Old 06-28-2016, 12:20 PM   #15
jcw99
Drives: swp mt '14 brz premium
I'm keeping my fingers crossed for you
jcw99 is offline   Reply With Quote
Old 06-28-2016, 09:54 PM   #16
BRZnut
Drives: BRZ DGM Limited
Wow..that would be something if that is it! How did you know that the pump was bad??
Old 06-29-2016, 01:43 AM   #17
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
I don't but there have been multiple confirmed cases of automatics with the same sound from the same area being fixed with the vacuum pump replacement. I can't find anything wrong with the one I removed but I can certainly see how the clanking sound can be generated by this pump. She's all installed but I'm going to wait until the morning to let the gasket paste seal up.
nlowell is offline   Reply With Quote
The Following User Says Thank You to nlowell For This Useful Post:
Tcoat (06-29-2016)
Old 06-29-2016, 10:35 AM   #18
nlowell
nlowell's Avatar
That was it! She started right up, no stalling, no metal knocking noises and purring like a kitten.
Wow, just wow!
I've been chasing this issue for a year with a full engine build and had two tuners working on the stalling issues...
Damn vacuum pump!
The Following 7 Users Say Thank You to nlowell For This Useful Post:
go_a_way1 (11-23-2016), humfrz (06-29-2016), jcw99 (06-29-2016), jwvand02 (06-29-2016), Tcoat (06-29-2016), Ultramaroon (06-29-2016), XanRules (06-29-2016)
Old 06-29-2016, 04:41 PM   #19
Wow, just wow!
Damn vacuum pump!
Thanks for the update.
Something else to add to the list of possible suspects ......
Tcoat (06-29-2016)
Old 06-29-2016, 04:47 PM   #20
Wow, just wow!
Damn vacuum pump!
Congrats, man! Well done!
Tcoat (06-29-2016)
Old 06-30-2016, 08:09 AM   #21
BRZnut
wow great to know!! I noticed oil on the one on the left. Do these pumps get oil circulation from the engine? How hard was it to replace???
Old 06-30-2016, 09:41 AM   #22
nlowell
nlowell's Avatar
Yes, the oil appears to lubricate the internals. It was clean until I turned the key a bit and it spit out oil.
Install is a breeze. Top access, 3 10mm bolts torqued to 12.5 ft lbs.
You need to clean the old gasket seal off of the engine, test fit the new pump to get the key on the right position, apply seal paste to the new pump (I used the black gasket maker variant). Apply the paste in a complete circle on the outer edge of where the pump contacts with the engine. Install pump and torque bolts to 12.5. Wait 12 hours for the gasket to set.
This is what I did but the gasket instructions say to let it dry before torquing down the bolts and they suggest waiting 24 hours. If it leaks I'll just re-seal it.
Going slow it took me 20 minutes.
Oh, and don't forget to replace the little Oring behind the pump - $1 part,
Old 06-30-2016, 03:57 PM   #23
nlowell
nlowell's Avatar
Update - I'm leaking oil - I didn't put enough gasket maker on, I didn't wait long enough before torquing it down and I didn't wait long enough to drive it.
I'll be redoing it this weekend - lol
Old 06-30-2016, 04:17 PM   #24
Well, grasshopper ......
Old 11-23-2016, 10:46 AM   #25
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Omg sorry to bump this but THANK YOU!! I think this is the issue I have had for 3 years (no stalling yet though)
Old 08-29-2017, 04:51 PM   #26
TheBRZsKnees
TheBRZsKnees's Avatar
Drives: 2014 BRZ
Video links are dead. Any way I could get another link? I suspect I have the same issue, but I'm not sure. I'll be grabbing recordings today.
TheBRZsKnees is offline   Reply With Quote
Old 08-29-2017, 07:05 PM   #27
OP hasn't checked in since July. Are you still under warranty?
Old 08-30-2017, 10:20 PM   #28
TheBRZsKnees
Drives: 2014 BRZ
Not even remotely. I have a boosted 2014 with a rebuilt title
Been hearing the sound for over a month now. No performance issues though. Only happens after driving for a while, and really only audible between 1000 and 2000 RPM. If I shut the engine off and turn it back on immediately, the noise doesn't come back until I drive for a while again...
Still gotta grab the sound clip.
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 11:09 PM
FR-S Rod knock pozer Issues | Warranty | Recalls / TSB 95 11-03-2015 10:39 AM
Oft knock brady86 Software Tuning 26 07-15-2015 11:14 PM
Metal on metal noise at 2500 RPM ssyed Issues | Warranty | Recalls / TSB 2 09-08-2014 05:01 PM
Metal on metal scratching noise front left wheel Ezk1el Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 08-11-2014 01:00 AM
