Old 05-08-2017, 11:24 PM   #1
#my86build
A review of my first suspension/chassis setup. All the pros and cons.
Greetings
#my86build is offline   Reply With Quote
Old 05-09-2017, 06:59 AM   #2
Cole
Not a troll
Cole's Avatar
You lost me at the rear strut bar actually making a difference. Many well respected people on here have verified that there is no advantage to have a rear strut bar.
You also don't mention what kind of driving you do, what your experience levels is, etc. Sounds like you made about a thousand changes between your chassis, suspension and driveline within very short periods of time, so I very much doubt you know how it feels from part change to part change.
Old 05-09-2017, 07:52 AM   #3
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by #my86build View Post
4) ISC lower control arms - Let me start by saying, If I could be bothered to do so, I would make products for this platform. It's not rocket science. Scan the factory one, do the 6061 billet aluminum thingy everyone does, apply color, apply name and done. With that being said, why couldn't you coat the bolts that do the adjusting? Or just use better ones? 2 days in the rain and I had rust forming on them! 2!!!
I guess you haven't seen the Velox rear lca development thread. And it's 6061-T6 not 6061.
5) Cusco Crossmember Brace (rear)
lol
Old 05-09-2017, 07:53 AM   #4
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Those are great for hard parkers.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 05-09-2017, 08:25 AM   #5
swarb
1. Grimspeed did testing with their solid(not pivoting like the cusco)front strut bar, deflection was something like 3-4mm total with out it. With all the bushings and soft tires etc, would steering rack bushings done the same thing? The master cylinder brace does help with pedal feel.
2. Look at post above mine. I'd tell you to ask someone to have you take a blind test drive with it installed and not installed. And finally a 3rd time, and you try to guess which is which among the 3 tests. You'll be looking for noise isolation more than actual feel imo. Loss of trunk space sucks too.
3. Hotchkis is known to overbar cars and it creates cross talk associated with it. One side hits a bump, you'll feel it on the other side. They are more autocross oriented than anything. Not sure if they went for a more modest setup for this chassis.
4. $475, I'd would have gone spl or velox for a little more. Or the cheaper route with spc. But it's your money, plus the cool color!! Looking at the pic, they couldn't even get the correct nuts and bolts so they used washers(fits loose) instead. That zip tie in the end... to hold the metal insert in the bushing... those tolerances scream out "made in random chinese factory"
5. Is the added weight worth it? I personally would have gone with firmer bushings or metal inserts to replace rubber parts that are known deflect quite a bit over some bars that supposedly stop metal chassis parts from deflecting(the rubber bushings are still there!). But hey, I'm not an engineer, just a keyboard warrior. Cusco does make like 20 types of bars for this car.
What tires are you using? what alignment? what brakes? what tracking or competitive driving do you do? Stiffer is not always better. The chassis is plenty stiff for street tires and lower(most) skill levels.
Old 05-09-2017, 08:48 AM   #6
dattran86
Driver
Drives: 2013 Whiteout FRS
struts bar is really good when you hard park at the local car meet with your hood open to show off the engine bay, not sure if it actually made a noticeable difference in handling.
i could be wrong.
dattran86 is offline   Reply With Quote
Old 05-09-2017, 08:51 AM   #7
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Why people will immediately throw a completely new suspension on a car before even getting a decent alignment and some good wheels and tires is beyond me. But, I bet it looks nice.
venturaII is offline   Reply With Quote
Old 05-09-2017, 09:14 AM   #8
D_Thissen
D_Thissen's Avatar
Another victim of advertising and the 'butt dyno'.
Old 05-09-2017, 09:16 AM   #9
D_Thissen
D_Thissen's Avatar
i could be wrong.
They could be beneficial on a car that lacks a roof for structural rigidity. I know early 1990's GM convertibles had them. That said, the 86 chassis is plenty stiff for the majority of owners.
Old 05-09-2017, 09:26 AM   #10
StraightOuttaCanadaEh
Wes
Actually my first observation in this car was just stiff and "well bolted together" it felt.
Old 05-09-2017, 09:38 AM   #11
venturaII
venturaII's Avatar
I don't want it to sound like I'm against modding the car - there's a rich aftermarket for it, there are lots of good products, and it's your car to do what you want. I'm sure all the parts look cool. But given your choices, I question whether you've got the experience/skill to actually determine that the car has actually improved. I'm sure it feels different, but if you drove an otherwise stock car with a really good alignment, and compared it to yours, I wonder if you'd be able to tell which is which...?
Old 05-09-2017, 10:57 AM   #12
Cole
Not a troll
Cole's Avatar
The only change I could ever feel was adding -3* camber up front. Oh, and the changed ride after lowering springs.
Old 05-09-2017, 12:50 PM   #13
venturaII
venturaII's Avatar
I've played Gran Turismo on the Playstation before and I know heel and toe requires the use of your hands and shifting speed.
This thread just jumped my shark.
Old 05-09-2017, 12:52 PM   #14
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
This would have been an amazing troll post if the op wasn't serious.
In order to review anything, you have to actually know what you're talking about. You don't know what you were trying to fix. You don't know what change there would be if any. And to make it worse, you did it all together. Realistically, you just paid to make the car "pretty". And I say that with quotes because I personally think Cusco (for this platform) is garbage.
I'm not trying to be an asshole. It is the sad truth though
A review of my first engine setup. All the pros and cons. #my86build Engine, Exhaust, Transmission 4 05-01-2017 11:42 AM
N/A build pros and cons... TRD_Demon527 Scion FR-S / Toyota 86 GT86 General Forum 35 03-17-2015 08:41 PM
Pros and Cons of the Rocket Bunny Kit VroomVroom86 Cosmetic Modification (Interior/Exterior/Lighting) 28 11-07-2014 01:29 AM
Greddy vs avo stage 1 Pros and cons of each SliverBrz Forced Induction 90 04-18-2014 10:45 PM
KW V3's pros & cons Shaolin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 02-25-2014 09:58 AM
