle input. Also depowered /unvalved the steering rack and put in a smaller diameter steering wheel... wasn't an ideal daily driver but was fun and quick in response! Plan to put a TRD lightweight flyweel in my FR-S soon, TOB is starting to complain more these days...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following 5 Users Say Thank You to Vracer111 For This Useful Post:
chaoskaze (12-21-2017), JoeC (12-21-2017), Teseo (12-22-2017), Ultramaroon (12-20-2017), Zentec (12-22-2017)
Old 12-20-2017, 11:49 PM   #10
Ultramaroon
not playing cards
The stock flywheel is already as light as reasonably possible. Firing pulses are clearly felt well past 2000 RPM. That's not trivial. Lightening the flywheel increases that effect, making idle rougher and low speed operation more annoying than it already is.
I would love to have a sharp responsive powerplant that feels like a straight-4 liter bike but that's just not what this engine does well.
Read all this as my opinion. I've considered, and talked myself out of a light flywheel many times.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post:
chaoskaze (12-21-2017), JoeC (12-21-2017), Teseo (12-22-2017), Zentec (12-22-2017)
Old 12-21-2017, 12:15 AM   #11
humfrz
One purpose of a flywheel is to smooth out the engine pulses. The lighter the flywheel the rougher the engine feels, especially at lower speeds. Usually, engines with fewer cylinders need larger (heavier) flywheels.
Check the flywheel on the side of this two banger pow-pow JD tractor ......
OK, I'm done ............
humfrz
JoeC (12-21-2017), Zentec (12-22-2017)
Old 12-21-2017, 03:51 AM   #12
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Wink
Thank you Ultra, for getting rid of the idea of me getting a light weight flywheel in the future.
Backed with real reason, understanding & experience.
The Following 3 Users Say Thank You to chaoskaze For This Useful Post:
Teseo (12-22-2017), Ultramaroon (12-21-2017), Zentec (12-22-2017)
Old 12-21-2017, 05:27 AM   #13
churchx
churchx's Avatar
Drives: 2014 GT86
humfrz: i wonder if i can retrofit those rear wheels of tractor in pic. Will i need to roll fenders and increase camber to not rub?
Such wheels may certainly reduce spending on tires!
The Following User Says Thank You to churchx For This Useful Post:
humfrz (12-21-2017)
Old 12-21-2017, 09:45 AM   #14
fika84
fika84's Avatar
Oooh @Ultramaroon it's not that bad! The stock flywheel is 28 lbs!
I put a 13lb flywheel in at 3000 miles and have driven it for 32k. You do need to get a little used to the needing to rev slightly higher from a stop to get going, but as long as you have good throttle control it's fine. Idle and other things are not bad at all. Totally tolerable. I'm also at a mile high elevation.
The best additional mod that leveled all of this out was a 4.88 FD. Made everything feel more like "stock", except quicker all around.
Really in the end it depends on OP's future goals and mods. It's always good to have a "vision" of what you want your car to be and how you want it to act.
fika84 is offline   Reply With Quote
The Following 2 Users Say Thank You to fika84 For This Useful Post:
Ultramaroon (12-21-2017), venturaII (12-21-2017)
OEM Clutch And Flywheel with 14k. nickmerronesucks Transmission and Driveline 15 10-22-2015 04:57 PM
WTB OEM clutch and flywheel Opposed Want-To-Buy Requests 5 08-08-2014 01:47 AM
Competition Clutch Stage 3 clutch and flywheel, who has one and what do you think? OICU812 Engine, Exhaust, Transmission 2 05-17-2014 01:56 AM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
