| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
Drives: '23 BRZ
FWIW, Tire Rack gives 16" steelies as a Winter wheel/tire option only for non-PP '17 BRZ. For Performance Package it only gives 17" and 18" options.
https://www.tirerack.com/snow/Winter...odClar=Limited I'm 90% about to buy a '17 PP BRZ, if I do probably get 17x7 wheels and 205/50-17 Pirelli Winter Sottozero 3s for it. Last edited by ZDan; 12-07-2017 at 11:07 AM. |
#16 | |
Rice King
. The difference in driving is so apparent to me I have reverted to grandma driving, but it is a worth compromise so I don't kill myself when I have to head to cottage country.
Glorious Honda.
Know my 5x120 GREATNESS PEASANTS. |
#17 |
Human
Drives: 2015 BRZ Black
I'm running 17x6.5+50 steelies with Altimax Artic tires. They sit in the fender a little far for my tastes so i run them with 25mm spacers.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
#18 |
Only users lose drugs.
Drives: All the time
I think it can be somewhat entertaining, depending on how you look at it. The car behaves much the same as with higher grip tires, just at a far lower threshold. Can make driving closer to the speed limit a little more fun...lol. It's kind of like hopping into an older sportscar from the 60's/70's with tall, skinny tires.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
| The Following User Says Thank You to venturaII For This Useful Post: | JazzleSAURUS (12-07-2017) |
#19 | |
Drives: 15 BRZ LTD, 05 FXT
The arctics dig better, the Xice3 does better in nasty icy stuff, and they both cost less. My top three winter tires right now are the new Altimax Arctic 12's, Nokian Hakka R2, or Michelin XIce3, in that order from most dig-happy tire, to best balance, to best ice tire. (Sans studs.)
#20 | |
Rice King
Glorious Honda.
#21 | |
#22 | |
Rice King
I'm just trying to stay alive in winter lol
Glorious Honda.
#23 |
Drives: '23 BRZ
To be able to drive on plowed roads in RI/Mass through the Winter, while maintaining some handling precision. I was only looking at the "Performance Winter/Snow" category tires.
#24 |
Drives: 2014 GT86
Jordanwolf: you can get slight/some of that stiffness back with extra air pressure, lowering sidewall, slight stretching .. but don't. Imho 2/3rds of that squirming/moving around is from tire's rubber type/thread pattern. So you won't get much out of your tries, except compromising grip, pricier tires, worse bad roads compliance. Just grit the teeths and get as given that (good) winter tires will feel different
. Also imho ability to drive with ease on iced/unplown snow roads/steep driveways/uphills, overtaking crawling with spinning tires and out of control AWD SUVs (simply because they are still on summers or on some worse all seasons) is fun in itself. So is some drift fun on ice/snow. Just give up and live with that for 4-3 months till spring. Tries to get back specific feel will compromise what's more important.
| The Following 2 Users Say Thank You to churchx For This Useful Post: | Jordanwolf (12-08-2017), Tcoat (12-08-2017) |
#25 | |
Rice King
Glorious Honda.
#26 |
Drives: 2013 WRB BRZ 6MT
Will any 16 inch wheels fit over the PP brakes? I was of the impression they require 17 inch at least...
#27 |
Drives: 2017 ISM PP BRZ
#28 |
If you're going for plowed roads and aren't worried about going out if it's bad, the XIce3 is a champ.
| Tags |
| tires, tires and wheels, tires help, winter |
| SOLD | CB390248 | Wheels and Tires | 65 | 09-12-2019 11:30 AM |
| Winter Tire setup | DVNARC | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 27 | 09-17-2015 02:17 PM |
| TRADE: Winter Tires+Wheels+Cash for OEM Setup | harkbrz | Canada Classifieds | 0 | 12-13-2014 09:24 PM |
| Winter setup | cnk | NY / NJ / CT / PA | 72 | 12-13-2012 09:48 PM |
