Old 12-07-2017, 03:30 PM   #1
GTone
Drives: 2014 Scion FR-S
Need advice for a suspension fix.
Guys,
Had a small front end collision on my 2014 FRS and insurance replaced everything, but ride feels rougher and bouncier than before so I want to try to upgrade the suspension in an attempt to fix it. Have had a couple alignments done so that shouldn't be the problem. Car has 50K miles on it.
I'm not interested in lowering the car at all. It is my DD and I don't go to the track, but I would characterize my driving as very spirited as I fight the fast and furious traffic to work every day. But I want a ride that is more comfortable than I currently have. I was hoping to stay around $800 for a fix.
I've been reading some of the posts here and kinda have the Bilstein B6 in the back of my head as a possible good set, but not sure if they would work with my stock springs or not? I've also seen talk about replacing the back springs with the 2017 version.
So I guess the questions are:
1. Are the B6's a good set to go with for ride quality but still sporty driving?
2. Will they work with the stock springs?
3. What are the big changes in feel with the 2017 springs and is it mainly just the rear springs that people are swapping out?
4. What other spring sets are good to pair up with the B6's?
Last edited by GTone; 12-07-2017 at 05:04 PM. Reason: People complain of having to read long paragraphs.
GTone is offline   Reply With Quote
Old 12-07-2017, 03:39 PM   #2
Racecomp Engineering
I would do a full inspection of your suspension, but yes Bilstein B6 would be a good choice and they work with stock springs.
- Andrew
Old 12-07-2017, 04:14 PM   #3
TommyW
TommyW's Avatar
Drives: '13 Whiteout
First thing is I'd use paragraphs when you type
TommyW is offline   Reply With Quote
Old 12-07-2017, 04:25 PM   #4
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Just think of it as one big ass paragraph.
smg1138 is offline   Reply With Quote
Old 12-07-2017, 05:08 PM   #5
GTone
Edited post to make it more readable.
Thanks Andrew for the feedback on the B6's. If I stuck with the stock springs, would I need to consider replacing top hats or mounts or any other hardware with it?
The Following User Says Thank You to GTone For This Useful Post:
cjd (12-07-2017)
Old 12-07-2017, 08:45 PM   #6
jmark
Drives: '97 NSX-T, '18 Type R
Originally Posted by GTone View Post
Guys,
http://www.ft86club.com/forums/showp...9&postcount=53
jmark is offline   Reply With Quote
Old 12-08-2017, 01:49 AM   #7
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
If the ride is noticeably different post crash I would have it checked again as RCE suggested. Something may be off if it was all replaced with OEM parts. Did anything else change parts wise when it got replaced?
Old 12-08-2017, 02:00 AM   #8
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
No need to replace top hats with the B6's. You'd want to keep the OE rubber to retain comfort as well.
But would agree with posters above before spending money and trying a new damper and have your current suspension looked over again.
R1 3 5
. 2 4 6
asdf is offline   Reply With Quote
The Following User Says Thank You to asdf For This Useful Post:
Racecomp Engineering (12-08-2017)
Old 12-08-2017, 02:03 PM   #9
You wouldn't need to, unless your old ones are busted or worn out.
- Andrew
Old 12-08-2017, 02:22 PM   #10
GTone
The driver side lower control arm as well as the tire was replaced but that was it as far as suspension parts. All the rest was pretty much cosmetic body work and the washer fluid tank.
So if the dealer already looked it over, where would you suggest a go-to for inspecting the suspension?
Old 12-08-2017, 03:10 PM   #11
I would inspect your shocks to see if they've blown (leaking fluid). Have a look at your control arm bushings to see if they're torn or in general bad shape.
- Andrew
Old 12-13-2017, 10:53 AM   #12
GTone
So, I looked over the suspension and I believe there is no leakage in my shocks. They are dry and clean all over. The bushings all look good and in fact on the side in question, I believe they are all new when they replaced the LCA.
I'm starting to wonder if this is all in my head. After the accident I had to drive a rental for 2 months waiting for my car to get fixed. It was a cushy ride. But I've been driving mine for 3 months now and still think it's a little rough but maybe that's just how it was before? The only thing changed on the car from stock is the tires - my Pilot Super Sports are getting a little worn. Would that be a drastic difference in ride quality compared to the stock Primacy's?
I think I was wrong in characterizing my ride as bouncy. I think stiff is a better word as every bump seems to translate directly to my body. Would the B6 and RCE Yellows be a more comfortable ride or just make it stiffer yet?
Old 12-13-2017, 10:59 AM   #13
dattran86
Driver
Drives: 2013 Whiteout FRS
I think you was used to the soft suspension in the rental.
and B6 + RCE Yellow will likely be the same or even a little stiffer compared to stock suspension.
I just went from 4 weeks with no car and driving a rental.
when i got back into my stock BRZ. IT was STIFF!
Check out my website:
http://www.aim4apex.com/
IG: aimforapex
dattran86 is offline   Reply With Quote
Could use some suspension advice Assassin4Hire13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 06-23-2017 10:06 PM
Need advice on suspension set up dejxx Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 07-01-2015 11:07 PM
suspension advice NoobTron Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 11-03-2014 12:15 AM
Need some Suspension advice! LazerBrZ Mid-Atlantic 6 10-09-2013 09:36 AM
Suspension advice? GTBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-25-2013 11:38 AM
