Old 07-14-2017, 03:34 PM   #1
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
Weird sounds out of gear w/ AC - 2014 BRZ
Anyone else has this issue? My friend has a BRZ and can't replicate it, also he rarely uses his AC.
When slowing down, I pop it into Neutral. With the AC one, it sounds like it's dragging something or the A/C belt being stretched while running.
It sounds like it's coming from the transmission tunnel, but it could be echoing.
Out of warranty.
Side Note: A/C also causes me to rough idle too (goes under 600rpm) and almost stalled 3x times could be battery/alternator though.
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 07-14-2017, 03:57 PM   #2
hmmm.......is your car a MT or AT ......??
If it's an AT, I believe there is a TSB for idle issues.
OR, maybe the MAF wants to be cleaned .... ??
come back
Old 07-14-2017, 10:01 PM   #3
SmartedPanda
come back
MT, I'm more worried about the loud, sound when cruising with A/C. The idle issue only happened <5 times. I'm still monitoring that.
Old 07-14-2017, 10:31 PM   #4
I'm missing something ..... "loud sound while cruising with A/C" .....??
Would you like to elaborate on that ......
Old 07-14-2017, 10:46 PM   #5
SmartedPanda
Sure, heading towards red light.
Clutch, put car into neutral.
If the A/C is turned on and blasting, a loud screeching can be heard 90% of the time.
It sounds like it's dragging something or the A/C belt being stretched while running.
It sounds like it's coming from the transmission tunnel.
Old 07-14-2017, 11:02 PM   #6
I'm sure it's not down in the tunnel but I get what you're saying about sounds bouncing around.
If you're slowing down in neutral, the idle is raised up over 1000 rpm. Try reproducing the effect while standing still by gently cracking the throttle. Does it make the sound?
Pop that hood open. Have a friend gas it a bit. Might get lucky with just a worn belt.
Old 07-15-2017, 02:09 AM   #7
SmartedPanda
When I'm at the light, it quiets down, it's only during the deacceleration portion it makes noise.
I do it when I get to work, and rev it a bit, doesn't replicate it. I can check while someone else's rev but I don't hear it. I thought that too!
It's strictly only when I'm deacceleration in neutral and the A/C is on anything besides low (2nd level or higher), and it's only 90% of the time. I couldn't replicate it today for example but happened the rest of the this week.
Old 07-15-2017, 03:00 AM   #8
Well, shit.
Does it have to be AC, or will it do it with the fan?
The AC compressor is intermittent with low fan because it doesn't push enough air through the evaporator to put enough heat into it. There's a thermostat in there to keep the evaporator from frosting over. This may explain the intermittent nature of the sound.
If it also does it just with the fan on high then there are other explanations. I'll stop here for now. Don't want to make it too confusing.
Can you get a clip of it?
Old 07-15-2017, 03:28 AM   #9
SmartedPanda
Well, shit.
A/C only!
I didn't know that, I'll try to replicate it today.
I have a dashcam but it doesn't pick it up, I'll try tomorrow driving to work.
Thanks so much about the info.
Old 07-15-2017, 03:59 AM   #10
A/C only!
Hopefully it's leading to something. Good luck. I'm staying tuned.
Car won't start! Making weird sounds. B_Rad Issues | Warranty | Recalls / TSB 35 01-25-2017 06:33 PM
Weird RPM drop in 3rd gear WOT pull ysu Software Tuning 10 07-18-2016 01:18 PM
Stock 2014 is headunit acting weird Thehermdawg Electronics | Audio | NAV | Infotainment 0 05-26-2015 06:35 PM
Weird sounds and liquid dripping from car kam Issues | Warranty | Recalls / TSB 21 05-07-2014 08:01 PM
BEST of Start Up sounds!! More than 70 Exhaust Sounds! JPxM0Dz Other Vehicles & General Automotive Discussions 5 01-08-2014 03:24 PM
