Old 07-26-2017, 11:14 AM   #1
D-rek07
High pitch noise in 6th gear
Hi,
In 6th gear (MT) between 72 and 80 mph (3200-3700 rpm?), there is a high pitch ringing only when I'm on the throttle. It's hard to tell if the noise happens when it lower gears at that rpm because the engine noise is louder. Anybody else have that problem?
Engine is completely stock. Just hit 45,000 miles. It does it on all roads. Tire pressure is fine. I don't know if it has always done it or I have just started noticing. I bought it with 28,000 miles on it.
Thank you
D-rek07 is offline   Reply With Quote
Old 07-26-2017, 12:36 PM   #2
Hi,
Do you have any power mods .. ??
Miles on your car .. ??
Does it do that just on certain roads .. ??
Have you checked your tires pressures .... ??
Did it just start doing that .. ??
Come back.
Tcoat (07-26-2017)
Old 07-26-2017, 01:23 PM   #3
D-rek07
Hi,
Come back.
Edited original post. Sorry for the lack of information.
The Following User Says Thank You to D-rek07 For This Useful Post:
Tcoat (07-26-2017)
Old 07-26-2017, 01:37 PM   #4
Thanks for the additional information......
It could be several things:
* you just started noticing it ......
* transmission gear whine
* differential gear whine
I would suggest that you check/change the transmission fluid. Check/change the differential fluid. Even if that doesn't "cure" it ....... at 45,000 miles, it sure wouldn't hurt.
Teseo (08-10-2017)
Old 07-26-2017, 02:21 PM   #5
ChinatownDragon
Drives: 2016 Ablaze FR-S MT
I noticed this exact same thing at that speed/RPM range on my 2016 brand new FR-S during my first week of ownership, so I think it's normal. Most likely gear whine?
ChinatownDragon is offline   Reply With Quote
Old 07-26-2017, 02:51 PM   #6
D-rek07
I changed the transmission and diff fluid with Motul gear 300 at 30,000 miles.
If it's normal, then it's kinda a bummer considering those are freeway cruising speeds/rpms
humfrz (07-26-2017)
Old 07-26-2017, 04:39 PM   #7
Gumberculies
Drives: 2016 BRZ Limited
How loud is the whine? I'll actually have to try to pay attention to mine on the way home and see if I notice anything. If it is normal and the whine isn't too loud, you could get an aftermarket cat-back exhaust and just overpower the whine.
Gumberculies is offline   Reply With Quote
The Following User Says Thank You to Gumberculies For This Useful Post:
D-rek07 (07-27-2017)
Old 07-26-2017, 04:50 PM   #8
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Mine does that and always has. I'm at 67k. The whine is not loud at all and only if you hold that rpm for a couple of seconds. I don't think it's anything to worry about. I also had my trans fluid changed at 60k with mogul gear 300. It goes away if you drive at 3k rpm or like 3.5k rpm. I also think it's a gear whine. You have you have things pretty quiet to even hear it, any music or loud cars near you can make it impossible to hear.
DandoX is offline   Reply With Quote
The Following User Says Thank You to DandoX For This Useful Post:
Exrald (07-27-2017)
Old 07-26-2017, 05:17 PM   #9
Well then, it's most likely gear whine. My 2013 FR-S doesn't do it ..... or I can't hear it.........
Back-in-the-day, when gears would whine ...... we would just put heavier oil in the case, till it would shut up.....
chaoskaze (07-26-2017), Teseo (08-10-2017)
Old 07-26-2017, 09:17 PM   #10
angadam
Drives: 14 BRZ Limited
Hmmm.......I used to get that whine all the time but you may be correct I haven't noticed a bit of it since my cat-back install.
angadam is offline   Reply With Quote
Old 07-27-2017, 12:19 PM   #11
Exrald
Exrald's Avatar
Drives: 2013 Scion FRS & 2022 GR86
Mine would whine too. I think it's common for all cars. My Corolla and Fiesta had it too. You have to be higher than 3000 RPM to hear it. I usually hear it in 78+mph to notice it. You should be fine tho.
2013 Scion FRS @Exrald.frs
2013 Scion FRS
2022 Toyota GR86
Exrald is offline   Reply With Quote
Old 07-27-2017, 12:23 PM   #12
JD001
JD001's Avatar
Drives: Subaru BRZ
Sounds like a turbocharged supercharger thingy ...
Old 07-27-2017, 03:08 PM   #13
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
My BRZ has faint little whine (or ringing) in 6th as well.. Seems normal to me. I kind of like it TBH.
DaBoBo21 is offline   Reply With Quote
Old 07-27-2017, 04:26 PM   #14
Gumberculies
So during my drive home yesterday I didn't notice any transmission or differential whine. However, I have a Invidia N1 Cat-back exhaust which is one of the louder exhausts for our vehicles. So my vehicle is probably not the best to use as a reference.
High Pitch Whine? 636 Issues | Warranty | Recalls / TSB 49 02-06-2016 01:32 AM
High Pitch Exhaust! mnsayer Engine, Exhaust, Transmission 38 09-11-2014 12:49 PM
Extreme High Pitch Noise Daned86 Issues | Warranty | Recalls / TSB 4 02-05-2014 12:44 PM
Fuel Pump high pitch chirp noise lucius AFRICA 9 10-24-2013 03:40 PM
Engine high pitch sound Munki Engine, Exhaust, Transmission 8 10-15-2013 03:11 AM
