Old 08-15-2017, 10:27 AM   #141
gtpvette
Drives: 2015 FRS - FFR GTM
Originally Posted by ILLSMOQ View Post
I see that. T56 and others have a slip yoke. Any idea on how to get a good measurement?
Good question,, not sure I have a good answer. I would guess the tailshaft housing might work,,, wonder if measuring off crank pulley would be the same??
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
The Following 2 Users Say Thank You to gtpvette For This Useful Post:
all4spl (08-15-2017), ILLSMOQ (08-15-2017)
Old 08-15-2017, 11:23 AM   #142
ILLSMOQ
Drives: 2017 WR BLUE BRZ
At least that would get you pretty close I'd think.
ILLSMOQ is offline   Reply With Quote
Old 08-15-2017, 05:27 PM   #143
NOHOME
Drives: RAVEN
It's not rocket surgery, get it close and call it good. Off the back of the transmission works fine. The balancer darn well better be the same angle!
NOHOME is offline   Reply With Quote
Old 08-20-2017, 07:05 PM   #144
gtpvette
OK,,, some good news. Yes,,, the Holden pan bolts right up. It straddles the cross member and the motor mounts plates should work. I will need to make a new hood.
The Following User Says Thank You to gtpvette For This Useful Post:
Sportsguy83 (08-21-2017)
Old 08-20-2017, 07:19 PM   #145
gtpvette
pics
Old 08-21-2017, 07:31 AM   #146
gtpvette
Couple of additional thoughts. Inside of motor is super clean which is good. I didn't seal the pan as of yet,,, just in case it needs mods. BTW,, getting the crank pulley off was a complete pain.
Clutch master will be an issue as the HP pump stuff is right there. It'll be the next thing I work on. Not exactly sure what will happen,,, recess it maybe with a remote fill.
AC expansion valve location should be OK,, I'll just skip the heat stuff for now. Don't need it here anyway.
Trans isn't in yet but based on my measurements the stock cross member location may just work with the way the mount on the trans is.
It be a whole lot easier to fab the mounts with a bare block. Having the motor hooked to the picker makes it tough getting in there
The motor is still a little high in these pics. I'm guessing I'll shoot for about an inch between the cross member/rack and the pan. How much space are you guys ending up with??
Exhaust on the drivers side will be tight with the starter there.
Old 08-21-2017, 09:53 AM   #147
-Willis-86touge
Drives: Stock
Looks a little tall
-Willis-86touge is offline   Reply With Quote
Old 08-21-2017, 03:35 PM   #148
gtpvette
Originally Posted by -Willis-86touge View Post
Looks a little tall
It is no doubt. Modding or making a hood is doable,,, but I worry about the aesthetics as I tend to like a more stock exterior. I'll do some quick measurements tonight.
Still diggiing this one. Fender shape is simular to FRS so it works pretty good. I'd certinally want the smallest version possible though.
Old 08-27-2017, 08:28 PM   #149
gtpvette
Peek-a-Boo Clutch MC,,, recessed 2",,, will start on motor mounts next week
The Following 3 Users Say Thank You to gtpvette For This Useful Post:
DustinS (09-05-2017), Sportsguy83 (08-28-2017), venturaII (09-05-2017)
Old 09-03-2017, 06:56 PM   #150
gtpvette
Well,, had to finish up the clutch master which I did. All seems to be good. It's 4 1/4" from the face that bolts to the firewall to the leading edge of the clevis. I opted to drill out the OEM clevis and weld in a 5/16 24 bolt. Everything seems to fit just right.
I've ordered some filler, primer and spray paint to cover the firewall where I've taken out the brace support.
I had thought I'd start on the motor mounts but opted to blow apart the wiring harness. I have a bunch of question for the guys that came before me,, but I'm short on time tonight.
Off to Las Vegas tomorrow for the Ron Fellows driving school. Thrashing someone else's Corvette for a few days sounds like lots of fun!!!
tirespin782 (09-04-2017)
Old 09-03-2017, 10:41 PM   #151
all4spl
looks good bud. I need to start my log soon. I just removed the trans mount brace which sucks ass!
all4spl is offline   Reply With Quote
The Following User Says Thank You to all4spl For This Useful Post:
Sportsguy83 (09-05-2017)
Old 09-04-2017, 05:22 AM   #152
gtpvette
I tried using the spot weld bit on that brace mount. Broke 3. Ended up using the cut off wheel to finish it off. Not looking forward to the trans brace,,, hoping it can stay.
Old 09-05-2017, 09:28 AM   #153
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
That was a really good ideal recessing the clutch master like that. Didn't even think about that on mine. I really like it.
Assuming you got the spot weld bits from harbor freight? They suck pretty bad, I went through quite a few. Using a center punch and starting slow seemed to work best for me. I also found that they would either break early, or do well until they got dull. Pretty sure I wore two of them out.
Old 09-05-2017, 10:16 AM   #154
all4spl
I will tell you guys. When I did the trans tunnel brace, I swapped back and forth with the drill and I actually bought a 3/8" belt sander at HF and sanded the welds enough to separate them with a screwdriver and hammer. Worked pretty well. Do you have any pictures of what it looks like on the other side of the engine bay for the clutch master?
Should I have just got a new motor? SoundsOfTheUniverse Issues | Warranty | Recalls / TSB 12 07-31-2017 07:51 PM
Seized motor!! What STX mods should I do while I have the motor out?? BlaineWasHere Tracking / Autocross / HPDE / Drifting 27 12-11-2014 02:39 PM
K2 Motor? Ronin Sascha Engine, Exhaust, Transmission 8 08-16-2014 06:51 PM
Does every motor say #1 sosick Engine, Exhaust, Transmission 21 05-05-2014 09:28 AM
MOTOR UNION David Southern California 0 06-22-2013 01:32 PM
