| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#99 |
Drives: '13 Firestorm Base AT
Just spent hours in the wheel thread to conclude ^
#100 |
Drives: 2013 Subaru BRZ
Any updates???
#101 |
Drives: A bunch of 'em...
Yeah... These are the ones I think.
Would love to see a pic on a slammed car with 2 degrees of front camber. Tires: What will fit? 235 40, 245 40? Want a square setup. |
#102 |
Drives: Satin white pearl
I currently have these on my brz, but the clear coat is pretty cracked and faded. Can i remove the bolts and remove the lip with the tire still on in order to refinish the face and lip seperately or would i need to take off the tire?
![]() Sent from my SM-G925T using Tapatalk |
#103 | |
Country Boy 4 Life
Ummmmm. No. The guy you quoted says they are one piece. The "bolts" are most likely plastic. IMO, the wheel looks fine; like any wheel of its age and value. I would be more concerned about the 45 series 18" tire. It is to tall. It should be a 35 or 40 series, depending on width. Anyway, if you want to paint the wheel, you can tape it off and paint it with the tire on it. If you want to powder coat; you will have to remove the tire. They will have to put the wheel in an oven to "cure" the powder. I know it's possible to re-clear coat the wheel. But clearing over the messed up clear coat won't fix it. You would have to strip the old off first. You can polish off the bad clear. I've done this, it is time consuming. Maybe someone else can chime in with some tips on how to make stripping and re-clearing easier. If they were mine and I wanted to change them... I would paint them dark silver or bronze. Tape off the lips, scuff the centers, prime, paint, and then clear them. The primer and paint will fill in the light scratches. Good luck!
I LIKE TIRES! |
#104 | |
But i want to separate the wheel and the lip because i want to use paint stripper to remove the old clear coat. I want the paint them as im not a huge fan of the polished aluminum/chrome look. Im leaning towards a bronze lip/barell and a black face. I just want to know if i can take off the lip with the tire on or if that lip is whats holding the tire bead in. What confused me is when they said its a one piece with a separate lip. Made me think the lip is not where the bead sits. If that makes sense? Sent from my SM-G925T using Tapatalk |
#105 | |
Otherwise isnt it obvious that if it were a one piece, why say its a one piece with a step lip. maybe im over thinking it lol Sent from my SM-G925T using Tapatalk |
#106 | |
LMGTFY
Drives: 13 FRS, 91 Miata
I used to own these. They are 100% a single piece of metal. The bolts are fake, and the lip is chrome plastic. Have fun trying to re-clear that POS. Last edited by x808drifter; 11-28-2017 at 05:45 PM. |
| The Following User Says Thank You to x808drifter For This Useful Post: | Leonardo (11-28-2017) |
| Wheel Directory: Yoshihara Design DY-D5C 18x9.0 +35 | Lanbaldo3 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 26 | 09-15-2016 01:37 PM |
| Wheel Directory: Yoshihara Design DY-37C 18x9.0 +25 | PekoPeko | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 05-23-2014 05:53 PM |
| Wheel Directory: Yoshihara Design DY-37C 18x8.0 +30/18x9.0 +35 | ish20 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 12-04-2013 12:08 AM |
| Wheel Directory: Yoshihara Design Champion 18x8.0 +30/18x9.0 +35 | JoeBoxer | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 36 | 11-24-2013 03:33 PM |
| New yoshihara design wheel | yoshiharadesign | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 129 | 11-01-2013 10:16 AM |
