-   Issues | Warranty | Recalls / TSB (https://www.ft86club.com/forums/forumdisplay.php?f=72)
-   -   Weird sounds out of gear w/ AC - 2014 BRZ (https://www.ft86club.com/forums/showthread.php?t=120322)
SmartedPanda 07-14-2017 03:34 PM
Anyone else has this issue? My friend has a BRZ and can't replicate it, also he rarely uses his AC.
When slowing down, I pop it into Neutral. With the AC one, it sounds like it's dragging something or the A/C belt being stretched while running.
It sounds like it's coming from the transmission tunnel, but it could be echoing.
Out of warranty.
Side Note: A/C also causes me to rough idle too (goes under 600rpm) and almost stalled 3x times could be battery/alternator though.
humfrz 07-14-2017 03:57 PM
hmmm.......is your car a MT or AT ......??
If it's an AT, I believe there is a TSB for idle issues.
OR, maybe the MAF wants to be cleaned .... ??
come back
humfrz
SmartedPanda 07-14-2017 10:01 PM
come back
humfrz
MT, I'm more worried about the loud, sound when cruising with A/C. The idle issue only happened <5 times. I'm still monitoring that.
humfrz 07-14-2017 10:31 PM
I'm missing something ..... "loud sound while cruising with A/C" .....??
Would you like to elaborate on that ...... :iono:
humfrz
SmartedPanda 07-14-2017 10:46 PM
Sure, heading towards red light.
Clutch, put car into neutral.
If the A/C is turned on and blasting, a loud screeching can be heard 90% of the time.
It sounds like it's dragging something or the A/C belt being stretched while running.
It sounds like it's coming from the transmission tunnel.
Ultramaroon 07-14-2017 11:02 PM
I'm sure it's not down in the tunnel but I get what you're saying about sounds bouncing around.
If you're slowing down in neutral, the idle is raised up over 1000 rpm. Try reproducing the effect while standing still by gently cracking the throttle. Does it make the sound?
Pop that hood open. Have a friend gas it a bit. Might get lucky with just a worn belt.
SmartedPanda 07-15-2017 02:09 AM
When I'm at the light, it quiets down, it's only during the deacceleration portion it makes noise.
I do it when I get to work, and rev it a bit, doesn't replicate it. I can check while someone else's rev but I don't hear it. I thought that too! :bonk:
It's strictly only when I'm deacceleration in neutral and the A/C is on anything besides low (2nd level or higher), and it's only 90% of the time. I couldn't replicate it today for example but happened the rest of the this week.
Ultramaroon 07-15-2017 03:00 AM
Well, shit. :(
Does it have to be AC, or will it do it with the fan?
The AC compressor is intermittent with low fan because it doesn't push enough air through the evaporator to put enough heat into it. There's a thermostat in there to keep the evaporator from frosting over. This may explain the intermittent nature of the sound.
If it also does it just with the fan on high then there are other explanations. I'll stop here for now. Don't want to make it too confusing.
Can you get a clip of it?
SmartedPanda 07-15-2017 03:28 AM
Originally Posted by Ultramaroon (Post 2946179)
Well, shit. :(
A/C only!
I didn't know that, I'll try to replicate it today.
I have a dashcam but it doesn't pick it up, I'll try tomorrow driving to work.
Thanks so much about the info.
Ultramaroon 07-15-2017 03:59 AM
Originally Posted by SmartedPanda (Post 2946185)
A/C only!
Hopefully it's leading to something. Good luck. I'm staying tuned. ;)
