Old 08-10-2015, 06:20 PM   #15
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by bur****jp View Post
What do you have done to the car? I wouldn't worry about it unless you're boosted.
See above, I wouldn't worry about it at all...
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-10-2015, 08:08 PM   #16
86drift
86drift's Avatar
Drives: Toyota 86 GT
Originally Posted by Kodename47 View Post
I'll chime in with my latest test using ECUtek. This is a 3rd gear WOT pull:
However I also logged desired TPS Voltage and actual TPS Voltage. Both of these are 4V for the entire range. So I've come to the conclusion that the throttle isn't actually shutting at all, but for some reason the ECU shows that it does.
80% is actually WOT as the throttle plate can actually go 20% past WOT.
So, not sure why throttle angle value tapers down (I know how to stop it) but it makes no difference to the actual throttle position and performance.
86drift is offline   Reply With Quote
Old 08-11-2015, 02:57 AM   #17
Kodename47
Kodename47's Avatar
Drives: UK GT86
80% is just how ECUtek shows WOT. The throttle doesn't open more than that, it actually makes sense if the sensor is reading 4v on a 5v sensor. I'm intreagued how you prevent the ECU to stop showing the tapering, do tell as it may have something to do with calculations etc.
.: Stealth 86 :.
Kodename 47 DJ:
Old 10-21-2017, 11:24 AM   #18
davidog3
Drives: Scion fr-s
Actually I’ve been taking my car to the track every month once a month for the last 6 months, and I always had 100% throttle, im running UEL 85 tune from OFT , but this month I change the battery on the car the day before the track day , and I noticed I got only 90% thorttle and is still like this and my times at the track actually got worse by two seconds, maybe a lot of variables on my time but still I didn’t feel slower , I dont know why is only 90% now. Any suggestions?
davidog3 is offline   Reply With Quote
Old 10-22-2017, 08:39 AM   #19
steve99
Drives: FT86
were you logging same parameter
Their are several throttle parameters like accelerator pedal angle, throttle plate angle
oft, throttle
Part throttle faster than full throttle brn12345 Engine, Exhaust, Transmission 38 10-21-2021 01:20 PM
do you know what your throttle is doing? 7thgear Tracking / Autocross / HPDE / Drifting 17 06-19-2014 06:38 PM
AFR of ~15 during throttle but up to 20.3 off throttle, idles at ~15 ok? tracerit Engine, Exhaust, Transmission 11 02-15-2014 01:44 PM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 08:44 PM
