Old 07-15-2017, 05:34 AM   #1
skogs
Drives: GT86 2013
Heatwrap header for noise reduction
I've recently installed some stainless headers, and the exhaust leaky noise under load is just too annoying. I went to an exhaust shop and had them check it out, they couldn't find a leak, and suggested it was caused by the thinner materials used in SS headers.
Do you think wrapping the headers would work to deaden the noise? Otherwise i might revert back to stock. I don't want to drive around in a new looking car that sounds like its leaking exhaust.
The system is stock otherwise btw.
skogs is offline   Reply With Quote
Old 07-15-2017, 06:07 AM   #2
JDM4E
Drives: Honda Accord Euro
what header did you get?
JDM4E is offline   Reply With Quote
Old 07-15-2017, 06:28 AM   #3
skogs
Drives: GT86 2013
Got the OFH2. Build quality is excellent and the fitment is spot on. I think the noise is just the nature of stainless steel headers.
Does anyone else here run with an UEL SS header and otherwise stock exhaust?
Old 07-15-2017, 12:15 PM   #4
kingkenny
Drives: 2014 Toyota GT86
From the Oem Cat header to a catless header , it louder for sure
kingkenny is offline   Reply With Quote
Old 07-15-2017, 12:34 PM   #5
skogs
Drives: GT86 2013
If it was about the same sound only a bit louder, no problem. But it's that entirely new leaking-sound that bugs me. Maybe it actually does leak, just not enough to notice on idle. I wasn't very thorough when cleaning the mating surface on the block..
Old 07-15-2017, 01:35 PM   #6
bfrank1972
Drives: 2013 FR-S Argento
I think wrapping would help deaden the sound you're talking about, assuming you don't actually have an exhaust leak somewhere. Sounds like you're complaining about the 'ringing' of the headers perhaps - stock are quieter because they have heat shields on them. I noticed the additional sound when I added headers too - the sound is right under your feet, and probably most of what you're hearing is in-cabin. I just got used to it, don't even notice it now.
The Following User Says Thank You to bfrank1972 For This Useful Post:
skogs (07-16-2017)
Old 07-16-2017, 01:08 PM   #7
skogs
Drives: GT86 2013
Well, turned out i had a leak. The torque wrench i used on tthe header-bolts was way off, and i got almost half a turn on each bolt before reaching 30Nm with a more reliable one. The sound started out less noticable after that, and disappeared entirely after a few miles.
I now hear the sound you are talking about frank, and frankly it doesnt bother me that much.
The Following User Says Thank You to skogs For This Useful Post:
bfrank1972 (07-16-2017)
Old 07-17-2017, 06:47 PM   #8
Sagz
Drives: 2016 Brz Hyper Blue
Is it a hissing sound when you accelerate? I installed a header too this weekend and can't figure out if its a leak or not since it's not there on idle.
Sagz is offline   Reply With Quote
Old 07-21-2017, 10:02 PM   #9
RYO
RYO's Avatar
Drives: 2014 Scion FR-S Firestorm
Warpping your headers should not reduce the exhaust sound. But honestly you should not wrap your exhausts in the first place, since its more likely for rust and corrosion. Ceramic coats the way to go.
But to answer your question, if you're strugging with a loud exhaust, I would suggest going with the JDL ultra quiet frontpipe. Seriously quiet the exhaust for me.
RYO is offline   Reply With Quote
Old 07-21-2017, 11:06 PM   #10
danfushi
Drives: Toyota GT86
Had the same problem with the tomei catless UEL, the thinner metal is the reason why your system sounds leaky... you can try wrapping the header... in the german forums a guy told me, it helped a lot to wrap.... some other guys told it doesnt help, so maybe just try it out and share your information with us?
I heared wrapping is no problem when the header quality is high
danfushi is offline   Reply With Quote
Old 11-10-2017, 05:40 PM   #11
Twitchy313
Twitchy313's Avatar
Hey guys, so i installed these same Tsudo UEL’s in my FRS as well, sounds great but i am having the weirdest sound coming from the headers. It sounds like a leak but i had them checked out and they said it wasn’t a leak. I am running stock exhaust on them so i wonder if that has anything to do with it?
Any comments or suggestions would be greatly appreciated 😊
Twitchy313 is offline   Reply With Quote
Old 11-10-2017, 05:53 PM   #12
Icecreamtruk
Drives: Track preped NA FRS
Simple answer, yes. I wrapped mine (also SS headers, catless, nothing too fancy) and the volume dropped considerably.
Edit: dammit, I just realised i answered to a somewhat old thread that got bumped ...
@Twitchy313 what you are hearing is probably just the gasses passing thru the header that is now thinner and has no shielding. Stock rest of the exhaust should have nothing to do with it (aftermarket exhaust will just make the whole thnig louder most of the time).
Icecreamtruk is offline   Reply With Quote
The Following User Says Thank You to Icecreamtruk For This Useful Post:
Twitchy313 (11-10-2017)
Old 11-10-2017, 09:03 PM   #13
Trust86
Drives: 2016 Halo FRS
Wrapping the header will quiet down down the noise coming from the header. It worked really well for me. Sounds like an exhaust leak, especially during cold starts. Now it’s nice and quiet. I wrapped my front pipe too, that was just as bad if not worse. I have the ace front pipe.
Trust86 is offline   Reply With Quote
The Following User Says Thank You to Trust86 For This Useful Post:
Old 11-10-2017, 09:27 PM   #14
Twitchy313
Twitchy313's Avatar
@Icecreamtruk Makes perfect sense, thank you for that! So you think that the loud rattle (leak noise) is caused by the no shield and gasses mix? What are the chances that i wrap them and that sound goes away?
Catted vs resonated front pipe noise reduction difference raven1231 Engine, Exhaust, Transmission 11 03-30-2017 11:20 AM
Mounting aftermarket header. Do i have to wrap/ ceramic coat for heat protection? giorgi0424 Engine, Exhaust, Transmission 9 03-03-2017 09:58 PM
Catless header noise reduction SlydwinderFT86 Engine, Exhaust, Transmission 11 08-24-2016 02:37 PM
Request: Oil Pan heat wrap? 1Cor10:23 DIY (Do-It-Yourself) Guides 14 11-26-2014 05:01 PM
DIY Gold Foil heat wrap intake box autoCAR DIY (Do-It-Yourself) Guides 35 02-20-2014 03:22 PM
