#15 | |
Drives: 2016 Scion FRS
Sent from my SM-G920R4 using Tapatalk |
#16 | |
#17 |
Señor Member
Did you check to see if your brake/tail lights work yet?
I know it sounds silly but I've heard of this same exact issue at least 3 times and it was the brake light switch (or possibly even the fuse like someone else mentioned on here) Do you have aftermarket tails? When it happened to my buddy it was right after he installed a set. |
| The Following User Says Thank You to STV3 For This Useful Post: | strat61caster (06-27-2017) |
#18 | |
#19 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | JazzleSAURUS (06-27-2017) |
#20 | ||
Drives: FT86
Yes if your using oft to read codes it only appears to read engine codes from engine ecu. So it the cel light is from another control unit the oft doesnt see it, if you have torque app or other code scanner it will likely show you the code from the teaction vsc system. However the oft will log wheel speed sensors and steering angles from memory, check if your getting readings from all wheel speed sensors, but you rearly need the dtc code |
| The Following User Says Thank You to steve99 For This Useful Post: | Tcoat (06-28-2017) |
#21 |
Drives: 2013 Scion FR-S 10 Series
im also having this same issue, except they only come on when my headlights/fogs/ etc come on...anyone know what might be causing it? any advice would be appreciated. thanks!
#22 | |
Check your fuses for that one! Mine was like that the second time when I hit the brakes. Sent from my iPhone using Tapatalk |
#23 |
Drives: 2015 FR-S
http://www.ft86club.com/forums/showthread.php?t=118218
I have the same issue. Turns out its a brake pedal sensor or something. Its reproducible for me if i give just enough brake pressure for the brake lights to come on for a second or 2. It doesn't seem to cause any problems though (no limp mode) so I've just been living with it. |
#24 |
Hmm, seems like my fuses are good, and my brake lights do work. What's odd is that they only come on when the car is in drive and I turn on the lights. I'm hoping that it is related to a bad wheel bearing that I'm getting checked soon
#25 | |
Drives: '13 FRS - STX
Sounds like you have a wiring issue. |
#26 |
you're absolutely right! Last thing I didn't mess with was my iJDMToy 4th brake light. I removed the splicers and all is well again. Maybe I didn't install it correctly? Although the lights only became an issue well after I did the install. Oh well, hope this helps out someone in the future!
#27 | |
Drives: 2013 Scion FR-S Asphalt [Gray]
The only thing is be careful until you fix it as all assists including ABS are shut off when the brake light fails for some reason. |
#28 |
Sittin' Sideways
Drives: 2016 Toyota FR-S
I got these lights on solid when my car was hit back in March, though that makes it pretty obvious why it happened in my case. The car basically freaked out from the impact and sudden change in direction, and since I was hit in the front left corner that wheel and tire had a very positive camber situation going on. Along with that the TC was completely turned off, and the rear tires would light up like I was on a drag strip thanks to being on snow tires in the rain. Interestingly, when I went to turn the car back on a few days later after the accident (it sat unmoved for most of the week) those lights had turned off.
Anyway, if you haven't been involved in an accident, as others have said it's likely things got very thrown off/damaged/loosened by this pothole impact. Hopefully an alignment will have you back on your way.
-O/D
2016 FR-S, Hot Lava |
| CEL and Slip Light DTC P0353 | rocketbunny86 | Issues | Warranty | Recalls / TSB | 7 | 03-23-2016 08:38 PM |
| Engine light/ slip light and P0458 | evo4g63 | Issues | Warranty | Recalls / TSB | 1 | 10-06-2015 03:06 AM |
| CEL and Slip Light | Gums | AUSTRALIA | 10 | 01-15-2013 09:42 PM |
| CEL and slip light? | Rob_g | Issues | Warranty | Recalls / TSB | 2 | 10-03-2012 05:57 PM |
| Slip Indicator Light | erom | BRZ First-Gen (2012+) — General Topics | 17 | 06-10-2012 11:17 PM |
