Old 08-10-2017, 11:56 AM   #1
bravedeer
Drives: Subaru BRZ 2013 Limited Manual
Downshift from 6th to 5th at high speed
Hi folks,
I picked up a 2013 BRZ a couple months ago, and the first thing I tested on my test drive was to see if this issue was present with this car, and it was not. However, a couple days ago I had the dealership perform transmission service and now it has the same issue my first BRZ had: when you shift from 6th to 5th at 70mph+, there's a synchros crunch.
I'm going to have my local mechanic put Motul 300 to see if resolves the issue, but a question, how many of you had this issue resolved by the tranny fluid?
Thanks!
bravedeer is offline   Reply With Quote
Old 08-10-2017, 12:51 PM   #2
bababooey
Drives: BRZ SWP Limited -6MT
reading other's responses on WHICH fluid relieves symptoms is hit or miss. possibly due to local climate conditions, but not telling if brand mentioned will solve problem.
bababooey is offline   Reply With Quote
Old 08-10-2017, 12:56 PM   #3
If it wasn't there before the service but was after then changing the fluid is probably not the answer. What was the "service"? What could it have changed? I would talk to whoever performed it and see what they have to say before I did anything.
Old 08-10-2017, 01:00 PM   #4
bravedeer
All they did was replace whatever fluid was in there (no way to know) with the OEM Subaru fluid. They did both the transmission and differential. Nothing else was done to the car.
Old 08-10-2017, 01:26 PM   #5
Ahhhhh. Well in that case then maybe the different fluid would indeed be worth a shot.
Old 08-10-2017, 01:52 PM   #6
fang_gt86
FR Noob
fang_gt86's Avatar
My '13 was completely fine until 15k when I had Toyota flush out tranny/diff fluid. I got 65k now and 5th gear still grind but I just live with it.
This is what I do to minimize grinding:
* Precise and quick shift and no granny shift.
* No rev match shift. Yes, my 5th gear hates rev match.
* No down shift above 3k.
* E85 also minimize 5th gear grinding. Weird right? But it does helps..
"I'm having too much fun to care about horsepower" - Unknown
6MT FR-S Whiteout:OFT- OTS V2 Stage 2 (93oct & E85), Tomei UEL, Invidia OP, JDL UltraQuiet FP, Ark Grip catback, GS hood struts, Perrin Inlet & K&N drop-in
fang_gt86 is offline   Reply With Quote
Old 08-10-2017, 02:26 PM   #7
That is very weird. Any theory on how a different fuel affects the shift?
j3rf (08-30-2017)
Old 08-10-2017, 02:35 PM   #8
bravedeer
Hate to say it but no down shift above 3K is unacceptable. If you want to speed up when you're at 70mph and can't downshift, then you might as well drive a Prius...
Worst case scenario is I'll do the same as I did with my first BRZ, request a new transmission from Subaru. But the process is a pain in the ...
Old 08-10-2017, 02:46 PM   #9
fang_gt86
FR Noob
fang_gt86's Avatar
I'm not sure but E85 vs 93oct is like night and day for both engine and tranny. Im struggling with my clutch work on 1st from stop with 93. But it's butter smooth with E85..
The Following User Says Thank You to fang_gt86 For This Useful Post:
Tcoat (08-10-2017)
Old 08-10-2017, 02:50 PM   #10
I get the engine but am baffled how it has any possible impact on the tranny.
HunterGreene (08-10-2017), JazzleSAURUS (08-22-2017)
Old 08-10-2017, 03:02 PM   #11
fang_gt86
FR Noob
fang_gt86's Avatar
My wild guess is that smooth engine means smooth tranny?
Tcoat (08-10-2017)
Old 08-10-2017, 03:05 PM   #12
Pretty smooth engine on gas too though. Maybe somebody will jump in and enlighten us (thank god Gforce/the Ubertwins can't).
HunterGreene (08-10-2017), Icecreamtruk (08-10-2017)
Old 08-10-2017, 03:05 PM   #13
fang_gt86
FR Noob
fang_gt86's Avatar
I just floor it on 6th. It's not that bad at 70mph on E85 lol. But then mine's got about 25hp over stock
Old 08-10-2017, 03:15 PM   #14
HunterGreene
Hail Magnet
HunterGreene's Avatar
The only times I can think of needing to downshift at 70+ mph is 1) Emergency 2)Track racing and 3) driving like an asshat. In the time it takes me to rev-match, downshift and floor it, gaining the necessary speed to pass, I can just put the pedal down in 6th and be going as fast as I need to, frankly. Might as well save your clutch if you are just on the highway.
p.s.--the fuel does not come in contact with the transmission, which is what I think @Tcoat is trying to get at. The assertion that E85 somehow makes your shifting smoother is pure butt dyno.
EDIT: This is with my stock FR-S. Using e-85 or FI, even a tune might change the most effective parts of the powerband. That said, still seems unnecessary to me.
It has priests in it?
The Following 3 Users Say Thank You to HunterGreene For This Useful Post:
Icecreamtruk (08-10-2017), jcw99 (08-12-2017), Tcoat (08-10-2017)
Downshift to 1st at low speed 86wtywly Scion FR-S / Toyota 86 GT86 General Forum 34 09-12-2016 01:53 PM
High RPM for current speed HachiRo Engine, Exhaust, Transmission 14 04-02-2015 03:59 PM
Hood flutter at high speed TheseColorsDontRun Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 09-10-2013 11:39 AM
Brakes unless at high speed - what to tackle? empower-auto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 10-12-2012 06:06 PM
Video: BRZ / FR-S High Speed Run to 124 MPH (200 km/h) Levi BRZ Photos, Videos, Wallpapers, Gallery Forum 43 05-16-2012 01:37 AM
