Old 07-08-2017, 05:31 PM   #71
extrashaky
Drives: 2014 BRZ Limited
I have never had to heel and toe a hill in my life and that includes very large military vehicles in the Bavarian Alps.
Why didn't I heel & toe ....... because, unless you had a shoe size 18 foot with a deformed ankle ...... it was impossible.
LOL. I was thinking the same thing when I read Tcoat's post. I once had to drive a 20 ton grip and lighting truck across Manhattan and through the Lincoln Tunnel at rush hour because I was the only person on our entire crew who could drive a stick shift (they were almost all New Yorkers). Even though it was huge (to me), I wasn't entirely uncomfortable in it because the pedals felt a lot like the '59 Apache.
Neither of which would be physically possible to heel-toe. Even if your foot were big enough, the brake pedal was so much higher than the gas pedal that your ankle would have to be double jointed, and your foot would have to have a right angle bend in the arch. You would startle children and little old ladies if you walked down the street with that.
The Following User Says Thank You to extrashaky For This Useful Post:
humfrz (07-08-2017)
Old 07-08-2017, 06:00 PM   #72
Meh. It could be done in the 5 tons but still never did it.
Many of my cars could not be heel and toed even if I had wanted to. My 58 Ford had no cover on the clutch pedal so it was about an inch wide piece of steel about 8 inches from the gas.
Old 07-08-2017, 06:46 PM   #73
You tried to heel & toe with the gas and clutch pedal ??...... no wonder you had difficulty ........
Tcoat (07-08-2017)
Old 07-08-2017, 08:31 PM   #74
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
You don't know how to drive manual if you can't heel toe clutch and gas.
The Following 2 Users Say Thank You to Andrew025 For This Useful Post:
humfrz (07-08-2017), Tcoat (07-08-2017)
Old 07-08-2017, 10:46 PM   #75
Lol brake pedal. i apparently had clutch in my mind. Suppose you could clutch with the heel of one foot and toe of the other and the term would still be technically accurate.
humfrz (07-08-2017)
Old 07-09-2017, 12:27 AM   #76
IronViper69
FR-S Hill Assist
If you do not have a car with hill assist on it and you really need one. Do it the old way. While stopped on a hill when ready to take off, pull up the hand brake give the car some gas and just before the clutch releases all the way, then release the hand break. That is what I use to do when I had my 2013 FR-S.
IronViper69 is offline   Reply With Quote
Old 07-09-2017, 02:48 AM   #77
WELCOME to the gang, there, IronViper69........
Yep, the old handbrake technique still works - fer sure .....
Old 05-23-2018, 11:00 AM   #78
Rai-zero
Drives: Legacy
I’m trying to turn my hill start off. I turned it on to try it out but it’s not for me. It can cause me to stall because I’m used to driving normal, backing up slight hill very little throttle and it’ll stall because of the hill start.
But I did the exact same thing as turning it on, hold the button for a minute or so until both lights go out then push button again and it won’t turn off.
Is there a trick about when and how long to hold the button the second time in order to disable?
Sorry if this is the wrong forum I have a 2018 BRZ but I’m assuming they are all the same.
Rai-zero is offline   Reply With Quote
Old 05-23-2018, 11:18 AM   #79
What does the owner manual say to do?
extrashaky (05-23-2018)
Old 05-23-2018, 01:29 PM   #80
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I turned mine and on and then off again following the same procedure as per the bullet point posts above.
I only found it useful on hills that are steep enough to require the hand brake otherwise.
Old 06-08-2018, 06:08 PM   #81
Ryan GT86
Ryan GT86's Avatar
Drives: 2019 Toyota 86
So for learning manual would be better to leave hill assist off?
Ryan GT86 is offline   Reply With Quote
Old 06-08-2018, 06:32 PM   #82
spike021
spike021's Avatar
IMO it doesn't matter _unless_ you figure someday you'll get to drive other manual transmission cars that don't have a hill start assist.
I'd recommend trying both ways so at least you know how to use the e-brake without assist.
Personally I use the hill start assist and haven't had any problems. Yesterday I was on a steep ass hill behind a car that decided to partially crest it to the stop sign, and then not go at all despite it being his turn, so I was stopped on what was probably a 60+ degree hill. Worked fine.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
The Following User Says Thank You to spike021 For This Useful Post:
humfrz (06-08-2018)
Old 06-08-2018, 08:06 PM   #83
Ya really ought to keep that machine on the paved roads ……….
spike021 (06-08-2018)
Old 06-08-2018, 08:10 PM   #84
spike021
spike021's Avatar
San Francisco's roads are paved! They're just unnaturally steep!
I think this is the one I mentioned: https://www.google.com/maps/@37.7579...7i13312!8i6656
Anyone planning HAC (Hill Assist) retrofit? Zardoman Engine, Exhaust, Transmission 28 06-07-2017 12:52 AM
Question regarding Hill-start assist control rkaywhodat Scion FR-S / Toyota 86 GT86 General Forum 17 09-30-2016 06:47 AM
Tuner Battlegrounds 2015 - Need an assist! protpibe Off-Topic Lounge [WARNING: NO POLITICS] 11 07-08-2015 06:51 PM
Cusco Jack Assist Ramp Set Evasive Motorsports Mechanical Maintenance and Tools 0 04-17-2015 02:40 PM
Car randomly doesn't start on slight hill Craig Issues | Warranty | Recalls / TSB 7 02-01-2013 02:48 PM
