Old 12-20-2017, 08:38 PM   #1
eddwvrd
Drives: Frs
Suggestions on mud flaps
Whats the difference between the Rally Armor and Rokblokz? I havent seen any post about rokblokz but im thinking of trying them on. Also what do you guy think is the better colorway for mud flaps in my frs? Red mud flap/black logo or black mud flap/red logo??
eddwvrd is offline   Reply With Quote
Old 12-20-2017, 08:48 PM   #2
TommyW
TommyW's Avatar
Drives: '13 Whiteout
IMO no mud flaps are the best choice.
TommyW is offline   Reply With Quote
The Following User Says Thank You to TommyW For This Useful Post:
STV3 (12-21-2017)
Old 12-20-2017, 09:00 PM   #3
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
The main difference is that RallyArmor flaps are floppy, and more of a "rally style" flap. Rokblokz (or the ones I have, which are GORILLA brand) are stiff plastic that doesn't flap around. The larger RallyArmor flaps make sense for an off-road vehicle, but I think they look silly on our cars. Also, the RallyArmor flaps mount using an additional bracket, and I don't like that mounting method. The GORILLA rock guards bolt right into the fender well (into existing holes) and it's a cleaner, simpler, sturdier install, IMHO.
A lot of people think they're just a style thing. I did NOT install them for style reasons. I installed them because I wanted to protect the paint on the side of the car from rocks. When you upgrade to a 9" wheel, lower the car slightly, and put a few degrees of camber on it, the bottom of the wheel is much further out. Then put sticky Michelin Pilot Super Sports on the car, and rocks start to be flung into the body work. I also autocross the car with RE71Rs, and those basically sandblast the car.
These are the ones I purchased. I wound up trimming about 3/4" off the bottom of them because I was barely scraping them on the ground during the more violent transitions in autocross. Rokblokz sells a "shortie" version but they are TOO short for my tastes and looked weird since they didn't even clear the bottom of the rocker panel.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post:
tfp (04-04-2018), TofuJoe (12-21-2017)
Old 12-20-2017, 09:22 PM   #4
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Yep, but some of these Subaru guys are into ugly.
dnieves (12-20-2017)
Old 12-20-2017, 09:46 PM   #5
Stang70Fastback
A.K.A. Starlord
And some others are into function over form
Old 12-20-2017, 10:00 PM   #6
Sapphireho
Famous Potatoes
Sapphireho's Avatar
So do you rally on dirt roads, or is there lots of debris with snow in illinois? I have 8 inch wide rims and only drive on paved roads with mpss and have never had an issue with scratches, but where you drive might be different.
So sorry.
Old 12-20-2017, 10:19 PM   #7
Stang70Fastback
A.K.A. Starlord
So sorry.
I autocross my car for starters. That means putting tires on the car that just make endless sounds of gravel hitting the inside of your fenders as you drive around, and LOTS of gravel being thrown up from surfaces that aren't anywhere near as clean as public roads. As it stands, I get gravel being flung INTO my car even WITH the flaps. I've literally been hit (painfully) in the face by pieces of gravel that bounced off of the mirror or window opening and into the car. I also drive in the winter, and they salt the crap out of the roads here, which means kicking up giant chunks of rock salt everywhere.
Here's what my car looks like from the front under heavy braking on my autocross setup. Note how far out the tires protrude from the body work at the bottom
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Asidrive (05-04-2018)
Old 12-20-2017, 10:33 PM   #8
NRXRaptor
Because the rally armors are softer, they wont rip out mounting hardware if you back up over a low bump. Some guy on youtube with a wrx had this happen to him: mudflap torn off and hardware in place. He contacted rally armor and he bought a new flap or a whole new set of flaps instead of a whole new kit, I can't remember. I plan on making my car lower in the future and so I went with rally armor
NRXRaptor is offline   Reply With Quote
Old 12-20-2017, 10:33 PM   #9
How about OEM mud flaps ....... black with no logo ........
Busybee (06-20-2022)
Old 12-20-2017, 10:41 PM   #10
Stang70Fastback
A.K.A. Starlord
I'm not a huge fan of OEM flaps for three reasons:
1. They tend to be less robust against abuse (because they are a complex shape, they are more easily damaged if you drive over an object that they don't clear.) Then again, the OEM flaps for the BRZ are much shorter, so this is likely to be much less of an issue than it was on my old Outback.
2. The wrap-around design is nice and streamlined, but it wears on the clear-coat of the car and can permanently damage it over time.
3. They won't fit with most (any?) aftermarket side skirts without some modifications.
humfrz (12-20-2017), lantsalot (01-03-2018)
Old 12-20-2017, 10:41 PM   #11
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Sounds like you need peterbuilt flaps.
Either way, form of function, they are very ugly on a twin.
Old 12-20-2017, 10:49 PM   #12
Stang70Fastback
A.K.A. Starlord
Meh. I don't think they really stand out enough to ruin the look of the car. They're matte black, so most of the time you don't really notice them unless you're looking for them. They aren't like the giant, shiny, colored RallyArmor flaps, which I also find a bit overbearing. To each their own, though
tfp (04-13-2018)
Old 12-20-2017, 10:58 PM   #13
Good points.
1. I don't "plan" on going off road ......
2. I figure "I'll" be worn out before the clear coat is ......
3. I have no plans for side skirts ...... I used to chase "skirts" but not any more .......
I usually don't like any kind of mud flaps, but I find the OEM mud flaps on my 2013 FR-S don't look all bad ....... or I just got used to them ......
Sapphireho (12-21-2017), Stang70Fastback (12-20-2017)
Old 12-20-2017, 11:21 PM   #14
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
If you plan on lowering your car later in the future, I'd recommend Rallyarmor as they're flexible. I'm currently lowered and running RA and while the flaps do scrape (no actual damage), they won't tear off like the Rokbloks.
Personally I run mud flaps because when I lead my friends through some spirited driving roads I used to throw a spray of rocks at them due to my sticky tires. I felt really bad one time after I hit one of them in the face... twice... on the same drive lol.
As for color I'd say go with something low key like the black with red lettering.
tyler_win_photo is offline   Reply With Quote
WTB: OEM mud flaps Decimus Want-To-Buy Requests 4 02-03-2015 08:45 PM
Rally Mud Flaps or Stock Mud Flaps + Rear Spats 914_WHITE_FRS Cosmetic Modification (Interior/Exterior/Lighting) 2 01-05-2014 09:09 PM
Fs: FR-S OEM Mud flaps ucsmfu Interior Parts (Incl. Lighting) 1 11-24-2013 08:37 PM
Mud Flaps DIY? Jertronic DIY (Do-It-Yourself) Guides 16 10-13-2013 04:58 PM
Mud flaps Kev01 AFRICA 43 04-13-2013 05:32 PM
