Old 11-14-2017, 01:27 PM   #1
Rohint75
Drives: 2014 Brz limited SWP
Is $1600 for a clutch replacement too much?
Was quoted $1600 to replace a clutch by a trusted family mechanic, does this sound right?
Rohint75 is offline   Reply With Quote
Old 11-14-2017, 01:32 PM   #2
StraightOuttaCanadaEh
Wes
A bit hefty. Is this parts included?
Old 11-14-2017, 01:37 PM   #3
bryansuriel3
bryansuriel3's Avatar
Drives: Red Brz
That’s a lot imo
bryansuriel3 is offline   Reply With Quote
Old 11-14-2017, 01:41 PM   #4
jasonojordan
Drives: 2013 satin white brz limited
Either way parts included or no it seems a bit steep provided you are just doing stock parts and not some crazy over kill clutch.
stock clutch and pressure plate can be had for under $300
Throw in a couple more bucks to have your flywheel turned or at least checked for this job I would figure you have under $500 in parts.
For a garage mechanic (someone working for cash in their own home garage) this job should be around $500 or less.
For a shop I could see that stretching up around $800-$1000 depending on their overhead costs.
jasonojordan is offline   Reply With Quote
Old 11-14-2017, 02:04 PM   #5
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
You can have it done for about $350-400 in labor in my area, obviously shop prices change between locations, but it seems a bit steep, even using an aftermarket clutch going for about 500-600 would still be less than $1600. I think that's high.
Old 11-14-2017, 02:17 PM   #6
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Better come with a lap dance in the waiting room.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following 7 Users Say Thank You to venturaII For This Useful Post:
Adam_L (08-18-2018), funwheeldrive (11-14-2017), KMA KiCKz (08-22-2018), Muaddib (11-15-2017), sosick (11-16-2017), Tcoat (11-14-2017), Teseo (11-15-2017)
Old 11-14-2017, 03:23 PM   #7
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
That price sounds too high.
OEM clutch part should be around 230-250
I had my TOB and new clutch installed out the door at $621.60
Look how fast someone familiar can take out the trans:
http://www.ft86club.com/forums/showp...7&postcount=44
Either way man I suggest getting your TOB replaced since someone will be up in there anyway (TOB=$50). Also check your flywheel you may not need it resurfaced/replaced. I'm at 70k and my flywheel looked great. However be prepared to resurface/replace the flywheel if needed.
DandoX is offline   Reply With Quote
The Following User Says Thank You to DandoX For This Useful Post:
Teseo (11-15-2017)
Old 11-14-2017, 04:30 PM   #8
jasonojordan
A new OEM flywheel is less then $200 from what I found.
Old 11-14-2017, 04:39 PM   #9
ermax
ermax's Avatar
I got the new 2017 TOB from Toyota for $17. $1600 is WAY too much.
Old 11-14-2017, 04:47 PM   #10
D-rek07
I just changed my clutch this weekend.
Exedy OEM clutch kit (Clutch, pressure plate, pilot bearing, throwout bearing= $200 on Amazon
Flywheel resurfaced = $35 at a local shop
D-rek07 is offline   Reply With Quote
Old 11-14-2017, 04:53 PM   #11
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I do the labor for $350 for locals, if that helps you get a gauge on the rest of the deal. A 'real' shop is likely closer to $450. These cars are pretty easy to do that job on, lift car, drain trans fluid, remove shifter, pull driveshaft from trans and hang on whatever you can, pull trans back and you're in like flynn. (flinn? idk.)
If that's the price with a full aftermarket (exedy stage 1, ACT HDSS, Southbend, etc,) clutch kit, new OEM or lightweight flywheel, velox clutch fork and pivot with OEM TOB, and a good gear oil like motul or amsoil, I don't think the price is that far off.
That said, I doubt he's grabbing the 'full monty' enthusiast package.
JazzleSAURUS is offline   Reply With Quote
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
why? (08-18-2018)
Old 11-14-2017, 05:11 PM   #12
venturaII
venturaII's Avatar
Flynn. As in, Errol.
The Following User Says Thank You to venturaII For This Useful Post:
JazzleSAURUS (11-15-2017)
Old 11-14-2017, 05:22 PM   #13
Hags86
Drives: Toyota GTS 86
What does TOB stand for?
Hags86 is offline   Reply With Quote
Old 11-14-2017, 05:25 PM   #14
ermax
ermax's Avatar
Throw out bearing
The Following User Says Thank You to ermax For This Useful Post:
Hags86 (11-15-2017)
clutch, replacement, transmission
DIY Clutch Replacement Supermassive DIY (Do-It-Yourself) Guides 217 08-27-2023 01:35 PM
Clutch replacement pinetree Engine, Exhaust, Transmission 21 05-03-2017 09:48 AM
Exedy OE replacement clutch. APEXIT53 Transmission and Driveline 2 04-08-2017 09:54 AM
Clutch replacement Thatguyjeremy Engine, Exhaust, Transmission 0 02-28-2015 05:22 AM
Clutch/flywheel replacement? bucket BRZ First-Gen (2012+) — General Topics 1 11-19-2012 01:25 PM
