#631 |
Drives: 2014 FR-S Hot Lava
It's halfway between DS and STX pax. Look like a good starting point to me.
#632 |
Drives: 2016 FR-S
#633 |
Spec Twin?
Don’t get your hopes up. You can pretty much cross out Rivals or RE-71Rs Sent from my iPhone using Tapatalk
Kyle H. - #89 STX
#634 |
My VTEC fluid is full
Drives: EFF JAY
#635 |
Drives: '15 STX
#636 |
Drives: Some kind of Subaru
#637 | |
Drives: 2014 FR-S
-Mike
#24 CS/CSR |
| The Following User Says Thank You to TrqlessWonder For This Useful Post: | strat61caster (11-17-2017) |
#638 | |
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
The alignment is a PITA too. The rear has a lot of cross-talk between toe and camber so we had to keep going back and forth between the two. The front gets a good chunk of camber from slop but it's not a simple matter of just maxing it out because of clearance issues. (At least with the rivals) |
#639 |
Drives: '15 STX
It's on that one forum somewhere.
You can probably ask Mike Maier, too.I'd be interested in doing a true test with the CS ND and the SSC car. I drove them back to back and put down extremely similar times on a 60s course. I think they're both just as fast as one another. PAX is "accurate" given similar tires. I drove both cars with 225 Rival S. Yeah, the ND is just that fast. |
| The Following User Says Thank You to tony_r For This Useful Post: | strat61caster (11-17-2017) |
#640 |
Drives: '13 FRS - STX
idk I read that pax as 'give an 86 a better alignment and it's actually on par with an ND'
No way is a lame tire on an SSC prepped 86 going to run times with CS The SSC kit isn't STX-lite, it's a Street+ |
| The Following User Says Thank You to strat61caster For This Useful Post: | Racecomp Engineering (11-17-2017) |
#641 |
Drives: '15 STX
On certain courses, it is STX-lite. It handles very similarly with a tad more roll. So long as you don't spend a lot of time in the torque dip they will be pretty close to each other.
I've driven a few STX cars, the CS trim, DS trim and now the SSC car. It certainly handles more closely to an STX car without the power, since you don't have to tip toe around a junk front end. |
#642 | |
You've alluded to getting over -3 degrees of camber on an SSC car I think, but it's not by much right? After seeing you drive Rich's car at Round 1 this year I have no doubt you know what you're talking about.
#643 |
Drives: '15 STX
Close to -3.5 with +40.
#644 | |
I agree, it will all depend on what tire SSC runs. |
| Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) | OnionTou | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 55 | 07-01-2016 01:36 AM |
| what's the difference between twin screw, centrifugal, single turbo and twin turbo? | warplane95 | Forced Induction | 86 | 04-17-2014 02:36 PM |
| my twin | RWDGUY | Mid-Atlantic | 2 | 04-08-2013 09:23 PM |
| JDM Spec-C V9 Twin Scroll VF36 complete | Nico TURBO | Engine, Exhaust, Bolt-Ons | 0 | 12-05-2012 11:20 AM |
