Old 07-29-2017, 11:23 PM   #43
Originally Posted by xZAMx View Post
Damn this thread is full of ADHD...That being said, I went to the dealer complaining about a grinding noise when shifting 3-4 in high revs. They said they would replace the synchros, but not the transmission. I wonder if this will have the same positive affect as your transmission replacement.
Are you sure you understood them correctly .. ??
I understand that most auto dealerships would choose to replace transmissions, rather than to rebuild them ......
Old 07-29-2017, 11:31 PM   #44
Terruko
Terruko's Avatar
Last time I took my car to the dealership was because the TOB was going out, and I mentioned the grinding noise to the service guy, he ended up telling me they couldn't replicate the sound and I left it at that.
Terruko is offline   Reply With Quote
Old 07-31-2017, 12:50 PM   #45
Terruko
Terruko's Avatar
So I left the car at the dealership and they said maybe the grinding at low rpms was caused by a bad clutch 🤔
Old 07-31-2017, 02:28 PM   #46
This specific low rpm "grinding," is this when shifting into gear, or is it just rolling on the throttle?
Old 07-31-2017, 02:31 PM   #47
xZAMx
Drives: '13 FR-S - Hot Lava
Yes she said they would replace the synchros and not the transmission. I'm a little worried about the whole procedure tbh...
So they just took your word for it and replaced it?
They did, but they also took it for a drive to confirm the problem.
xZAMx is offline   Reply With Quote
Old 07-31-2017, 03:00 PM   #48
Well, xZAMx ...... not to worry. If the dealership figures they can rebuild the transmission (replace the synchros), I'd figure they would know how to put it back together.
Rebuilding a manual transmission is not rocket science ....... even ol humfrz has done that ..... back-in-the-day........
Old 07-31-2017, 05:14 PM   #49
xZAMx
Well that makes me feel a little bit better =). I still have ~1.75 years left on the PT warranty so if anything happens, they'll be cleaning up their own mess.
The Following User Says Thank You to xZAMx For This Useful Post:
humfrz (07-31-2017)
Old 07-31-2017, 07:00 PM   #50
Terruko
Terruko's Avatar
Dealer called and said I have a bad transmission and that they'll replace it
Old 07-31-2017, 07:46 PM   #51
Terruko
Terruko's Avatar
It happens when I put it on first and give it gas, it grinds until 1.5k rpms then stops. It started happening after they replaced the throwout bearing.
Old 07-31-2017, 08:00 PM   #52
Oh, jeez, I went back and reviewed. Did you ever have the fluid level checked?
That's not grind. That's gearbox rattle from the engine lugging.
Old 07-31-2017, 08:07 PM   #53
Terruko
Terruko's Avatar
Synchros going bad?
I didn't get to check transmission fluid. So I'm driving the wrong way? The car didn't make that sound before the TOB was replaced though, it started AFTER it was replaced.
If I want to avoid that grinding/rattling sound I have to get it up to 2.5k-3k rpms before releasing the clutch. Before the TOB was replaced I used to get it to 1.5k and slowly release the clutch.
Oh and this is from neutral to 1st we're talking.
Old 07-31-2017, 08:26 PM   #54
Ya know, Terruko, I've found out, over the past 70 years of driving things that have mechanical parts that are lubricated, that if those parts start acting up or making noise, the first thing to do is check to see if they are properly lubricated.
In other words ....... I suggest (again) that you check the transmission oil level ....... get it .....??
Ultramaroon (07-31-2017)
Old 07-31-2017, 08:53 PM   #55
I'm not sure of anything at this point. I see what you mean about starting out in first. Maybe it's clutch chatter?
Like humfrz said. Have the fluid checked. Show them the grind/chatter. Do that first.
After that, if you can make/post a recording, I'd be glad to give it a listen. Beats spitting into the wind.
edit: oh, I see you posted earlier. New transmission. Good.
Old 08-01-2017, 02:51 AM   #56
Terruko
Terruko's Avatar
Here's the rattle I'm talking about
It's a video a recorded but the sound isn't that good.
Synchros finally starting to die? Bushhy Engine, Exhaust, Transmission 6 12-09-2016 12:22 PM
Synchros problem? FRiSson Issues | Warranty | Recalls / TSB 191 06-21-2016 05:27 PM
Are My Synchros Going Out? Scavanger Scion FR-S / Toyota 86 GT86 General Forum 11 11-20-2014 01:29 AM
Swap out OEM clutch, OEM synchros/gearbox brzadmir Engine, Exhaust, Transmission 19 05-04-2013 04:13 PM
Synchros followup FRiSson Scion FR-S / Toyota 86 GT86 General Forum 7 08-31-2012 03:38 PM
