Old 11-02-2017, 09:36 PM   #1
Spocknasty
Spocknasty's Avatar
Drives: '13 BRZ Limited / 76' 914 1.8T
OLM Bixenon Low / High Beam Projector Fog Lights Installation
I picked up the OLM Bixenon Low / High Beam Projector Fog Lights to reveal the wooded surroundings at night on the way back from mountain biking - almost hitting deer every time is far from ideal.
I did some searching and haven't been able to find the locations for the following plugs:
"To stock high beam"
"High beam input from vehicle"
"Fog light input from vehicle"
If someone could shine some light on the locations for me I'll happily post up a review after.
Automotive photo and video
www.mikespock.com
Spocknasty is offline   Reply With Quote
Old 11-03-2017, 07:00 PM   #2
mrderp
ಠ_ಠ
mrderp's Avatar
Drives: 860 SansOverspray
Here's the headlight harness pinout for a '13 BRZ.
White = Turn signal +
Green = Boomerang LED +
Thin Black = Common Ground
Yellow = High beam +
Red = Low beam +
Thick Black = Low beam ground
Blue = High beam ground
You will need to tap your hi beam input connector into the YELLOW and BLUE wires.
As for the stock fogs, if you didn't have any, look at the fog installation howto to get the wiring details. http://www.ft86club.com/forums/showthread.php?t=27581
mrderp is offline   Reply With Quote
The Following 2 Users Say Thank You to mrderp For This Useful Post:
DAEMANO (11-03-2017), Spocknasty (11-03-2017)
Old 11-03-2017, 07:03 PM   #3
Spocknasty
Spocknasty's Avatar
Are those harness plugs not intended to plug directly into the factory plugs?
www.mikespock.com
Old 11-03-2017, 07:17 PM   #4
mrderp
ಠ_ಠ
mrderp's Avatar
Can you show us the actual harness kit you got with the fogs?
Old 11-03-2017, 07:21 PM   #5
mrderp
ಠ_ಠ
mrderp's Avatar
If you mean you have this harness: http://www.ft86speedfactory.com/olm-...2013-ft86.html
Your BRZ has factory HID, you don't have the hi beam plug that this kit is for.
It's not going to be plug and play.
Old 11-03-2017, 09:06 PM   #6
Spocknasty
Spocknasty's Avatar
So I'm basically tapping in to the factory high beam wiring and running to the connector coming off of the rear of the foglights to control the mechanical flaps?
Where am I tapping in to the "fog light input from vehicle" as I'm not seeing a matching plug - or will that require custom wiring as well?
www.mikespock.com
Old 11-04-2017, 02:24 AM   #7
Poodles
Drives: 2015 Series.Blue
No, as it's meant for the FRS.
Old 11-08-2017, 01:03 AM   #8
Spocknasty
Spocknasty's Avatar
At this point I just need to know where to tap for the "fog light input from vehicle"
www.mikespock.com
Old 11-16-2017, 11:05 PM   #9
Spocknasty
Spocknasty's Avatar
Can anyone answer this question? I'd like to install this weekend.
www.mikespock.com
OLM bixenon fog light and wiring harness for fog with high beams NahumCC Cosmetic Modification (Interior/Exterior/Lighting) 42 08-10-2016 02:46 PM
Dash lights and high beam icon are on but.. GT 86 Brah Issues | Warranty | Recalls / TSB 3 06-28-2016 01:18 AM
OLM Bixenon Projector Foglights:Review 15limited Cosmetic Modification (Interior/Exterior/Lighting) 7 10-31-2015 11:48 PM
Scion FRS H11 Projector Low beam CREE LED replacement dssence Cosmetic Modification (Interior/Exterior/Lighting) 23 04-09-2014 12:18 AM
*PHASTEK* High / Low Beam Fog Lights for the FR-S & BRZ PhastekSport Exterior Parts - Lighting 35 01-06-2014 11:23 AM
