Old 07-10-2017, 08:05 PM   #1
wrb
frank
wrb's Avatar
Drives: Subaru BRZ WRB
BRZ HID ballast problem?
My left side high beam stopped working.
I've changed the bulb and checked all the fuses multiple times.
Could a ballast malfunction cause this problem?
Low bean works perfectly fine.
2013 SUBARU BRZ WRB LIMITED M/T
Los Angeles, CA
Build Photo Album - http://bit.ly/brz_wrb
SoCal LA 86 Club Member
wrb is offline   Reply With Quote
Old 07-10-2017, 10:58 PM   #2
ryoma
ryoma's Avatar
it's not a ballast problem. your high beam solenoid might be stuck, or a bad fuse. there is no separate bulb or voltage for high beams. once you turn on the high beams, it actuates a solenoid inside the projector that lowers a cut-off plate, revealing the entire output of your bulb. low beams have that cut-off plate up, blocking half of the output of the bulb (hence why there is the flat cut-off)
The Following User Says Thank You to ryoma For This Useful Post:
Ultramaroon (07-11-2017)
Old 07-11-2017, 05:12 AM   #3
wrb
frank
wrb's Avatar
so, how do I check for bad solenoid?
and what other fuse should i check?
i replaced the bulb already and checked fuse and even replaced proper fuse.
Los Angeles, CA
Old 07-11-2017, 09:45 PM   #4
ryoma
ryoma's Avatar
I remember someone mentioning the DRL relay controlling the high beams as well so that would be a good place to start. try having someone stand with their ear next to the projector while you turn on/off the high beams and see if they can hear the click of the solenoid activating.
OEM BALLAST 6spd Want-To-Buy Requests 0 06-06-2016 09:03 AM
WTB: OEM BRZ HID Ballast Cheeto Want-To-Buy Requests 1 02-17-2016 02:12 PM
Blew a ballast? coloradobrz BRZ First-Gen (2012+) — General Topics 13 12-31-2015 08:23 PM
Wtb: 55w h11 ballast Tr1huynh Want-To-Buy Requests 0 03-05-2014 08:40 PM
HID slim ballast Kit for 86 ? TRD_86 Cosmetic Modification (Interior/Exterior/Lighting) 21 08-02-2012 04:50 AM
