Old 08-24-2017, 01:39 AM   #1
Nobunnyhere.86
Drives: Scion FRS
Shifter/Transmisson Rattles
Sorry if this is already a thread somewhere but , my car is a 2016 frs and the day I bought it off the lot I heard a rattle when at low and mid rpms , like going over a speed bump or slow rolls in traffic. I hear the rattle/clunking near my shifter and is extremely noticeable outside the car as well. noise does change as I put pressure against shifter and noise stops when I am out of gear...
Toyota told me it was normal . I am waiting for something to blow and them say they cant warranty it out . that's when madness will start. SMHHH
Anyone have an idea or has had the same issue??
Nobunnyhere.86 is offline   Reply With Quote
Old 08-24-2017, 07:20 AM   #2
Kimviklund
Drives: 2017 Brz
Actually I have the same noise on my 2017 brz. Its below 2300rpm and sounds like something is loose.
Kimviklund is offline   Reply With Quote
Old 08-24-2017, 10:20 AM   #3
Nobunnyhere.86
Drives: Scion FRS
Yes , have you got it checked yet? I am going to keep going to Toyota in till they fix it or give me a new car��
Old 08-24-2017, 12:05 PM   #4
Did you buy the car new..??
How many miles on your car ..??
Do you have a short shifter installed .. ??
Old 08-24-2017, 04:05 PM   #5
Nobunnyhere.86
Drives: Scion FRS
Yes brand new off the lot, currently have 14k miles and no it is all oem.
Old 08-24-2017, 04:14 PM   #6
I'd suggest that you go to a dealership and ask to drive another car like yours ..... just to compare.
If the other car's shifter doesn't rattle you have another piece of information to support your concern.
If the other one "rattles", most likely that's just the nature of the beast.
Old 08-24-2017, 04:16 PM   #7
My guess is that the exhaust is misaligned and hitting someplace at certain RPMs.
Old 08-24-2017, 07:04 PM   #8
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
On my '17 had some shifter rattle too and aftermarket Reverse thing. Took them off and wrapped everything with some thread seal tape. Also the top decal on top of the stock shift knob is not glued that great got some epoxy up inside of it. That with a louder exhaust haven't noticed anything since
SuperTom is offline   Reply With Quote
Has anyone found a solution to Kartboy shifter rattles and noises? oliverc Engine, Exhaust, Transmission 1 06-16-2015 07:25 PM
Shifter rattles after CF driveshaft install? Venz1028 Engine, Exhaust, Transmission 5 03-28-2015 03:43 AM
Coilover rattles.. HELP TwoFourFive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 04-14-2014 04:56 PM
Hard to fix rattles qoncept Electronics | Audio | NAV | Infotainment 6 07-17-2013 04:32 AM
Rattles & Vibrations brian_c_m AFRICA 65 03-22-2013 04:07 PM
