Old 05-16-2017, 11:02 AM   #1
AxisPower
Drives: 23 GT4RS
RCE T2 + Raceseng CasCam helper spring not fully compressing
Currently installing my Tarmac 2's with Raceseng camber plates and ran into a small issue. I noticed that the mount between the helper and main spring seems to be making contact with the spring perch on the camber plate before the helper spring can fully compress. I guess this wouldn't be an issue if I put the helper spring on the bottom, but all the pictures I've seen of other peoples setups the helper spring is on top. Just wondering if anyone else has had this problem? I'll post some pictures once I get home.
AxisPower is offline   Reply With Quote
Old 05-16-2017, 12:17 PM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
@Racecomp Engineering
Old 05-16-2017, 12:22 PM   #3
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Similar situation (Raceseng + Bilstein) I just put the helper on the bottom.
It's not unheard of:
ineedyourdiddly
Old 05-16-2017, 12:54 PM   #4
No issue with having the helper on the bottom.
PM a pic if you like and I can get a better idea of what's happening but I think that should take care of it.
- Andrew
Old 05-19-2017, 11:56 PM   #5
AxisPower
Drives: 23 GT4RS
Took some pictures to show whats going on with the front helper spring first in a free state:
and compressed:
As you can see, the helper spring doesn't have a thick enough compressed height and the upper camber plate spring perch gets pushed into the plastic perch. Unfortunately the same thing happens when I put it on the bottom, this time its the adjustable perch thats hitting.
The only solution I could come up with was to use the rear helper which is 10/60/80, versus the fronts 3/60/80. Since the rear helper has a higher spring rate, the coils are thicker and it is about half an inch thicker fully compressed versus the softer 3/60/80 which is just enough clearance. I took a picture to show how the fronts look like with the 10/60/80 rear helper with the suspension loaded up.
The only thing I'm missing is what was the reason for the fronts using different helpers in this case, I know kw v3s nowadays come with 10/60/80 front and back according to their website. I'm just wondering if there will be any issues running the softer helpers in the rear?
Old 05-20-2017, 12:05 AM   #6
byun
byun's Avatar
Drives: 2015 BRZ CWP
I'm running the exact same setup. I put the helper on the bottom up front and the helper on top in the rear. Have no issues.
byun is offline   Reply With Quote
Raceseng CasCam - Caster + Camber Plates with Spring Perch RJasonKlein Brakes, Suspension, Chassis 3 01-26-2017 08:14 PM
WTB Raceseng Cascam camber ft86me Want-To-Buy Requests 0 09-22-2015 06:22 AM
clutch helper spring replacement. another way Sandy AUSTRALIA 5 08-02-2015 05:32 PM
Spring bind - Raceseng CasCam & Ohlins RT 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-14-2015 03:56 PM
Looking for BRZ in NoVA area w/ helper spring removed! Synkronicity Mid-Atlantic 0 05-28-2015 01:36 PM
