Old 07-04-2012, 05:54 PM   #43
motofan
Drives: 10 VW GTI
Originally Posted by R Corse View Post
Can we get confirmation on this?
Can you scan/post this?
It is here. http://www.ft86club.com/forums/showthread.php?t=8374
It's the BRZ version but I believe the scion version is the same.
motofan is offline   Reply With Quote
Old 07-04-2012, 06:18 PM   #44
EsoBOFH
Senior Hoonigan
EsoBOFH's Avatar
Drives: 2016 Hot Lava 6MT FR-S
Actually, I am wrong. The first item in the "under the hood" section is "check ATM fluid levels". When I glossed over this earlier my mind read "check tranny fluid levels"....
So yeah, it stands to reason that the dealer may not check the levels on an MT, given its bolts that need to be undone - unless its in the "on the hoist" section. I can't confirm as I'm away from my PC.
Sent from my Galaxy Nexus using Tapatalk 2
2016 Hot Lava 6MT FR-S, Surrey, BC Canada
EsoBOFH is offline   Reply With Quote
Old 07-04-2012, 06:30 PM   #45
R Corse
Drives: Ducati R Corse
So it is fairly clear then that it may not be required of the dealers to inspect the MTM Gear Oil; just leaks (Visual Inspection). Those dealers that go above and beyond to make their consumers special are the winners. Scion/Toyota and the Factory here is apparently an issue. I hope the best for the owner of that vehicle.
R Corse is offline   Reply With Quote
Old 07-04-2012, 07:05 PM   #46
Kearny Mesa Scion
Drives: It's Slow but it Handles.
Originally Posted by ruskymx View Post
On Saturday, there was a Whiteout FR-S that came in on a tow truck. My first though was about the idle issue and maybe it was stalling, etc. I spoke with the tow truck driver briefly and he said there was transmission issues. It wasn't shifting into gear, especially into reverse like it should. I first though that maybe the driver jammed it into reverse without using the collar and broke something. I was wrong....way wrong.
I had to go to the parts department this morning and I was talking with the guys back there and they informed me of what happened. The original dealer's service department did a half-assed PDI and never checked the trans fluid. Apparently, it left the factory empty! It was bone dry when our tech checked it out! It only has 600 miles on it too, but I guess that's pretty good to last that long with no oil. My dealership was not the original dealer FYI. I'm going to see if I can find out who it was and maybe do some bus driving over a competitor.
I'll admit though, it makes me a little nervous because I rushed one of our techs through my PDI because it came in near the end of the day.
Update (since I didn't finish my post all at once, I grabbed a pic in the mean time of the offending dealership):
There were quite a few mistakes here. First the factory that built the transmission, then the Subie plant, and finally the dealer. Parts department told me the transmission is just shy of $6,300!
BTW, I would make them take that sticker off for sure.
Ruskymx
no transmission fluid? all cars leave the factory with engine oil and the neccessary fluids for it to be driveable for shipping that's not part of the Pre-Delivery Inspect. the only fluids that's not filled to the brim is the washer fluid.
sounds fishy...
Kearny Mesa Scion
San Diego's #1 Volume Dealer Since 2003
www.kmscion.com
Kearny Mesa Scion is offline   Reply With Quote
Old 07-04-2012, 07:28 PM   #47
R Corse
sounds fishy...
Kearny Mesa is by me. Something about 600 miles on the ODO and being "Bone Dry" is fishy....
There would be remnants of oil if it drove 600 miles. I had a shotty shop and warranty company change out my trans several times. On one occasion, they put the trans back in with no oil (it was used and had whatever oil was sitting in it that wasn't drained out; new trans still have oil on the internals when assembled). I made it all of 23 miles before it burned up and seized. This was 7 years ago and I still remember it. Pissed me off because I had to buy a New trans for my car since both the selling dealer and warranty went bankrupt.
Old 07-04-2012, 08:35 PM   #48
motofan
Drives: 10 VW GTI
I would say so. It this can be brought up to the top leve, the factory should have the record showing which technician was in charge of putting the oil in and there should be an inspection/quality control person who failed as well.
(Not-so-related: When my friend got the FRS, the radio was not in yet. I can see there was a stamp on a steel beam inside. The stamp showed a Japanese surname (some like 清水) and a date mark. I think that can be a QC mark)
Old 07-05-2012, 01:23 AM   #49
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
It's clear that there is more going on than a simple "it didn't have oil", it clearly had some, maybe not enough. Maybe some leaked out, maybe there were other issues.
Whoever has the car now will check what is wrong and fix it, and if there is something fishy going on, I hope Toyota will check into it further, or that it has been reported to the correct people. (In Canada this would be done via an FPR, and probably followed up on by Toyota).
As for checking the fluid on the PDI sheet, I didn't just assume it wasn't on there, I looked up the PDI sheet and checked before posting.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 07-12-2012, 10:55 PM   #50
ruskymx
ruskymx's Avatar
Drives: 13 HotLava FRS, 93 4Runner, 97 Taco
Update: The new tranny came in and our techs installed it. I was able to grab a pic while they were finishing up. The tech was topping off the tranny with fluid to make sure there was enough in there so this wouldn't happen again.
I did talk to the tech a little and he said there was a little bit of oil in the old tranny but no where near the amount required. He said maybe around a quart of fluid if that. He also said that the transmission is very light for a transmission. He was surprised as to how little it weighed. There were no signs of the fluid leaking out. The undercarriage was very clean where if there was fluid in the transmission and a seal was bad, there would be oil all over the place under the vehicle or at least visible spots where it was leaking.
I think the owner should be able to pick his car up and enjoy it like he expected to the first time around.
Ruskymx
ruskymx is offline   Reply With Quote
Tow hook specs? mufasis BRZ First-Gen (2012+) — General Topics 15 10-21-2012 10:41 PM
Tow-hook license-plate template? TuxedoCartman Cosmetic Modification (Interior/Exterior/Lighting) 5 06-24-2012 12:51 PM
Whiteout FR-S At Kenshaw rL-gT CANADA 17 05-26-2012 05:06 PM
Whiteout FR-S/86 just86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 15 04-01-2012 01:16 AM
Delete driver01 Scion FR-S / Toyota 86 GT86 General Forum 17 03-28-2012 12:32 PM
