Old 11-23-2017, 07:00 PM   #29
brzzy
@anthonysestito
brzzy's Avatar
Drives: 2013 Sterling Silver Metallic BRZ
Well, problem solved.
Was the the mechanics today doing a tire changeover. They found nothing, as I’m leaving the lot, it happens again.
Mechanic peeks in the engine bay...... I have Velox (now verus) fuel rail covers. One the bolts was backing out and loose and rattling.
Smh.
Thanks anyways everyone.
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO
brzzy is offline   Reply With Quote
The Following 3 Users Say Thank You to brzzy For This Useful Post:
bcj (11-24-2017), humfrz (11-24-2017), Ultramaroon (11-24-2017)
Old 11-24-2017, 01:41 AM   #30
Smh.
Thanks for letting us know what the problem was.
Well, like they say in the old country ........ when you play you pay ........
"Reduce weight from the extremely heavy FA20 engine while adding a bit of color to the engine bay. These brackets remove the large and bulky factory steel pieces in the engine bay. The passenger side fuel rail cover / ECU bracket removes 2 lbs 7 oz alone while the driver's side bracket removes just under 2 lbs as well!"
I should ...... ...... you for not telling us about that mod. But, since it's thanksgiving ...... I'll let it go ....... this time ......
PS - where in the hell is "Vaughan" - because, we are going to have to keep an eye on you ......
Tcoat (11-24-2017)
Old 11-24-2017, 01:52 AM   #31
brzzy
@anthonysestito
brzzy's Avatar
To tell you the truth that was literally the last thing I would ever check for. Hence, I left it out. The sound was Les of a scrape than a rattle which led me to look in other places - never in a million years would I think that bolt would back out given how long it’s been in there and in there good.
And yeah it’s a hyped up piece but whatever. When you need to get free shipping some times you buy useless shit to fill the cart lol
Vaughan, I’m like 20 mins north of the city (Toronto) and I’m across the street from wonderland. Not too many twins in this area. A lot that I see sometimes just passing thru the area. And a few that are just stock, no mods, not even a wave back or anything.
I usually end up at a few meets and track days here and there and I’m often in the city or out and about in Vaughan.
IG: @ANTHONYSESTITO
The Following User Says Thank You to brzzy For This Useful Post:
humfrz (11-24-2017)
Old 11-24-2017, 01:54 AM   #32
brzzy
@anthonysestito
brzzy's Avatar
Also just noticed you’re in the USA so my spiel about where Vaughan is was probably alien to you - my apologies.
I’m in Canada. Vaughan is a city just north of Toronto.
IG: @ANTHONYSESTITO
Old 11-24-2017, 02:09 AM   #33
Well, it seems once a nut or bolt is loosened from the factory placement, there is a chance of it coming lose.
Back-in-the-day ....... when they used gaskets between things and lock washers on nuts and bolts, things that were taken apart, stayed together better when put back on.
Now days, they seem to slap some goop between things and torque down the nuts or bolts, thinking nobody is ever going to take the part off.
Old 11-24-2017, 02:20 AM   #34
Ahhhh haaaa !!..... got you on the scope ......
I'm going to ask ol @Cole to run up and check on you from time to time.
Now, be advised, ol Cole leads a straight and narrow life so, I suggest you be on your best behavior ....... and keep your nuts and bolts tight.
Old 11-24-2017, 08:53 AM   #35
brzzy
@anthonysestito
brzzy's Avatar
Ha! Thanks for the heads up lol
IG: @ANTHONYSESTITO
humfrz (11-24-2017)
Old 11-24-2017, 10:32 AM   #36
This is why it is important to list ALL your mods when asking about an issue. May be the last thing you would think of but the very first place somebody else may say to look.
I was through Brampton and Vaughan about 4 times this summer and did not spot one single other twin. The way people talk I thought I would be surrounded by them all the time but nothing appeared.
Old 11-24-2017, 10:57 AM   #37
brzzy
@anthonysestito
brzzy's Avatar
I totally forgot about that part TBH - My mistake.
Yeah I see very few around here. I’m always in the wonderland area because I live and work near that intersection right off the 400. Often when there’s meets I see a lot of guys from up north stopping at the gas stations along the way but otherwise next to nothing here. A lot more STI’s and Ferrari’s then anything else.
IG: @ANTHONYSESTITO
Old 11-24-2017, 03:48 PM   #38
@brzzy, you strike me as a super cool, considerate guy. Thanks for following up.
bcj (11-24-2017), brzzy (11-24-2017)
Old 11-24-2017, 06:12 PM   #39
brzzy
@anthonysestito
brzzy's Avatar
I try haha.
IG: @ANTHONYSESTITO
metal on metal sound when releasing the clutch MyNave Engine, Exhaust, Transmission 7 04-18-2018 01:00 AM
Clanking metal sound from rear!!!! 808Raven Issues | Warranty | Recalls / TSB 7 09-21-2017 11:09 AM
Metal vibration sound when in drive before pressing accelerator theparagon Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 08-31-2017 12:05 PM
Metal Grind Sound when throttle blip JDM-dono Issues | Warranty | Recalls / TSB 0 11-17-2013 05:37 AM
Scraping metal noise? Gost Issues | Warranty | Recalls / TSB 0 03-14-2013 10:11 PM
