Old 09-13-2017, 12:01 PM   #1
pjp
Drives: frs
A/c cuts out above 90 mph ?
Air conditioner cuts out above 90 mph,
starts working after slowing down?
pjp is offline   Reply With Quote
Old 09-13-2017, 12:13 PM   #2
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I have to wonder, are you really concerned about the AC at 90mph? Do you normally cruise at 90mph and get frustrated that it's not nice and cool?
If I was going that fast, I'd want the AC to shut off to free up power, and release the load of the A/C on the cooling system.
JazzleSAURUS is offline   Reply With Quote
The Following 2 Users Say Thank You to JazzleSAURUS For This Useful Post:
Icecreamtruk (09-14-2017), Yardjass (09-14-2017)
Old 09-13-2017, 12:21 PM   #3
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Just drive at 89 mph.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following 6 Users Say Thank You to 8RZ For This Useful Post:
Alltezza (09-13-2017), FirstWinter (09-13-2017), j3rf (09-13-2017), Jyn (09-13-2017), Kaotic Lazagna (09-13-2017), lantsalot (09-13-2017)
Old 09-13-2017, 12:23 PM   #4
pjp
Drives: frs
Yes I cruise at 85 to 90 all the time, with cruise control on most of the time!
Last week driving through the big valley it was 107*F so yes A/C On!!
Old 09-13-2017, 12:26 PM   #5
pjp
Drives: frs
Eng Temps were Fine .
Six gear cruising Along
Old 09-13-2017, 12:54 PM   #6
KDad2
KDad2's Avatar
Drives: 2013 Raven
I don't know about that. Every time I get up to 88 mph, I see some serious shit.
KDad2 is offline   Reply With Quote
The Following 7 Users Say Thank You to KDad2 For This Useful Post:
8RZ (09-13-2017), FirstWinter (09-13-2017), Impureclient (09-15-2017), Kaotic Lazagna (09-13-2017), Kimsey47 (09-14-2017), smg1138 (09-14-2017), treminaor (09-23-2017)
Old 09-13-2017, 01:14 PM   #7
What valley do you call the "big valley" ...... ??
The A/C compressor will cut off under extreme load ........ maybe, at those speeds, the engine considers itself under extreme load .......
Pat (09-21-2017)
Old 09-13-2017, 01:24 PM   #8
JazzleSAURUS
Do you know if that's vacuum or RPM based?
Calculated engine load v. user demand.
Old 09-13-2017, 01:30 PM   #9
Darth Khan
I think therefore.....
Darth Khan's Avatar
Drives: Toyota 86 860 Halo White (Manual)
Open the window, this will do three things:
1. Cool the cabin down.
2. Generate increased cabin noise.
3. Cause the cars drag coefficient to increase slowing it down allowing the air A/C to come back on.
May the N.A. force be with you.
Darth Khan is offline   Reply With Quote
The Following User Says Thank You to Darth Khan For This Useful Post:
Stang70Fastback (09-14-2017)
Old 09-13-2017, 01:37 PM   #10
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
lol you know California's Central Valley. Not much has changed since you first visited I'd wager.
Interesting to hear it shuts off at 90, I could see that happening going up a hill (due to high load as mentioned before) but surprised it happens on flat level roads. Maybe dropping down to 5th will reduce the load via gearing and allow you to stay cool?
ineedyourdiddly
Old 09-13-2017, 01:42 PM   #11
strat61caster
You've never driven in 110 degree heat have you?
ineedyourdiddly
Old 09-13-2017, 01:46 PM   #12
Darth Khan
Darth Khan's Avatar
Yes, but I was having some fun, suggesting dropping below 90 is mundane.
Old 09-13-2017, 01:48 PM   #13
Imrac
Drives: 13 SWP BRZ Prem
Could it be the 110 Degree heat being forced in via high pressure area where the cabin intake is and overwhelming the evaporator?
Try turning on cabin recirculate to shutout air from the outside. Otherwise it's possibly the ECU turning off the AC unit due to load/demand.
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 09-13-2017, 01:57 PM   #14
mazeroni
Drives: 2013 Scion FR-S Series 10
Eh, couldn't verify if my car does this. I have very few opportunities to go more than 90 on the interstate, and in those rare situations, someone usually slows me down sooner rather than later.
If it has happened to me, the cabin would have already been cold, so I probably never realized it was happening.
mazeroni is offline   Reply With Quote
Unstable idle when A/C cuts out paulca Engine, Exhaust, Transmission 14 10-24-2015 10:18 PM
Help, Audio cuts off with sub amp install. 2014 FR-S Waukeen Electronics | Audio | NAV | Infotainment 8 07-02-2014 05:29 PM
AC cuts out at high revs. Cool feature? Superhatch BRZ First-Gen (2012+) — General Topics 9 06-28-2012 03:13 PM
Possible Final production cuts. Syldrin Scion FR-S / Toyota 86 GT86 General Forum 46 11-23-2011 10:02 PM
