| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 |
There is a mileage requirement? So the system is weighted to benefit the dealer but presented as if to be best for the costumer?
#16 |
Drives: 2016 Subaru BRZ
Their website still says this though:
"For vehicles exceeding the above maximum mileage limits and not disallowed by the Vehicle Exclusions or the Vehicle Condition Criteria outlined in the Program Guidelines, the GTP Value offered to the customer must be reduced by $0.20 for each mile over the maximum mileage allowance. This is the only allowed reduction of the GTP Value." Come to about a $1,500 hit for me. But I still don't know what Subaru values my car at though. |
#17 |
#18 |
Drives: '22 WRB
Yes there is a mileage requirement, no it is not weighted to benefit the dealer. Just like leasing has mileage caps, the GTP program is a "bet" on the depreciated value of a car, and that is much much harder to be accurate on as mileage goes way up on younger cars, so Subaru caps mileage for GTP so they can accurately quote a trade in value that is good for both parties.
| The Following User Says Thank You to trippinbillies40 For This Useful Post: | Tcoat (05-23-2017) |
#19 | |
#20 | |
Drives: '22 WRB
#21 |
Drives: 13 brz limited
Well since my mileage had almost 30k more allowed I guess that means I get 30k x .20 added to my vehicle value.
I actually got really pist at subaru because in one month their trade-in value dropped by 4k. Total bs. |
#22 |
Drives: '22 WRB
Just out of curiosity, what does fair market price have to do with Subaru? If you want the most money for your car, sell privately. More work, but always your best option, especially if you think black book values are wrong.
#23 |
That's hard to do if you still owe money though.
#24 |
Drives: '22 WRB
#25 |
Persona Non Grata
Drives: '15 BRZ (WRB)
Let us know what a "top engine clean" is. I probably really need one of those whatever TF it is.
Slow is smooth, and smooth is fast
| The Following User Says Thank You to Capt Spaulding For This Useful Post: | Tcoat (05-23-2017) |
#26 | |
Sounds like they pour some shit in your gas or something. Even though the manual clearly says "don't pour shit or something in your gas". "Using a top engine cleaner can help: Reduce stalling, hesitation, and pinging. Make your engine idle smoother. Improve your exhaust emissions and gas mileage. Clean carbon deposits from inside the engine (decarbonize). Clean the intake valves and pistons. Clean the throttle body (a little)."
#27 | |
This is what the Subaru 30K service is supposed to include for around $300: Major Subaru Recommended Service* Perform at 30,000 Miles, 60,000 Miles, 90,000 Miles, etc Replace engine oil, filter and drain plug washer Inspect and adjust all drive belts to factory specifications Inspect and ensure cooling fan is operating within factory specifications Replace transmission fluid with Subaru High Performance Fluid Check to ensure air conditioning and heating systems are operating within factory specifications Rotate tires, inspect tread wear and check and adjust tire pressure as needed Perform brake system inspection; pads and/or drums, lines, hoses and fluid Inspect suspension system and steering components to ensure factory specifications Service battery, clean terminals, install anti-corrosion pads and check battery condition Inspect wiper blades and linkage operation Lubricate all door, trunk and hood latches and hinges if needed Inspect exhaust system and heat shields Replace front and rear differential fluid Inspect radiator and cooling system Adjust emergency brake to within factory specifications if needed Replace air filter element Inspect steering operation, tie rod ends and steering rack guides per factory specifications Inspect all engine and transmission mounts Inspect and adjust all fluid levels as needed Check all interior and exterior lighting operation Replace brake fluid Install premium fuel additive (dealer recommended) Factory trained technician to conduct road test
#28 | |
That's not too terrible. Full fluid and filter changes all the way around and full visual inspection too. Sure you can do it in under 2 hours (3 including getting the parts and supplies) yourself if you have the knowledge, the place to do it and the tools but at $300 I'd question if it's worth it.
| Subaru Guaranteed Trade-In Program | White64Goat | Off-Topic Lounge [WARNING: NO POLITICS] | 5 | 03-21-2014 04:25 PM |
| BeSpoke trade in program | jybrd | Issues | Warranty | Recalls / TSB | 23 | 07-22-2013 01:47 AM |
| Subaru VIP Program | tranzformer | BRZ First-Gen (2012+) — General Topics | 203 | 07-17-2012 02:12 PM |
| Subaru Graduate Program Documents | Motopythons | BRZ First-Gen (2012+) — General Topics | 5 | 06-03-2012 01:09 PM |
| have anyone join the Subaru VIP program? | Xdragonxb0i | BRZ First-Gen (2012+) — General Topics | 7 | 01-01-2012 08:33 AM |
