Old 06-27-2017, 04:19 PM   #15
illxkoncept
Drives: 2016 Scion FRS
Originally Posted by JazzleSAURUS View Post
Tell us more about your alignment being off. Is it really screwy? If you have a ton of toe out in the rear it might be enough to constantly be tripping the light.
I'm in the boat that you likely have a damaged sensor, but it's totally possible that an alignment that's really bad could do this.
Did you do LCA's without toe arms perhaps?
I have to turn the steering wheel about 1/8 of a turn to the left to drive straight. I remember hitting a pothole with the front wheel yesterday do you think that would be enough to mess up a sensor? I'm thinking about bringing it to an alignment shop before the dealership.
Sent from my SM-G920R4 using Tapatalk
illxkoncept is offline   Reply With Quote
Old 06-27-2017, 04:22 PM   #16
Certainly would! An alignment shop will be able to check the sensor as well. Hopefully you haven bent anything to bad.
Old 06-27-2017, 04:52 PM   #17
STV3
Señor Member
STV3's Avatar
Did you check to see if your brake/tail lights work yet?
I know it sounds silly but I've heard of this same exact issue at least 3 times and it was the brake light switch (or possibly even the fuse like someone else mentioned on here)
Do you have aftermarket tails? When it happened to my buddy it was right after he installed a set.
STV3 is offline   Reply With Quote
The Following User Says Thank You to STV3 For This Useful Post:
strat61caster (06-27-2017)
Old 06-27-2017, 05:03 PM   #18
illxkoncept
Just checked, brake lights work. I have aftermarket tails but they have been on a year
Old 06-27-2017, 05:17 PM   #19
Think you already have the winner!
JazzleSAURUS (06-27-2017)
Old 06-27-2017, 11:10 PM   #20
steve99
Drives: FT86
Is there anyway I could know which one? I tried looking for a fault code with the oft and it came up with nothing
Out of my knowledge base on that one. @steve99 ?
Yes if your using oft to read codes it only appears to read engine codes from engine ecu. So it the cel light is from another control unit the oft doesnt see it, if you have torque app or other code scanner it will likely show you the code from the teaction vsc system.
However the oft will log wheel speed sensors and steering angles from memory, check if your getting readings from all wheel speed sensors, but you rearly need the dtc code
Tcoat (06-28-2017)
Old 07-03-2017, 05:46 AM   #21
jdair28
Drives: 2013 Scion FR-S 10 Series
im also having this same issue, except they only come on when my headlights/fogs/ etc come on...anyone know what might be causing it? any advice would be appreciated. thanks!
jdair28 is offline   Reply With Quote
Old 07-03-2017, 01:29 PM   #22
allowe
allowe's Avatar
Check your fuses for that one! Mine was like that the second time when I hit the brakes.
allowe is offline   Reply With Quote
Old 07-03-2017, 01:50 PM   #23
Cubix
Cubix's Avatar
Drives: 2015 FR-S
http://www.ft86club.com/forums/showthread.php?t=118218
I have the same issue. Turns out its a brake pedal sensor or something. Its reproducible for me if i give just enough brake pressure for the brake lights to come on for a second or 2. It doesn't seem to cause any problems though (no limp mode) so I've just been living with it.
Cubix is offline   Reply With Quote
Old 07-05-2017, 08:32 AM   #24
jdair28
Hmm, seems like my fuses are good, and my brake lights do work. What's odd is that they only come on when the car is in drive and I turn on the lights. I'm hoping that it is related to a bad wheel bearing that I'm getting checked soon
Old 07-05-2017, 01:54 PM   #25
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Highly unlikely that the car has any idea what the status of the wheel bearing is.
Sounds like you have a wiring issue.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
jdair28 (07-05-2017), Tcoat (07-05-2017)
Old 07-05-2017, 09:29 PM   #26
jdair28
you're absolutely right! Last thing I didn't mess with was my iJDMToy 4th brake light. I removed the splicers and all is well again. Maybe I didn't install it correctly? Although the lights only became an issue well after I did the install. Oh well, hope this helps out someone in the future!
The Following 2 Users Say Thank You to jdair28 For This Useful Post:
MJones_RB (10-18-2017), Tcoat (07-10-2017)
Old 07-10-2017, 03:21 PM   #27
TorontoNat
Drives: 2013 Scion FR-S Asphalt [Gray]
See if your brake lights work. My friend had the same issue and it was a broken brake light switch under the pedal.
Had this issue as well. Brake light was done.. cheapest fix you can possibly do on your car.. 16$ for the part and don't let anyone charge you labor for that... youtube it it's literally plug and play.
The only thing is be careful until you fix it as all assists including ABS are shut off when the brake light fails for some reason.
TorontoNat is offline   Reply With Quote
Old 07-10-2017, 04:46 PM   #28
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
I got these lights on solid when my car was hit back in March, though that makes it pretty obvious why it happened in my case. The car basically freaked out from the impact and sudden change in direction, and since I was hit in the front left corner that wheel and tire had a very positive camber situation going on. Along with that the TC was completely turned off, and the rear tires would light up like I was on a drag strip thanks to being on snow tires in the rain. Interestingly, when I went to turn the car back on a few days later after the accident (it sat unmoved for most of the week) those lights had turned off.
Anyway, if you haven't been involved in an accident, as others have said it's likely things got very thrown off/damaged/loosened by this pothole impact. Hopefully an alignment will have you back on your way.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
CEL and Slip Light DTC P0353 rocketbunny86 Issues | Warranty | Recalls / TSB 7 03-23-2016 08:38 PM
Engine light/ slip light and P0458 evo4g63 Issues | Warranty | Recalls / TSB 1 10-06-2015 03:06 AM
CEL and Slip Light Gums AUSTRALIA 10 01-15-2013 09:42 PM
CEL and slip light? Rob_g Issues | Warranty | Recalls / TSB 2 10-03-2012 05:57 PM
Slip Indicator Light erom BRZ First-Gen (2012+) — General Topics 17 06-10-2012 11:17 PM
