Old 08-14-2017, 01:31 PM   #1
Codym33
Drives: 2016 Brz
2016 Brz daytime running lights - condensation / moisture
Hey everyone
Just recently bought a 2016 Brz and since the first rain (2 months ago) there has been moisture in my running lights... Ive contacted my dealer and they say its normal and if I wanted they could drill holes in the back to let them drain...... really????
Anyways has anyone else gotten this issue? found a fix? found good aftermarket repacements?
Any input would be appreciated
Codym33 is offline   Reply With Quote
Old 08-14-2017, 02:21 PM   #2
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Originally Posted by Codym33 View Post
Hey everyone
I too have experienced this from time to time. I tried checking the connections to the back of the strip and found no solution. I haven't been able to replicate it for the techs at the dealership either. They won't take my pictures as validation, unfortunately. Luckily, I haven't had any of the LEDs go out.
DaBoBo21 is offline   Reply With Quote
Old 08-14-2017, 03:11 PM   #3
Codym33
Drives: 2016 Brz
At least yours appear to dry, considering you cant replicate it.
mine have remained like this since i bought the car. kinda silly....
The Following User Says Thank You to Codym33 For This Useful Post:
DaBoBo21 (08-14-2017)
Old 08-14-2017, 03:29 PM   #4
norcalpb
norcalpb's Avatar
Use a heat gun to heat up the adhesive and remove the lense. Use new silicone glue to reseal.
Old 08-14-2017, 03:42 PM   #5
Codym33
Drives: 2016 Brz
Do not do this!!! This will not fix the issue!!!
zzzz I decided to take a look into the issue a bit further, turns out the special people of subaru decided to just have a wire go through a rubber boot, its literally open at the back, enough for it to condensate but not enough for it to dry.... that explains why they said its normal, because they literally cant fix it.
nice.
Old 08-14-2017, 05:38 PM   #6
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Gotcha gotcha. It's pretty dry here in my region of Texas, so that may be why mine are dry at the moment. Though, in February and March I had condensation just about every other day in the morning. It would be dried out by the evening, though. I hope you find a fix man. Good luck!
Old 08-14-2017, 06:11 PM   #7
Joon525
Joon525's Avatar
Drives: 2016 BRZ
nice.
Maybe get some silicone gasket maker and seal it up yourself?
Just a little sounds like it would work.
Joon525 is offline   Reply With Quote
Old 08-14-2017, 07:50 PM   #8
MalcolmHimself
MalcolmHimself's Avatar
Drives: 2015 BRZ
Mine did that, I just got the JDM bezels and cut those bitches out ✌️
MalcolmHimself is offline   Reply With Quote
condensation, running light
LED daytime running lights sav AFRICA 168 03-22-2016 05:26 AM
best LED daytime running lights trigger happy Cosmetic Modification (Interior/Exterior/Lighting) 8 11-15-2013 11:00 PM
Front LED Daytime Running Lights myjobis2pimp NY / NJ / CT / PA 0 04-18-2013 06:47 AM
***FR-S/BR-Z LED Daytime Running Lights 6K White*** Vicious LED Exterior Parts - The Rest 7 10-14-2012 04:38 PM
daytime running lights JDMrolla Scion FR-S / Toyota 86 GT86 General Forum 2 06-06-2012 11:09 PM
