Softer Ride
I've got 2013 FRS and the suspension is extremely stiff for me, specially with shitty roads we have in Toronto.
What is the best solution to make the ride softer and comfortable? I've looked around this forum but can't seem to find the answer I am looking for. If I change the springs would that help or I need to get coilovers? I'm not racing or anything like that, just city/highway driving. Thanks! |
#2 |
Drives: '13 FRS - STX
How many miles on the car?
#3 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
You could try getting a pair of the newer 17 dampers and springs. Or if you're lucky get a hold of some of the performance package Sachs dampers too.
#4 |
16" wheels shod with some comfy all-season radials.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | new2subaru (06-20-2018) |
#5 |
#6 |
#7 |
| The Following User Says Thank You to PVLFD For This Useful Post: | Ultramaroon (12-08-2017) |
#8 | |
Sidewalls on the Primacys are super stiff.
#9 |
I don't see why they wouldn't!
#10 |
#11 |
You could try cheap coilovers. But I wouldn't do it.
#12 |
Loading...████████] 99%
Drives: #0517
You will not likely find something in your stated budget of $300-$400 to make this car more comfortable. The easiest way would be to sacrifice some performance for tires with a bigger/softer sidewall or go with something like the Chuhatsu lift springs, but I'm not sure if a lift in ride height is what you're particularly looking for.
Did you find the ride to be more comfortable when the car was new? If so, then maybe just looking for a lightly used/low milage set of OEM springs/dampers from a newer model year car will help get you back to a more comfortable ride.
R1 3 5
╘┼┼┤ . 2 4 6 |
#13 | |
With this one I can feel every small pothole. I've seen aftermarket springs, most of them are under $400. Does that make a difference in ride quality or shocks is what I need? |
#14 | |
Drives: #0517
There are a ton of aftermarket spring options out there if you want to lower the car, but since you're looking for some comfort, you won't find it there, especially pairing up with your OEM dampers... You may be surprised how much of a difference a softer tire will make. If you're set on trying to change the suspension: If you have local meets, you can try to see if anybody that has a different suspension setup can give you a ride-along or let you test drive (maybe if you offer a 6pack or lunch or something). Or maybe you can stop by a local dealership to test drive a new stock 86/BRZ to see if finding a less worn set of OEM springs/shocks will do the trick. I will say, I very much doubt any aftermarket springs paired with your OEM dampers will net the result you seem to be looking for. Good luck in your search!
R1 3 5
╘┼┼┤ . 2 4 6 |
| The Following User Says Thank You to asdf For This Useful Post: | wparsons (12-08-2017) |
| Is the BRZ Windshield softer than other glass? | Meatstreak | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 20 | 09-05-2016 04:58 AM |
| Something softer than sportlines | encity5 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 03-01-2015 03:22 PM |
| clutch/gear box getting softer | zERoTu | Issues | Warranty | Recalls / TSB | 3 | 06-05-2014 09:18 AM |
| For those who ride, there's a group ride happening tomorrow if you're interested. | Yamaha_R6 | Northwest | 3 | 03-07-2014 10:32 PM |
| What's your other ride, winter ride etc. | wtout86 | Other Vehicles & General Automotive Discussions | 13 | 12-07-2012 01:36 AM |
