Old 04-10-2014, 10:45 PM   #1
TwoFourFive
TwoFourFive's Avatar
Drives: 13 HOT LAVA
Coilover rattles.. HELP
Hey guys I just installed a set Of Ksports and hear a rattle and clunk noise coming from all around. It's only when I drive slow when I am up to speed it's gone. Why could this be please help!
TwoFourFive is offline   Reply With Quote
Old 04-14-2014, 03:32 PM   #2
cortrain
Drives: Whiteout FRS
Check the preload on your springs. If you have two collars on the lower portion of the spring you'll need to loosen them then tighten the spring (upwards) so it doesn't have any movement. Your instructions should mention preload. If not, just google it and you'll get what Im trying to say haha.
Also, could be your top nut not torqued to the proper spec if you used stock top hats.
Or, you fucked up your end link in the install.
I'd check the preload first.
cortrain is offline   Reply With Quote
Old 04-14-2014, 03:56 PM   #3
TwoFourFive
Drives: 13 HOT LAVA
Sorry forgot to update this ha. I fixed the problem it was my sway bar end link that was a little loose that's all
Rattles/Squeaks in the BRZ? cammyfive BRZ First-Gen (2012+) — General Topics 190 01-12-2017 10:24 PM
To those who modified their cars...rattles!? FutureFT86 Scion FR-S / Toyota 86 GT86 General Forum 15 10-11-2013 05:58 PM
Hard to fix rattles qoncept Electronics | Audio | NAV | Infotainment 6 07-17-2013 03:32 AM
Stereo rattles FR-anco89 Issues | Warranty | Recalls / TSB 2 04-19-2013 07:44 AM
Rattles & Vibrations brian_c_m AFRICA 65 03-22-2013 03:07 PM
