Old 03-29-2016, 12:30 AM   #1
UFO
Drives: 2013 Scion FR-S, 2014 Audi S4
Can't figure out my brake (non-)issue
OK, so my first track day went just fine with regards to brakes, I swapped out the stock pads for some StopTech street performance pads right before the event. So, brand new identical pads and this is how my wheels looked after the event:
Driver side
Passenger side
The car did not pull under braking and when I jacked it up both wheels spin freely. I would concur that the passenger side is dragging but, like I said, the wheel spins freely. What else should I be looking at?
UFO is offline   Reply With Quote
Old 03-29-2016, 12:53 AM   #2
j0307
j0307's Avatar
Drives: 2015 Subaru BRZ Series.Blue
Not knowing much about this, could it just be the pads wearing, has it happened again since they were new. If so I have no idea. But if not it might just be them wearing in from being new.
Sent from my SM-N910V using Tapatalk
j0307 is offline   Reply With Quote
The Following User Says Thank You to j0307 For This Useful Post:
UFO (03-29-2016)
Old 03-29-2016, 02:07 AM   #3
Northwest86
Drives: Velocity Orange 86 GT
Pedal dance? Ebd can go a bit spastic sometimes and so can the other nannies if allignment is out by a decent amount.
Northwest86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Northwest86 For This Useful Post:
Gforce (06-19-2017), UFO (03-29-2016)
Old 03-29-2016, 09:32 AM   #4
Ashikabi
Ashikabi's Avatar
Maybe cuz you didn't break them in?(you worded it like you went straight to the track :iono)
The Following User Says Thank You to Ashikabi For This Useful Post:
UFO (03-29-2016)
Old 03-29-2016, 06:49 PM   #5
UFO
Haven't really driven it since the track day to be honest, I don't think I've put enough miles on to generate any brake dust . Don't really have anywhere close to me where I can do some spirited driving.
Ah, yeah, I spent the weekend with traction control fully on until my final 2 sessions on the 2nd day and then EBD was still active (first time on track in 8 years, I was being super cautious). I think we might have a winner here.
10 threshold stops from 60 to 10 MPH with only a bit of braking in between and then drove around for 10 minutes with only gentle braking to let them cool down.
Old 06-19-2017, 02:40 PM   #6
kch
Senior Misanthrope
kch's Avatar
Driver side
[ig]http://i.imgur.com/hu8xC2G.jpg[/img]
Passenger side
[mg]http://i.imgur.com/3wXcg1R.jpg[/img]
Super delayed response, but if you haven't figured it out by now, that's just TWS. It's hard on the front passenger corner, particularly TC on. I've seen you at TWS a couple times since then, so I'm sure this is a moot point, but just in case anyone else was wondering...
The Following 2 Users Say Thank You to kch For This Useful Post:
strat61caster (06-19-2017), UFO (06-19-2017)
Old 06-19-2017, 04:00 PM   #7
Gforce
Drives: 2013 Subaru BRZ
More left turns than right could do this.
Modern ABS also have EBD which controls line pressure to each wheel separately.
Your brake dust pattern might just be confirming the EBD function is engaged a lot on that particular track. Left front brake is not being applied as hard as the right front, on average.
F1 cars aren't allowed to use EBD and lock up the less loaded tire accordingly. EBD gives street cars added safety by utilizing ABS selectively for each of the four wheels.
Gforce is offline   Reply With Quote
The Following User Says Thank You to Gforce For This Useful Post:
UFO (06-19-2017)
Old 06-19-2017, 04:14 PM   #8
UFO
Yeah, I gave the brakes a thorough going over and didn't have the same issue at MSRH so just put it down to being TWS. Thanks for the reply. Hopefully I'll get another run out at TWS before the end of the year, such a shame they're closing it , and I run with TC off now (as was evident last time out where I did some weed whacking in turn 6); I'm in the big boy's club .
Need Some Help Please: Brake Issue zkahle Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 02-04-2021 11:53 AM
E-Brake issue "clunking noise" when pulling the e-brake while rolling. Kinzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 06-20-2018 11:14 PM
Frs brake issue. F3dzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 01-12-2015 08:28 PM
BRZ factory head unit parking brake issue KevinBRZ Electronics | Audio | NAV | Infotainment 0 12-04-2014 12:00 AM
Cold / Wet weather brake issue? Ingen Scion FR-S / Toyota 86 GT86 General Forum 6 10-29-2012 12:42 PM
