#15 |
Drives: '13 FRS - STX
#16 |
Only users lose drugs.
Drives: All the time
"Passed" means it was somewhere within the wildly variable range of allowable specs. Nowhere close to an optimum setup for handling. And if you changed springs and didn't get another alignment, then that's a fail as well.
| The Following User Says Thank You to venturaII For This Useful Post: | #my86build (05-09-2017) |
#17 | |
It'll go down the road fine enough, but you're losing a lot of feel and performance. |
| The Following User Says Thank You to strat61caster For This Useful Post: | #my86build (05-09-2017) |
#18 | |
So the fact that you're asking these questions sort of proves out the assumption made by others (and myself, tbh) that your experience/ability to tell what's good or bad is lacking. Not a slam - just stating what seems to be obvious. And yes, the factory alignment specs are decidedly less than optimum for handling. The tradeoff is better tire wear, less tendency to tramline, more braking stability, etc. But if you want a car that responds well to steering input, those other qualities will suffer. |
#19 |
Drives: Track preped NA FRS
This thread is good, keep it going guys
#20 |
Custom User Title
Drives: Asphalt FR-S MT
You have some homework to do. If you don't know what an alignment is, that's the first place to start. Look up camber, toe, caster, and how each one has an effect on the way a car handles. Do that, tell us what you learned, then we can move on to the next step. Don't even say a single word about your "next build".
| The Following User Says Thank You to boredom.is.me For This Useful Post: | Cole (05-09-2017) |
#21 | |
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | boredom.is.me (05-09-2017), Cole (05-09-2017) |
#22 | ||
Because compromise ®
Drives: Red Herring
I made fun of the rear strut bar BUT the front strut bar is a different matter. Myself and many others have commented on a marked difference in feel after having a front strut bar fitted. This post sums it up well: Quote:
#23 | |
Drives: 2017 Subaru BRZ
| The Following User Says Thank You to Lust For This Useful Post: | Cole (05-09-2017) |
#24 | |
Suggestion to get some decent(not entry level) brake pads and brake fluid, and add some camber(2++) up front with some camber bolts and you should have a good base for the track. |
| A review of my first engine setup. All the pros and cons. | #my86build | Engine, Exhaust, Transmission | 4 | 05-01-2017 12:42 PM |
| N/A build pros and cons... | TRD_Demon527 | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 03-17-2015 09:41 PM |
| Pros and Cons of the Rocket Bunny Kit | VroomVroom86 | Cosmetic Modification (Interior/Exterior/Lighting) | 28 | 11-07-2014 02:29 AM |
| Greddy vs avo stage 1 Pros and cons of each | SliverBrz | Forced Induction | 90 | 04-18-2014 11:45 PM |
| KW V3's pros & cons | Shaolin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 22 | 02-25-2014 10:58 AM |
