Old 07-27-2017, 05:40 PM   #15
Car won't start.
I was just going by what the OP posted yesterday ....... which indicated he had checked the voltage the alternator was putting out.
"Hi Tcoat, Yes Engine is fully stock no mod
Just check the Alternator still good and charging battery 11.6v
Battery measure at 12.6v
Compression on all Cylinder is within spec at 135 PSI
Check all the relay and Fuses non blown or damage"
Old 07-27-2017, 09:39 PM   #16
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
11.6 is low voltage for an altenator but not low enough that the car would stall. You'd get the check charging system light. But that is only voltage, do you have open phase or bad diodes? How's the ripple?
What is the fuel pressure? the fuel pump working only tells you if the in-tank fuel pump is working, but what about the HPFP? What's the pressure? Insufficient pressure from a working fuel pump will cause the car to stall out.
guybo is offline   Reply With Quote
Old 07-27-2017, 09:45 PM   #17
cnxmist
Drives: 2013 Subaru Brz Limited Automatic
@ Guybo Thank for the lead, I'll get those check out
cnxmist is offline   Reply With Quote
Old 07-27-2017, 10:25 PM   #18
Originally Posted by cnxmist View Post
HELP!!! my car (2013 Subaru BRZ Limited Auto) was running the other day, and suddenly stall out on me on the freeway, now it crank over but doesn't start, the only code that was stored prior to the incident is P0031 and P0560. Any info lead to fixing would be appreciated
- replaced the O2 Sensor
- Check Battery and replaced
Car was running on Fwy then lost power = stall out didnt start after that
How exactly are you measuring 11.6 from the alternator if it won't start?
Old 07-28-2017, 12:26 AM   #19
I caught that too but let it go earlier - quick reading breaks.
So, for funzies I just disconnected the accessory belt and started it to prove it would run on battery alone. Didn't want to assume it would.
OP, does the starter crank over the engine like the battery has a full charge? If yes, it's not the alternator because the charging circuit and battery are fine.
humfrz (07-28-2017)
Old 07-28-2017, 06:44 AM   #20
guybo
Huge E85 fan!
guybo's Avatar
somebody mentioned something about removing the alternator from the car to test it so I figured that's what he did. I should hope he knew enough not to get a voltage when the engine was cranking over but not starting.
With the batt voltage being good, it wasn't the alternator that made the car stall. The car would run until the volatge got so low it could not provide spark then die. The low voltage CEL is a red herring. That CEL probably came up after the car died. We really need more info from that CEL on what the car was doing when the CEL came up- but you need a better scan tool than a bluetooth code reader for that.
Engine Won't Crank - Battery or Worse - Sanity Check StrangeLove4791 Issues | Warranty | Recalls / TSB 16 02-23-2017 12:18 AM
Car won't start, won't crank, no ecu communication redlined600 Issues | Warranty | Recalls / TSB 10 07-09-2016 01:55 PM
Car Won't Start.. No Lights.. Not a battery or fuse issue.. pleong Scion FR-S / Toyota 86 GT86 General Forum 11 09-23-2015 05:45 PM
No crank no start issue *KID* Issues | Warranty | Recalls / TSB 3 09-29-2014 07:22 AM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 07:06 PM
