#29 | |
Drives: 2015 Raven FRS
#30 |
Drives: 2013 BRZ Limited
PM me if you want details on my fuel system and how to solve this. Surge tank isn't the solution.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523 Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car www.makesmodels.com www.camautomag.com |
#31 |
#32 |
If surge tank isn't the solution, it would be really helpful to be shared with the community as that is the only viable solution I (and many others) are aware of.
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
#33 |
Yes, however, I don't have time to do a full write up at the moment, so I would prefer to discuss it in private to avoid any group confusion. The experience and education level on forums vary so much, I don't want to be responsible for someone making a mistake while trying to do a massive fuel system conversion without a proper write-up.
#34 |
Fair enough. I should have said the surge tank is the only plug and play type solution I am aware of. Certainly massive changes can be made.
#35 |
Drives: 2015 FR-S Release Series 1.0
So has anyone thought about installing some sort of drop in baffle balls?
Essentially plastic whiffle balls that would not displace much volume but would get jammed up in the middle of the saddle during high g corners and essentially create a barrier to the fuel sloshing to the other side. It seems like this is used in other applications successfully. Also it would be fairly simple to do as you would just open the fuel tank and drop them in rather than a complicated surge system/fuel cell and there's no risk of deterioration over time like there is with foam. Something like this but the size of ping pong balls: http://www.gemplers.com/product/WEB218017/Baffle-Balls or this in the golf ball or baseball size http://shop.ctstore.com/store/pc/vie...?idCategory=70 Edit: So apparently wiffle ball plastic will dissolve in gasoline over time, but the tank itself is made of high density polyethylene (hdpe) so I figure it must be safe to use HDPE baffling. My idea is to get some quality HDPE hollow balls and drill some holes in them. Any thoughts? http://cicball.thomasnet.com/viewite...e-hollow-balls Edit 2: I found a patent filed by Goodyear in 1965 for this exact idea. https://www.google.com/patents/US3349953 Last edited by avishenoy1; 06-13-2017 at 09:16 AM. |
#36 |
#37 |
Drives: Hydra EMS Powered FRS Raven Black
We install a lift pump in place of the siphon tube in the passenger side tank which helps a ton. Eventually even that wouldn't cure it but our car pulls 2G so it may work for most people.
What happens on the boosted car is that the bigger fuel pump or higher fuel demands can empty the oem surge faster than it can recover. It doesn't recover fast enough on the track due to fuel sloshing so your siphon system isn't working 100% of the time. |
#38 |
Drives: Ford mustang, Model 2018, Black
It is hard to say but you need to go to Auto Machnique. So, He can identify the problem and solve it.
| Left Hand turn fuel starvation on WOT | Huehuecoyotl | Tracking / Autocross / HPDE / Drifting | 105 | 08-05-2021 07:12 PM |
| High boost, e85, fuel starvation on a road course: What's everyone doing in 2015? | Xero-Limit | Tracking / Autocross / HPDE / Drifting | 6 | 06-16-2015 12:45 PM |
| Fuel Starvation issues? YAY OR NAY? | track_warrior | Tracking / Autocross / HPDE / Drifting | 23 | 10-22-2013 11:19 AM |
| Oil starvation in high loads | jdcorbitt3 | Engine, Exhaust, Transmission | 7 | 06-01-2013 10:46 PM |
| Fuel Starvation | feldy | Tracking / Autocross / HPDE / Drifting | 1 | 06-09-2012 10:14 AM |
