go_a_way1
Old 11-09-2017, 01:17 PM   #4257
amcp1
Drives: frs
Update on the new RXK valve. It seems to make the power band smoother and the torque around 3-3500rpm seems a bit higher. That might be since the weather here is getting colder now. Its also a bit louder. No complaints.
amcp1 is offline   Reply With Quote
The Following User Says Thank You to amcp1 For This Useful Post:
keithr (11-09-2017)
Old 11-09-2017, 03:56 PM   #4258
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Originally Posted by mrg666 View Post
I am still using the stiffest spring (yellow) in the recirculation valve.
- With the stiff spring, recirculation valve closes earlier at lower vacuum level when I want to accelerate. This boosts the engine at lower rpm, gives better throttle response, and noticeably higher power at lower rpm.
- Recirculation valve opens later (at higher vacuum) when I release throttle in deceleration. I feel that the compressor is making less noise on sudden release of throttle. Take this with a grain of salt since this is my interpretation: I think the surge is less on the compressor during deceleration and compressor is happier.
I went back to softer spring for a day to make sure this is not all placebo. Nope, I have installed the stiffest spring back and I am definitely not making all these up.
CSGMike said that he is going to test what I posted here. But it is not an expensive piece to test if you want to see yourself. I think RKX valve is higher quality than the plastic valve anyway.
Did you use either of the washers that came with the kit?
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 11-09-2017, 04:04 PM   #4259
mrg666
pessimistic skeptic
mrg666's Avatar
No, just the yellow spring
Old 11-09-2017, 04:10 PM   #4260
keithr
keithr's Avatar
Drives: 2014 BRZ Limited (DGM)
I'm seeing a lot of positive experience feedback about this part, but @CSG Mike expressed some concerns.
Mike? JR (Oscar?)? Anyone care to weigh in on whether this is effective (anecdotally it appears to be) and safe for the JRSC setup?
keithr is offline   Reply With Quote
Old 11-09-2017, 04:31 PM   #4261
ExpertZero
Drives: FR-S 2015 Halo
What spring color did you use?
ExpertZero is offline   Reply With Quote
Old 11-09-2017, 04:38 PM   #4262
amcp1
Drives: frs
I agree it would be nice if someone from JR chimed in. The only reason I made the switch is the supplied part failed twice.
I used the red spring per the recommended settings.
- Red spring 8-22 PSI
Old 11-09-2017, 07:56 PM   #4263
Deep Six
Deep Six's Avatar
Ordered today !! James will calibrate the tune and drop the rev limiter for me. Track weekend scheduled for Dec 2/3 very interested to see if the extra midrange punch allows me to consolidate some gear changes.
[SIGPIC][/SIGPIC]
The Following 3 Users Say Thank You to Deep Six For This Useful Post:
CSG Mike (11-11-2017), Jmonty (11-11-2017), rns294 (11-11-2017)
Old 11-11-2017, 12:22 AM   #4264
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Keep us updated on the the turn around time for shipping and how the power band ends up
This will be my Christmas present to me.
Jmonty is offline   Reply With Quote
Old 11-11-2017, 08:20 AM   #4265
rns294
Drives: 13 BRZ
What are the details of your engine build?
rns294 is offline   Reply With Quote
Old 11-11-2017, 10:31 AM   #4266
q335r49
Drives: 2013 scion fr-s
So im installing the supercharger right now, and I noticed that the oil resevoir for the supercharger oil is higher than the supercharger shaft, contrary to the rotrext directions ... anyone think this is an issue / mount it somewhere else?
Sent from my BBB100-1 using Tapatalk
q335r49 is offline   Reply With Quote
Old 11-11-2017, 12:00 PM   #4267
mrg666
pessimistic skeptic
mrg666's Avatar
No, just install where it is recommended.
The Following 2 Users Say Thank You to mrg666 For This Useful Post:
Jackson Racing (11-13-2017), q335r49 (11-11-2017)
Old 11-11-2017, 02:23 PM   #4268
keithr
keithr's Avatar
I had that same dilemma/concern when I installed mine. I was assured it was OK as it is directed to be installed.
Rules are meant to be broken, because racecar.
The Following User Says Thank You to keithr For This Useful Post:
Old 11-11-2017, 09:08 PM   #4269
revaholic
Drives: 2016 Ablaze Scion FR-S
My C30 has suddenly got REALLY loud at idle. This means it's defective? I have an email to tech@jacksonracing, waiting for a response.
Why does this seem to happen to everyone eventually
revaholic is offline   Reply With Quote
Old 11-12-2017, 09:02 AM   #4270
Deep Six
Deep Six's Avatar
New oem block/crank/girdle/oil pump & cover assembly
Wiseco forged 11.5:1 pistons
Manley I Beam forged rods
ARP studs
GSC +1 Valve Train including Beehive Spring kit
Original heads with P&P
Full Blown Oil Pan and Radiator
Wellbro 485 Pump and 1000cc Injectors
Motor was built with higher rpm's in mind but I keep staring at dyno sheets and think about how much time is spent between 4,500 and 7K versus 7K+. My gut tells me the car will be quicker around the track with more mid range acceleration and the ability to stay one gear higher in certain turns. That and I'm certain I will do more for engine longevity by staying under 7K versus routinely pushing 8K as I have in the past. I will run it with the 90mm pulley until the head unit wears out then switch to a C38.
They shipped the kit same day and will be here in Florida on Thursday. I don't plan to dyno it but we will have some boost to rpm data from our street tuning logs to share.
[SIGPIC][/SIGPIC]
The Following User Says Thank You to Deep Six For This Useful Post:
rns294 (11-13-2017), Surok (01-19-2018)
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
