#15 |
Drives: 1JZ-GTE Toyota Mark II, Toyota bB
#16 |
Drives: 2013 Scion FR-S (Hot Lava)
As they mentioned the only real reason the BRZ is so 'slow' from 0-60 is because of the required upshift at 59mph from first to second. If the car could just be left in first than I'm sure it would be quite a bit quicker. That said, who really cares about that stat unless you are racing other slow cars on the street.
#17 |
Drives: Scion FR-S (Hot Lava)
It's a 2l 4cyl car. I wouldn't really stress about the 0-60, especially when you have to up shift at 59 lol.
#18 |
It does 0-59 in 6.5sec, who gives a $#!t about that last MPH.
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
#19 |
Drives: 2013 BRZ Limited 6MT
I also think this is just a myth. I've seen videos of the car at 60 rolling at 7400 rpms in 2nd. After my break-in, I will test this out. Regardless, this is just chatter at this point. The car feels like a 6 second car. It doesn't feel underpowered. nuff said.
| The Following User Says Thank You to Tbxgz For This Useful Post: | tripjammer (07-07-2012) |
#20 | |
Drives: '13 BRZ Lmtd
59 MPH is max for 2nd
The correct rotations per mile of the 215/45R17 Primacy tires is 844 according to Michelin. The differential has a 4.1 ratio and the gear ratios are: 3.626 2.188 1.541 1.213 1.0 and 0.767 so the accurate speeds at the 7450 RPM fuel cut-out are: 60*7450/4.1/844 ./[3.626 2.188 1.541 1.213 1 .767] which equals: 35.6 59.0 83.8 106.5 129.2 168.4 So you would need to shift to 3rd to reach 60 MPH. But, who really cares that the 0-60 time is slow because of the second shift? |
| The Following User Says Thank You to DSPographer For This Useful Post: | Tbxgz (07-06-2012) |
#21 |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I've seen plenty of videos showing it only takes two shifts to get to 60mph. I don't know what you guys are talking about.
| The Following User Says Thank You to SUB-FT86 For This Useful Post: | tripjammer (07-07-2012) |
#22 |
#23 |
86 Member
