#15 | |
Time Traveller
I agree that building in the electronics may be possible, but that still doesn't account for the additional electrical storage needs (batteries) and possibly the recharge needs (beefier alternator, and possibly a KERS device.), and finally an ESC tune that ties it all together. For OEMs this is easy. For the Aftermarket, these items would need to be accounted for in addition to the Borg-Warner e-Turbo. Thankfully the 86 comes with an over spec'd 130 amp alternator (IIRC) so it's perfect for the Phantom ESC's recharge needs. To step the voltage up from 12v to 24v the Phantom kit uses 2x 12v Odyssey PC680's dedicated to the kit and a 3rd discreet PC680 as a vehicle systems/starter battery. The Borg-Warner e-Turbo is a 48v system so they'll be needing to use some method to get there from 12v. As far as tunes go, the Phantom ESC can be tuned with Rom Raider, ECUTek and OFT. Last edited by DAEMANO; 06-02-2017 at 02:29 PM. |
| The Following User Says Thank You to DAEMANO For This Useful Post: | SStratos (06-12-2017) |
#16 | |
Drives: 2014 Scion FR-S Monogram
All of your tips to reduce lag could still be put to use with a electric supercharger helping even more. The way I could see it working is it kinda acts like a small shot of nitrous would. It helps give that extra oomph to get things going quicker but doesn't really provide extra HP. Furthermore back in 2004-5 battery technology was shit compared to today. So your experiences have little to do with how a electric supercharger would work today.
Raven OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap |
#17 |
Drives: 06 Evo GSR SE, 17 Series Yellow BRZ
Most of my data point was aimed at the idea of using the electric turbine to pre-spool a main gas turbine. I don't believe I phrased anything in the light of an NA (non-hybrid) application.
It's basic physics that this would work on an NA application very well. I'm very aware aware the tech has come a long way. There is a you tube video of shiv or someone activating the turbine while they are standing in front of a brz/86 with a popped hood and just from a sound/visual stand point it was clear that they had greater power output than the set up I had going on almost 15 years ago. The set up i had was making somewhere in the 7-8psi range, I'm not sure what psi the phantom setup makes but for sure the motor is smaller in their set up. I really was not trying to talk down the phantom stuff and how they are using it here, I should have made that more clear. I was more aiming this at borgwarner and their angle to use it in a gas turbo application to pre-spool a gas turbo. I have not gotten too deep into the E-supercharger phantom threat because I'm currently trying to go through all the ecuflash/ecutek/oft threats to see if it is worth it to teach myself all the disassembly, protecol, C++ language stuff in the attempt to make a free tuning software. :-/ It is not a fast process at all lol. But back to the E-charger stuff, from what I have seen so far is that they are making good gains. I think I saw some 200+hp dyno charts which is pretty impressive and mathematically expected. They are going from a 0psi situation to a greater than 0psi situation .According to PV=nRT=energy P=Pressure V=Volume For an NA car it is pretty cut and dry that V (max) is constant on the "suck" stroke. So we can only vary pressure which is what an E-turbo or any air compressing device does. As pressure (P) goes up it multiplies with constant Volume (V) which equals more energy according to thermodynamics. ^_^ My argument above was that: A) With respect to Pressure (P), In a gas turbo engine you have a max pressure already set by your gas turbo's maximum psi at full boost. So you will not see an hp gain from an E-charger in such an application as the pressure of the E-charger gets over ran quickly by the pressure of the gas charger. Also using it to pre-spool a gas charger is negated by the fact that the E-charger is too weak currently to do that more efficiently than other options such as playing with timing/anti-lag/displacement. When E-Chargers do get powerful enough to spool a gas turbo faster than all other tricks in the book that means that they are at a level of power output to now be their own stand alone unit on a turbo application. In the pre-spool argument think of it like this. It takes so much gas flow to spin the exhaust side which spins the intake wheel. Well the reverse of that is true too, so much air flowing past the intake wheel will get the exhaust turbine to spin was long as the flow per area is equal in both scenarios. But if an E-charger can match the force per area flow to get a gas turbine spinning faster than the exhaust gas can get the gas turbine spinning...you have created a more efficient stand-alone turbo... even if only for a brief fraction of time. Which brings us to my 2nd argument B) How do we make the E-charger better as a stand alone unit? By focusing the tech and research on battery power output and recharging of that battery so that this E-charger can be more efficient for more than just a fraction of time. I believe a read somwhere in one of the phantom threads that the turbine can only be on for (x) amount of time then it powers down and the battery gets recharged from the alternator. "please correct me if I mistranslated that" If that is the case and I was phantom I would look into a battery set up similar to those seen in lowriders. The ones that power all that bouncy hydroponic "don't mess with my switches" type of set up or I would try to look for a crashed tesla battery pack in a junkyard. The larger lowrider battery set up or using a few battery cells from a tesla battery pack in conjunction with slapping a larger output and/or dedicated alternator to recharge those batteries fast should be able to improve how long you can keep that E-charger active. The phantom set up should also look into the wheel recharging systems from a crashed hybrid car and try to rig it on one or two brz hubs to handle the recharging if a larger output alternator isn't enough. Hope that makes things clearer from my first post :-) |
| The Following User Says Thank You to TachyonBomb For This Useful Post: | SStratos (06-12-2017) |
#18 |
Drives: runs&drives
ya check out the Phantom thread, they address batteries and other questions you have
| The Following User Says Thank You to WRBrzRX For This Useful Post: | TachyonBomb (06-02-2017) |
#19 | |||
Plus I have a physics degree so my background and experience have lots to do with the understanding of the concept. :-/ and again my 1st post was in reference to factory turbo applications not NA application because I was addressing the BorgWarner thread since this is a BorgWarner thread where BorgWarner is applying an E-charger to a turbo set up (within my experience). Had I had an issue or point to bring up with the phantom set up and how it is being applied to NA cars I would have gladly posted in their thread. But I don't really see anything wrong with their set up. I actually want them to further develop what they are doing. An E-charger as a stand alone unit should have been the mindset behind this tech from the beginning. Back 15 years ago I was in high school with my head shoved up the forced induction world that I never thought twice to apply the tech on my car to a non-turbo application lol. |
| The Following User Says Thank You to TachyonBomb For This Useful Post: | Detroiter (06-02-2017) |
#20 | |
I'm really looking for fun tech thing to jump into for the summer. So whether it's tuning software or E-chargers I plan on using my physics background somehow in this community. Still looking around to see what fits best for me. |
| The Following User Says Thank You to TachyonBomb For This Useful Post: | DAEMANO (06-02-2017) |
#21 | |
#22 |
yup that is what I'm looking into. Looking into the pros and cons of working within the parameters of that system to develop the it more or to just give up on life and get ecutek + racerom. seems like the major contributors to the tuning community here were ztan and james martin and they both seem to be non-existent anymore. So I'm just looking through all their old posts and information to determine if I would like to dedicate my time to romraiders and if there is a time/cost benefit to continuing ztans development or if I take the ecutek route and incorporate that james martin has made public. Super sad that both are not active on here anymore they really should be getting paid by ft86club and the community to continue their work.
#23 | |
Drives: 2017 WRB Subaru BRZ
What are the details of your "non sequential 24 volt setup"? I want to learn as much as possible about all FI options before I get my build underway. |
| The Following User Says Thank You to SStratos For This Useful Post: | DAEMANO (06-12-2017) |
#24 | |
Time Traveller
| 5% OFF all Borg Warner Turbos! | BRZFRSSTORE | Forced Induction | 0 | 02-23-2017 02:34 PM |
| First ever FR-S Borg Warner 7670 EFR turbo by JDL | texasbound972 | Forced Induction | 0 | 10-30-2014 12:19 AM |
| Borg Warner S255-RS .48 | FAER | Forced Induction | 39 | 05-16-2014 02:27 PM |
| Borg Warner Vs Garrett | DeBiase | Forced Induction | 12 | 12-03-2013 12:17 AM |
| Borg Warner Match Bot | diss7 | Forced Induction | 15 | 09-28-2013 11:13 AM |
